duke
Use Of Compact Disks
Mon Aug 23, 2004 5:22 pm
I need questions answered regarding use of compact discs:
1) Is there any way to transfer cassette recordings onto a CD?
2) I put some material onto a CD ROM instead of a floppy disk recently. CDs are less likely to break down, I'd say (I recently lost my resume due to a disk suddenly becoming "not formatted"), but once I had typed some stuff and closed the file, I COULD NOT EDIT IT! Is there such a thing as a CD ROM that you can type on and EDIT like a floppy disk?
Klaus
RE: Use Of Compact Disks
Mon Aug 23, 2004 6:34 pm
1) Yes. You need to record your cassette into digital format first. That´s usually done with a software that digitizes the analog audio input and writes a WAV or AIFF file. Then burn the file(s) to a CD (most burning softwares can do the necessary conversions).
2) CD-RW disks can be re-recorded multiple times, but not exactly like a floppy disk. Handling depends on the driver software in your system. You should normally make a copy to your harddisk for editing and only update the CD when finished for the day.
CD-RWs "wear out" a little bit every time they are written to, and they are not quite as "safe" for long-time storage as CD-Rs (write-once) are.
It´s definitely a good idea to make more than one copy of your important data so you´ll have a backup when the main copy should not be usable any more.
And: Never touch the surface of a CD, except when cleaning them (carefully). Only hold it by the edge. Especially audio CDs are quite durable, but a data CD is more easily damaged (and usually more valuable).
Users browsing this forum: bagoldex, Google [Bot] and 12 guests
