747-600X
E-Geeks: A Question About Java And/or Forms...
Tue Dec 21, 2004 6:42 am
This gets me. So there's this really ugly web page with a form on it, which does a dandy job of gathering information and sending it along. Now! When the user clicks the "submit" button (please don't everybody do it - I know the guy who has to read these submissions and he'll surely shoot on site) it goes to "thanks.htm" - but if you go to VIEW > CODE for the first page, no where on there does it say anything about "thanks.htm".
So the question is - how does it know to go to thanks.htm?, what if I wanted to make it go somewhere else (like, for example, a PDF file)?
Thanks to any contributors!
747-600X
RE: E-Geeks: A Question About Java And/or Forms...
Tue Dec 21, 2004 6:43 am
Oh, the reason I mention Java is because I was under the impression that had something to do with it.
Qb001
Tue Dec 21, 2004 6:46 am
When you click the Submit button, it triggers a call to a function nammed "return validate_form()" on the server. The redirection to the "thanks.htm" is done within that function, on the server side.
Never let the facts get in the way of a good theory.
Klaus
Tue Dec 21, 2004 7:43 am
Actually, the target page of a form is specified in the
element that opens the form in the HTML code.
In this case:
<form action="formpost.asp" method="POST" name="F1" language="JavaScript">
The emphasized parameter specifies that on submission of the form the browser will post the form data to the page formpost.asp. The code generating that page on the server (from the extension I suspect it´s a Windows server running "active server pages") will then process the form data and generate the confirmation page accordingly.
validate_form() is actually a JavaScript function which is not executed by the server (you won´t see any code in your browser in that case) but by the browser itself (that´s why you can see the code in the page source code). Something like that is often used to make a first local plausibility check on the browser side before bothering the server with an inconsistent reply. If it returns false, the follow-up page is not loaded (the form is not submitted) and the user has another chance to correct his input.
By the way: JavaScript has nothing to do with Java; The name JavaScript was merely chosen for marketing purposes. JavaScript is a browser-executed script language, Java is a portable compiled language usually employed for separate Applets or on the server side (not in this case, apparently).
And just for the record: JavaScript is entirely optional and in no way required for an HTML form or any other page. Pages should be constructed in a way that they will still work without JavaScript if at all possible. Since JavaScript is still somwhat browser-dependent, results will usually vary anyway, so it´s generally bad style to require the client to have it enabled.
Some browsers (hint! hint!) even have critical vulnerabilities in their JavaScript implementations, so forcing anyone to enable it is a safety issue as well.
In this case, the form should still work with JavaScript disabled; It just wouldn´t have that convenient plausibility-check.
[Edited 2004-12-20 23:56:31]
Users browsing this forum: aerlingus747, Aesma, davideham, FGITD, L410Turbolet, pvjin and 2 guests
