klm672
Leaving The Computer On All Day And Night
Wed Sep 22, 2004 5:19 am
Hey, now at college, i notice that a lot of students leave their computer on all day and night, for days. I was wondering is that good for the computer? I do the same, but I just wanted to know.
Also I love to fly FS2004, will it hurt the game, or my computer, if I just let the plane fly for a few hours when I go to class? One night I took off, got it to 35,000ft, set the heading and went to bed, woke up around 6:00AM and landed it.
Andre
desertjets
RE: Leaving The Computer On All Day And Night
Wed Sep 22, 2004 5:24 am
What will happen if you leave your computer on for a long period of time, may I ask you????
Unless you set it up not to, your computer will go into standby mode after a while anyways. Practically like being off anyways. If you have a noisy computer and it bugs you while you try to sleep, then turn it off... otherwise don't worry.
slider
Assuming your CPU fan and power supply cooling fan is up to snuff, there's no problem in leaving it on.
In fact, I've heard recommendations that it's BETTER to keep it on instead of having frequent power up and power downs. I can't substantiate that however- just word of mouth from some buddies who are PC guys.
jutes85
I wouldn't leave it on all night unless you leave it on for a flight, I do that myself.
Turning it on updates some files and refreshed the system. So if you can, turn it off or just hit the sleep button not to waste energy. Besides, the fan is annoying.
nothing
qr332
I usually don't turn off my computer or even restart for a whole week, and the only problem I ever had was my PSU burn because of a power surge, but that had nothing to do with me leaving it.
Regarding FS2004, many long haul flyers do that, just be sure that the plane doesnt get to its destination beforehand, and you should be fine.
"The greatest threat to knowledge is not ignorance, it is the illusion of knowledge."
aa61hvy
Wed Sep 22, 2004 5:25 am
Better question is, why wake up and land at 6am, thats crazy talk.
I leave my computer on pretty much 24/7, I try to restart it once a week
Go big or go home
Logan22L
Wed Sep 22, 2004 6:02 am
RE: What Slider mentioned, IT personnel have also told me that it is better to leave the computer on and avoid excessive powerdowns/startups. However, the "refreshing" aspect of restart is also a good thing periodically. That said, you should be energy conscious, and use sleep mode. The effect on sleep mode on simulators, etc. may vary. Also, I had trouble waking my office computer up from sleep mode, so I cannot use it; therefore, I shut down every night.
Logan
"The deeper you go, the higher you fly. The higher you fly, the deeper you go."
EGGD
Wed Sep 22, 2004 6:16 am
Yep, If you don't enjoy huge electricity bills, switch your computer off. However, switching it off/on will significantly reduce the life of your power supply, and leaves a greater risk of it blowing up and taking out every component that is connected to it (Cards in slots on your motherboard will not be damaged, only parts connected to the power supply by a cable will blow).
Its really up to you, I used to leave mine on except for the odd occasion. In every day use you should have to restart anyway, most updates done by windows update will install periodically and will restart if needed automatically.
CaptOveur
Wed Sep 22, 2004 6:26 am
I have heard it is a lot better to leave it on, no heating up and cooling down all the electronics and less wear on the switches.. I leave mine on all the time and run SETI at home as a screensaver.
Things were better when it was two guys in a dorm room.
Klaus
Wed Sep 22, 2004 6:48 am
It depends...
If the computer has crappy components, it may better to switch it off in order to get the most usable life out of it. Underdimensioned power components or crappy fans come to mind, also bad cooling which leads to permanent overheating of some or all components. Semiconductors, some capacitors and harddisks age much faster at high temperatures.
A decent system, however, generally will live longer if you spare it too frequent on/off cycles. Harddisks are especially stressed by stopping and starting (which also means you should not use the "sleep mode" of a harddisk at all or at least only sparingly); Next in line are power semiconductors, mostly in the power supply and in the voltage regulators. Some capacitors will also age with thermal cycles.
MD11Engineer
Wed Sep 22, 2004 7:00 am
One thing comes to my mind:
After I had a power supply failure (fortunately without taking anything else down with it), even though I tend to let the computer run around the clock (except when I´m travelling, then everything in my flat gets shut down except for the fridge), I shut it down and open the housing every 3-4 months to clean out the innards wih a hoover. You won´t believe how much dust will accumulate in a computer and I think overheating of the power supply due to accumulated durt over two years caused it to break down.
Jan
Rj111
Wed Sep 22, 2004 7:10 am
Due to the incresed heat, Concorde expanded 7 inches in length when in a supercruise. So if the components in your computer are frequently being heated and cooled because you are turning the computer on and off then this must surely increase the probability that they are going to break.
Just my 0.02GBP
dazultra
Wed Sep 22, 2004 7:40 am
... yeah man!
current uptime of my server:
 Smokin cool
PPGMD
Wed Sep 22, 2004 7:50 am
That's not a server, it's barely moving packets.
Now this is a server moving packets
Screenshot taken on July 1st, the server ran without a reboot until our friend Fances decided to kill our power for 4 days.
I have my personal laptop on for 60 days or more without a reboot.
If you a enough cooling on your system, then it's actually better to leave your computer on (as long as you have good surge protector and UPS). But in reality leaving it on doesn't extend the life of the computer all that much, IMO.
At worst, you screw up and die.
dazultra
Wed Sep 22, 2004 7:54 am
I think ul find it is a server, albeit not a very busy one  Big thumbs up. Just handles a smallish website, mail and an ftp site.
Daz.
Users browsing this forum: Baidu [Spider], BlueberryWheats, Google [Bot], SQ948 and 1 guest
