wardialer
Internet Problems In Hungary With My PC
Mon Sep 27, 2004 3:31 pm
Ok, heres the problem, the provider called Matav in Hungary (Europe) gave me this access number below
06 51 622 622
On the Internet Setup page in Windows 2000 (My Dial-up Networking), I selected from the menu Hungary (36) which is the country code, but what should I put under the Area Code and then what would be the actual number??
I tried it already as 0651 as the Area Code and the actual number as 622622 and still could not connect. The phone line gave me like an announcement that I could not connect.
The modem works fine which is an external one.
Is anyone familiar with the Hungarian access numbers??
iakobos
RE: Internet Problems In Hungary With My PC
Mon Sep 27, 2004 4:18 pm
Did you try without the 0 (which is only required for local/domestic calls) ?
707CMF
Mon Sep 27, 2004 4:19 pm
I concur - remove the 0.
UTA_flyinghigh
Mon Sep 27, 2004 4:26 pm
Or pay your ISP bill in time.
Signed,
707cmf
Fly to live, live to fly - Air France/KLM Flying Blue Platinum, BMI Diamond Club Gold, Emirates Skywards
707CMF
Mon Sep 27, 2004 4:41 pm
I sent the check yesterday.... barely 3 weeks late (1week after the second notice).
I indeed really should have a direct debit for that...
andz
Tue Sep 28, 2004 12:20 am
If you are in Hungary then the country code is not needed. If you are in a hotel check the dial out digit required (usually 0) when I was in Budapest last year I also had a local dial up number and it worked.
When I travel out of South Africa I use AT&T Global network client to get local dial ups and have never had problems, I am in Helsinki now and having no problems connecting to a local number so it is probably just the number setting. If you have to dial a digit for an outside line try the digit, comma, and a space then the number to give the modem time to get the dial tone, I have seen this cure a "number unobtainable" before. (eg: 0, 622622)
wardialer
Tue Sep 28, 2004 12:33 am
I amnot in Hungary right now, I just came back. But the PC is located in the home and not in a hotel.
Nextime I will try it without the 0.
Users browsing this forum: CPH-R, PlaneHunter, VonRichtofen and 3 guests
