CaptOveur
A Question For The Mechanics
Wed Sep 22, 2004 1:20 pm
My girlfriend drives a 2000 Mitsubishi Galant with (I think) the 2.0ltr 4cyl engine, I know its a 4cyl, just not positive on the displacement. the transmission is a 3 speed automatic. It has about 70,000 miles on it and has had regular maintenance its whole life, eg oil changes every 3000 miles. The car just got new belts about a month ago.
Oil consumption is negligible, 1/4 to 1/2 quart between changes.
over the last few months it developed a very slight ping around 4000rpm, usually I only noticed it very faintly when getting on the highway or passing, I advised her it might be time to think about getting a tune up, she hasn't taken it in yet.
The other night I was driving it down the highway at about 70mph, 2800rpm and it started making this noise that sounded like a really bad pinging. I was thinking bad gas or something but it was happening at a low RPM. Earlier today the noise came back, this time at idle, as before it went away a few minutes later. I have decided this noise is probably not a simple ping and I am getting concerned it might be something serious, she was planning on having this car last a few more years.. any ideas what it could possibly be?
The car has no other noticeable problems otherwise and all appears fine on a quick glance under the hood. Any imput is welcome.
[Edited 2004-09-22 06:28:49]
Things were better when it was two guys in a dorm room.
Lono
RE: A Question For The Mechanics
Wed Sep 22, 2004 1:38 pm
sounds like a lifter may be going out... or a lifter may be sticking...
[Edited 2004-09-22 07:08:38]
Wally Bird Ruled the Skys!
dmeeky243
Wed Sep 22, 2004 1:57 pm
hate to say it, but my dad always said knocks and pings are always bad sounds. Have you checked the tranny oil? That's the first thing that comes to my mind. Is it for sure under the hood? Couldn't be a brake or anything? I'm no mechanic, but just trying to help.
"I have a favorite dish, which tends to change daily depending on my mood, or whether I have a hangover, or whether it's
CanadianNorth
Wed Sep 22, 2004 2:02 pm
Is it definetly the engine itself, or just some silly little thing coming loose and making some noise as it vibrates or something.
CanadianNorth
HS-748, just like a 747 but better!
KROC
Wed Sep 22, 2004 7:41 pm
Before you start dropping a mass amount of money to fix the problem, you might want to try dropping in a can of slick 50 or another fuel treatment product. I've had similar problems with my old car, and lots of times all it was was deposits inthe engine and such that were cleaned away with the treatment.
MxCtrlr
Wed Sep 22, 2004 8:00 pm
Not actually working on the car, I can only venture a few guesses:
1). Check the fuel filter for clogging/contamination
2). It could be a lifter tapping.
3). It could be that it needs new spark plugs (or cleaned, at least).
4). It could be a bad EGR Valve or PCV Valve (simple to check out).
MxCtrlr  Smile/happy/getting dizzy
Freight Dogs Anonymous - O.O.T.S.K.  Smokin cool
DAMN! This SUCKS! I just had to go to the next higher age bracket in my profile! :-(
cptkrell
Wed Sep 22, 2004 10:18 pm
Well, it is a bit difficult to diagnose a noise on the net, but an engine noise commonly referred to as a "ping" is usually predetonation, is usually heard under throttle load and is usually caused by lower than required octane fuel for your compression ratio and/or ignition timing. Bad fuel is easy enough to detect (might want to do the fuel filter as previously suggested), altered compression ratio by carbon buildup on the pistons is, of course, more difficult, and timing is a couple-of-minute check. If a compression check indicates build up, a range colder spark plug may cure the problem...IF that's the problem.
However, you indicated that the sound was also intermittent at lower RPMs and idle recently. This could mean an easy valve actuator ("lifter") change as Lono suggested. Or...you may have a leaking head gasket. Before you do dollars large, go to:
http://www.alldata.com/TSB/0039_mo.html
plug in the make/model of her Mitsubishi and see if there have been any recurring problems where a Technical Service Bulletin or recall has been issued for complaints similar to yours. Regards...Jack (P.S. The above address seems to be case-sensitive, so type in as I have done above).
all best; jack
CaptOveur
Wed Sep 22, 2004 10:53 pm
Thanks for the help guys, I was going to try a higher octane gas next time she fills it up and see what happens, it will probably be going in for plugs in the next week or two.
I doubt it is the head gasket, it's not smoking at all and the coolant reservoir is still full.
the lifter sounds plausible, but I will give the slick 50 a try, failing that the fuel filter probably hasn't been changed since the car was new and is probably worth a look.
SSTjumbo
Sat Sep 25, 2004 12:20 pm
Check the timing belt. Mitsubishis are maintenance hogs when it comes to engine timing. If you can't do it, have a certified mechanic check it out.
I don't know, so this is my signature.
desertjets
Sat Sep 25, 2004 12:42 pm
I will concur with what Jack mentioned. It might be a pre-detonation problem from not enough octane. Gasing it up with premium and putting in a high quality fuel additive, something like Chevron Techron Fuel System Cleaner with an octance booster, would be a good idea for the next few fill-ups to see if that clears it up. If that does the trick then you should be fine. Some engines are notoriously bad with pre-detonation. The 3S-FE 2.0l Toyota engine in the Camry and Celica was notably bad. Back when my dad sold the things they'd come back to the shop with customers complaining about pinging early on. I suppose if left unchecked it might do some damage... though how much I do not know.
BTW... I believe that engine is a 2.4 liter.
CaptOveur
Sat Sep 25, 2004 1:06 pm
"BTW... I believe that engine is a 2.4 liter."
On further examination I found you to be correct. I knew it was one step above lawn-boy but I wasn't sure exactly. I ran the higher octane fuel and that did get rid of what I was sure was the ping, that will be dealt with in a few weeks when she goes home, her dad is going to take it in for service.
I ran the car around the 1604 loop yesterday and was able to get it to make the noise again in an area where I could do a little more trouble shooting.
Now it is time to make myself look stupid (not that I wouldn't anyway), sure enough it was in fact, not an engine noise making the low RPM noise, it sounds like it is coming from the left front wheel. I know the car has a warped rotor because it does shake a little under braking. The rattle goes away when I step on the brakes so the best guess I can pull out of my ass is a brake pad or something vibrating in a particular RPM range. The car had a brake job about 30k miles ago and the way my girlfriend drives it may be coming due for another one in 10k miles.
Thank you for all the input so far.
Users browsing this forum: afcjets, Dt91c and 46 guests
