USAFHummer
Cars: Is There A Difference Between AWD And 4WD?
Wed Aug 11, 2004 7:47 am
Hi,
Im not really a car person but I know loads of them are out there so I figured I'd ask this here...is there a difference between "All Wheel Drive" (AWD) and 4 Wheel Drive (4WD)?? If so, what is it??
Greg
pl4nekr4zy
RE: Cars: Is There A Difference Between AWD And 4WD?
Wed Aug 11, 2004 8:03 am
I'm no car expert either, but I believe if the vehicle is 4WD, you can choose to put it in 4 wheel drive or 2 wheel drive like most cars. All wheel drive is like permanant 4 wheel drive.
"Don't forget to bring a towel!"
desertjets
Wed Aug 11, 2004 8:09 am
I'll probably butcher this, but in principle is should be mostly right.
4WD refers to systems that are part-time and use a fixed front wheel/rear wheel torque split, IE: 50-50.
AWD refers to systems that are full-time and have a variable front/rear torque split. Such that under most conditions most of the power will be sent to one set of wheels. A slippage is sensed the center differential shifts the torque split.
EGGD
Wed Aug 11, 2004 8:22 am
I was thinking AWD included the spare tire  Smile/happy/getting dizzy
NWA742
Wed Aug 11, 2004 8:36 am
To be basic:
4WD: Allows the vehicle to use the two rear wheels for traction, or in 4WD, use all 4 wheels. In a 4WD mode, you have 4 wheels gripping at ALL times.
AWD: AWD is basically an automatic 4WD system, it goes on and off whenever it is needed, and it doesn't have to use 4 wheels at the same time. It'll sense what wheels need the traction.
-NWA742
Some people are like slinkies - not good for anything, but they bring a smile to your face when pushed down the stairs
Klaus
Wed Aug 11, 2004 9:16 am
I´m pretty certain it´s merely a marketing tool to differentiate from "the other" manufacturer´s slogans.
Unless you´ve got more than four wheels, of course.  Wink/being sarcastic
In that context, EGGD´s explanation can make a lot of sense.  Big thumbs up
[Edited 2004-08-11 02:17:27]
vafi88
Wed Aug 11, 2004 10:23 am
NWA got it right!
4WD you have an option to go 2 wheels grip or 4 wheels grip
AWD senses when you need the 4 wheel grip automatically and switches to 2 wheel grip when you don't need the traction.
I'd like to elect a president that has a Higher IQ than a retarted ant.
gigneil
Wed Aug 11, 2004 11:33 am
Most AWD systems these days have either a 90/10 or 80/20 distribution of power during normal conditions.
N
Skyway1
Wed Aug 11, 2004 12:58 pm
All I know is that AWD systems add some heft to the vehicle's weight and also suck some horsepower from the engine as well. The AWD on te Pontiac Vibe(stock motor) takes away 7 horsepowerk(130 VS. 123). Even the quick G35X loses a bit with it's AWD system. Didn't add much to the thread I'm afraid.....oh well.
Chris
KNUK, KNUK, KNUK woowoowoo
USAFHummer
Ok...thanks so much for your help everyone...now...is one better than the other or is it some kind of personal preference just like manual vs. auto?
Thanks again,
Greg
L-188
Wed Aug 11, 2004 5:22 pm
On a HEMTT the 4WD would only engage the back two axles.
AWD would engage the front two axels.
8WD rules the Day  Laugh out loud
Damm I miss that truck
N6376M
Wed Aug 11, 2004 9:12 pm
I have a Honda Pilot with AWD. The car's great. It's roomy and has a tremendous amount of cargo space. I've never had any problem getting through anything (I do some very light off roading). The AWD sends power to the individual wheels when the computer senses them slipping. There's an option to lock the wheels into 4WD if you need it.
My understanding is that AWD is a good mix between performance and economy.
-76m
tristarenvy
Wed Aug 11, 2004 10:22 pm
I read somewhere that carmakers will use the term "AWD" instead of "4WD" on vehicles that have drive power to all wheels, but were NOT meant to go "four wheelin" in a mud bog somewhere.(Probably keeps the Lawyers out of their hair, too) So don't try and go crazy in a field with a Subaru Legacy, as opposed to an old CJ-7 with big ass tires and a honkin' V-8 under the hood.
[Edited 2004-08-11 15:35:22]
If you don't stand for SOMETHING, you'll fall for ANYTHING.
desertjets
Wed Aug 11, 2004 10:32 pm
Of course they are also marketing terms too.
But the important distinction is how the system is activated and what the torque split is (and whether it is variable). Go to Subaru's or Audi's website... both have pretty decent explanations on how their AWD systems work.
Now there are variations within all of this to make it even more confusing. Most conventional AWD systems like you see in a Subaru or an Audi or your mass market SUVs for that matter are strictly designed for on-road use only. There are some AWD systems that have been designed for off-road use. This will include a low-range (which is pretty much common in conventional 4WD set-ups) as well as one or more locking differentials. A locking center differential will keep the front/rear torque split constant, like in a conventional 4WD system.
Users browsing this forum: GDB, vhqpa, WIederling and 3 guests
