SA7700
XP Professional Upgrade
Wed Sep 22, 2004 5:07 am
I need help please, fellow A.netters!
I'm trying to upgrade from Windows 98SE to XP Professional. However, as soon as I have entered the Product Key and the installation process starts, the following error occurs and eventually causes a Fatal Error. The setup can not be completed.
Setup cannot copy E:I386MFC42 DLL to C:windowssetupMFC42.DLL
Any ideas what the cause could be and how I can rectify this?
SA7700
PS: For some reason the backslashes e.g. E: are thrown away.
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
KBOS
RE: XP Professional Upgrade
Wed Sep 22, 2004 5:22 am
you might want to check this out.....
http://support.microsoft.com/default.aspx?scid=kb;en-us;310064&Product=winxp
it might give you a few idea's.....
I don't care if the sun don't shine, I do my drinkin in the evening time when I'm in Rhode Island
Brick
Wed Sep 22, 2004 5:23 am
Did you confirm your system meets the minimum requirements for hardware as indicated on the side of the box the software came in? Windows 98SE is pretty old (in the computer workd), so I the first thing I'd look at is hardware. Are the RAM, disk space, processor, and graphics card good to go on Windows XP?
Also, are you letting XP do the upgrade from 98 or have you reformatted your disk for a "clean" install (which I definately recommend)?
A noble spirit embiggens the smallest man...
SA7700
Wed Sep 22, 2004 1:56 pm
KBOS
Thanks mate, I have seen that one already, and will try again this evening when I have some time on my hands.
Brick
Yes, I made very sure that my system meets all the hardware requirements, as XP Pro is quite expensive in South Africa. Unfortunately I have to go with the upgrade, as there is a lot of data on my hard disk.
Thanks for the input.
SA7700
Bronko
Fri Sep 24, 2004 4:18 pm
Make a folder on your harddrive called, XPPro or whatever. Open that folder up, and copy the entire contents of the cd to the new folder. Then run setup.exe from your harddrive.
I am guessing it is a problem with the cdrom drive, is it old?
Jet City Aviation Photography
Users browsing this forum: 817Dreamliiner, airtran737, ANITIX87, casinterest and 4 guests
