Riley
How Fast Is A T1 Line?
Mon Jan 10, 2005 2:46 pm
Well I never thought broadband cable would come to this. Been having BIG TIME speed issues with my connection and my ISP is unable to solve the problem. I'm running at about 1.4mb per second and due to time constraints and workload it's just not fast enough anymore. I was getting around 2.5mb per sec up to around Jan 1 and then it just backed off. My ISP has agreed to cut my monthly fee by $10 but that's not solving the problem. Now I'm thinking about having a T1 connection installed but want to do my homework first. What can I expect as far as speed and are there any other issues I need to be prepared for before I make the plunge?
RyanU
174thfwff
RE: How Fast Is A T1 Line?
Mon Jan 10, 2005 3:00 pm
T1 is like $300 per month at least. Have you tried to switch providers or anything? I'd try something less drastic first, as that's not exactly chump change.
-174th
Brooklyn, Queens, Manhattan, Staten, Uptown, what now? Lets make it happen.
ordflyer
Mon Jan 10, 2005 3:20 pm
I don't have any firm numbers, but T1 is obviously very fast but also veerrry expensive. I though I've read that they were at least $1,000 per month but I could be mistaken. I've never heard of a private residence having a T1 connection, usually its schools and companies. Have you tried DSL? I would try and exhaust all less expensive possibilities before considering T1, unless you have the cash to throw around in which case go for it!
[Edited 2005-01-10 07:28:39]
Ralgha
Mon Jan 10, 2005 4:03 pm
$600-$1000/mo depending on things. However, be aware that a T-1 is only 1.5 Mbps.
iakobos
Mon Jan 10, 2005 5:26 pm
T1 is the basic standard for leased line capacity. (guaranteed capacity !)
The "pipe" is 1.544Mb (up to 24 x 64Mb channels).
US prices vary from 500-550 to 1,200$+/month.
An ISP cannot and will not guarantee capacity, it all depends on how much capacity they have themselves to the internet backbone, and the secret in the business is to have the higher number of clients downstream and paying the least possible costs (leased lines) upstream, a headache when it comes to caring about the Quality Of Service.
If you already got 1.4Mb, a T1 is no solution. The step higher is a T3 (up to 45Mb of guaranteed capacity) but then you multiply the monthly rental by a factor 10....
My suggestion is to sit with your ISP and have a honest discussion.
hawaiian717
Tue Jan 11, 2005 10:24 am
As others have mentioned, a T-1 is 1.5Mbps. The difference is that this is symmetric; you get this speed both upstream and downstream. With most DSL service, you can get that downstream, but the upstream is usually slower (I've seen it as low as 128Kbps).
David / MRY
Users browsing this forum: No registered users and 46 guests
