CHRISBA777ER
Terrorist Attack On A Ferry?
Fri Mar 12, 2004 9:03 pm
QIGuy24 raised a chilling point in his terrorism post earlier and i wanted to share my opinions on this - as its not directly related to the piece i thought id start a new thread so we could have some opinions on this. I work in the Marine industry, and have extensive experience working on ferries, I have my degree in Ferry operations business, and work writing credit reports now for ferry and cruise companies as well as airlines. Not wishing to be morbid, but ive been considering the effects of what would happen if a terrorist attack took place on a ferry, and it makes disturbing reading.
Its very difficult to blow up a ferry. You would need many thousands of pounds of explosives to do any meaningful damage - they are very structurally strong - But its easy to kill nearly everyone on board - small incendiary charge on a tank trailer on the vehicle deck - very easy to smuggle aboard and easy to place - once theres a bad fire on the cardeck - ie: refined petrochemicals in a tanker vessel or trailer - not all ferries have weatherdecks fore or aft, so for the most part all the IMDG stuff goes on the vehicle decks. (IMDG - International Maritime certified Dangerous Goods - ie: petrochemicals, refined hydrocarbons, oxidising agents, flammable liquids, gases, explosives etc).
All vehicle ferries over a certain gross tonnage now have to have longitudinal bulkhead doors to prevent fires from spreading through the car deck but these are normally aluminium and will melt in eight or nine minutes, if the fire is hot enough - ie: if you are burning Kerosene or something. Either way, they are not air tight, normally there is a gap at the top to aid ventilation, and the other compartments will certainly flashover (air temperature in the adjoining compartment is risen due to transferred heat from the involved compartment to the point where the oxygen in the air combusts) before the doors melt. The vehicle decks have a degree of fire protection in the form of sprinklers, and sometimes halon gas flooders, but these are of limited use on a really severe petrochemicals fire. Then you have secondary explosions from petrol tanks and other nasties cooking off in the fire.
Expect smoke to fill the lower decks and begin rising into the passenger decks inside four minutes, and to reach the upper decks in six. Anyone below the car decks (many large overnight ferries have passenger cabins and such below the car decks) is in real trouble, quite simply as smoke or fire may reach the stairwells down very quickly.
For maximum passenger casualties you would need to detonate the bomb in the middle of the night - say, just before three, when everyone is in bed, and the crew are at their lowest state of readiness. If it is good weather there are probably only two people on the bridge, and probably only the second officer - the more senior deck officers often prefer not to take the really late shifts, especially on ferries. People react slower at night time. This includes emergency services.
For maximum effect, further incendiaries may be planted in cabins and lower deck areas where the fire may not be discovered until it has taken hold and become too intense to extinguish with hand held fire extinguishers.
The reason fires are so dangerous is because of the materials used in fitting out passenger ferries - when they burn they really, really burn very quickly, and often give off toxic gases, which mix with the smoke meaning that from when you first smell smoke, unless you are perhaps thirty seconds from clean air ie: outside - open decks, then you will collapse from the toxic effects of the gases and die where you fall. The vast majority of people who died in the Scandinavian Star tragedy died because they didnt get out of the smoke quick enough and passed out from Carbon Monoxide poisoning.
Now think of this.
The newer breed of overnight cruise ferry, more often found in the Baltic, though also in numbers on English Channel, can carry more than 1,500 people in cabins, sometimes as many as 2,200. It takes more than ten to twelve minutes to get everyone out on deck at at the outside muster stations ready to embark the lifeboats and liferafts, after the first alarm has been raised. Think it probably takes thirty seconds to raise the alarm if the fire/explosion is on the cardeck, but much, much longer if it is in an enclosed upper deck space, such as the cinema, cleaning locker, or cabin block. The muster alarm may not be given right away - it is the call of the senior bridge personel at the time - they may wish to sound the general alarm, and send the night watchman to investigate the alarm.
So, assuming the alarm is raised quickly and professionally, then the people who can get out of the rapidly smoke filling superstructure, will be gathered out on deck and awaiting the Master's signal to commence abandonment procedures - this will mean, again, assuming all is going well, that people will be preparing 25 person liferafts which will be lauched over the side with one crew member and 24 passengers in. The lifeboats will take 200+ each. This procedure will take no longer than 20 minutes to disembark everyone. By the end of this, the first of the helicopters will be overhead, again, assuming all goes well and the weather is fine, and any passing shipping will be on scene soon. If anyone goes in the water fully clothed in the winter ie: now, in the shallow English Channel, they have maybe eight minutes before they die of cold, less if the person is unfit etc. This time is much reduced in the colder waters of the North Sea.
Potentially you could kill hundreds of people this way.
What a chilling and horrible prospect this little scenario makes.
More so when you consider that Spanish police intercepted an ETA bomb plot to attack the Brittany Ferries Val de Loire out of the Basque port of Santander back in 1999.
Any thoughts guys?
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
LHMark
RE: Terrorist Attack On A Ferry?
Fri Mar 12, 2004 11:41 pm
Thanks, Chris. Our new Crapchester-Toronto fast ferry arrives next month. I WAS going to take it...
"Sympathy is something that shouldn't be bestowed on the Yankees. Apparently it angers them." - Bob Feller
QIguy24
Fri Mar 12, 2004 11:47 pm
Let's take as an example as well:
USS Cole bas badly hit in Yemen a couple of years ago. And if that happened to a passengership out in the middle of nowhere, It would really look bad.
L-188
Sat Mar 13, 2004 12:01 am
Are you actually allowed to carry loaded tank trailers over there on passenger ferries?
I don't believe that is legal in the US.
In fact every time that I have been boarded on an Alaska Marine highway vessel, they have asked if I had any propane bottles on the vehicle, something of big concern with the large numbers of RV's they carry. If you do they have to be sealed by a ferry worker.
Also right after 9/11 some guy got busted for undeclared Hazmat because he had 20 cases of ammo in his truck. I don't know if that was because he didn't declare it or it was prohibited from carraige.
QIguy24
Sat Mar 13, 2004 12:06 am
Here in Denmark you are allowed to have that.
And no one checks you if you have propane bottles in your car or in your van. So you can easily say that you dont have anything. Thats why this thing is so scary. If you drive a van loaded with explosives no one checks either. They just let you thru. It is only the trucks that are being scanned here in Scandinavia.
So ferries are easier to bomb than people think. That is so scary.
MD11Engineer
Sat Mar 13, 2004 12:34 am
Imagine a truck with a large ANFO bomb on board, the stuff they used in Oklahoma City. Cheap to make out of diesel fuel and certain widely used fertilisers. All you´d need is a few sticks of a commercial dynamite and a blasting cap for the primer. A standard long distance truck as used in Europe could carry about 30 tonnes of this stuff. I t would take the ship apart, just like the Hood, when she was hit in her magazines by the shell from the Bismark.
Jan
L-188
Sat Mar 13, 2004 12:36 am
The idea of hauling fuel trailers or chemicals on a closed cargo deck is completely mind boggleing.
How in the world do you vent that?
I belive that that is one of the reason on the M/V Lutyia they went for an open deck, to get around those problems.
Users browsing this forum: aerlingus747, salttee, TheGov, ThomasWarloe and 1 guest
