ArmitageShanks
Digging A Hole?
Mon Feb 23, 2004 3:14 am
Hypothetical question:
Lets say I started to dig a 10 foot wide hole from my backyard to the exact opposite side of the earth. What would happen to gravity when I reached the centre of the earth and started to dig up (or would that still be down)?? If I made it all the way through, how would that be physically possible?
What would happen if I jumped in the hole?
N766UA
RE: Digging A Hole?
Mon Feb 23, 2004 3:18 am
Maybe you'd just explode?
This Website Censors Me
Twistedwhisper
RE: Digging A Hole?
Mon Feb 23, 2004 3:44 am
My guess is that you'd be floating....? Slightly towards the moon....
Read between the lines.
707CMF
RE: Digging A Hole?
Mon Feb 23, 2004 7:26 am
Actually, the further down you'd go, the lesser you would weight.
Weight force is at maximum at the surface of the Eart, decreases on a square root ratio if you go up, and decrease (on a 3 root ratio I believe, but not sure) if you dig your way down.
707
Sonic
RE: Digging A Hole?
Mon Feb 23, 2004 8:13 am
You would burn, as it is hotter the more down you go. Also, certain parts of earth are liquid and thus you wouldn't pass through if you jump (nor you would be able to dig there).
photopilot
RE: Digging A Hole?
Mon Feb 23, 2004 8:31 am
Here you go. Everything you wanted to know about what's inside the earth.
Here's the link to the whole slide presentation.
http://lewis.up.edu/mcs/wasowski/sci110/TnTkCh05/sld003.htm
Here's the relevant slides.
The Lithosphere
The Crust - Mantle - Core
As an analogy. If the earth were an apple, the deepest depth ever dug by man in the world's deepest mines, wouldn't even be deep enough to get through the apple's skin. Think about that.
Steve
JetService
RE: Digging A Hole?
Mon Feb 23, 2004 10:03 am
You'd be deafened by the loud whistling noise the Earth would make as it hurls through space.
"Shaddap you!"
tbar220
RE: Digging A Hole?
Mon Feb 23, 2004 10:15 am
Yea, I think force due to gravity is inversly proportional to the radius of the earth squared. So the further down you go (ignoring effects of heat), you would feel less and less in weight. Once you get to the center, if the earth where the only object in the universe, you would probably just float because you would be at the center of gravity and mass of the entire system.
NO URLS in signature
ArmitageShanks
RE: Digging A Hole?
Mon Feb 23, 2004 11:04 am
So, if I dove in the hole I would just kind of stop and hang in the middle.
maiznblu_757
RE: Digging A Hole?
Mon Feb 23, 2004 11:31 am
You would weigh more all the way down to the center, but, you would stop because the gravity is equal all the way around the circumfrence of the earth... There would be an equal force each way... You may crush....
[Edited 2004-02-23 03:43:29]
N766UA
RE: Digging A Hole?
Mon Feb 23, 2004 11:52 am
I ammend my prediction.....
You would implode.
sleekjet
RE: Digging A Hole?
Mon Feb 23, 2004 12:30 pm
What you'd find along the way: Bill Buckner's firstbaseman's mitt, chads from the Florida ballots, the missing 727 from Africa, all of JCS's unsigned report cards from elementary school, and the end of the uploaded a.net picture queue.
II Cor. 4:17-18
prosa
RE: Digging A Hole?
Mon Feb 23, 2004 12:37 pm
You can pick up a shovel for ten bucks at Home Depot or Lowe's. Why not find out for sure? You can post your results in the Trip Reports forum  Smokin cool
"Let me think about it" = the coward's way of saying "no"
MD11Engineer
RE: Digging A Hole?
Mon Feb 23, 2004 1:02 pm
Provided Earth would be solid and a perfect sphere, gravitational force would decrease with increasing depth because the forces of all the layers above you would cancel each other out and onkly the amount of mass between you and the center would attract you. At the center you would be weightless.
An object thrown into a borehole right through the planet would (provided no friction) oscillate through the center.
jan
maiznblu_757
RE: Digging A Hole?
Mon Feb 23, 2004 4:39 pm
This is deep... LOL.. Very interesting to think about. I never thought about it, but, brainstormed and came up with my synopsis.. I think its pretty close to what would happen..
Users browsing this forum: aerlingus747, BobPatterson, einsteinboricua, Francoflier, UltimoTiger777, vc10, wagz and 3 guests
