Aviation
A Good Web Editor
Thu Jan 20, 2005 5:52 pm
Hi,
Does anyone know of a good web editor to make a site like a.net like what would they use to do a.net help anyone
Aaron J Nicoli
Signed, Aaron Nicoli - Trans World Airlines Collector
saxdiva
RE: A Good Web Editor
Thu Jan 20, 2005 6:06 pm
Um, I don't think it's that easy.
I seem to recall that a.net's photo database is SQL-based and runs on multiple servers. The forums look a lot like some of the PHP (that's a scripting language) systems I've seen around. Generally they use HTML templates, but I think the vast majority of the site content is dynamically generated.
Put simply, that means there is no web editor that's going to build you a site like a.net--you'd need to learn about database design and management, and--at the very least--need to learn how to install, configure, and run the scripts that make up the forums. To do that, it generally helps to know a little about web server administration and what to do when something doesn't work quite as expected (which is most of the time).
-Leanne
qr332
Thu Jan 20, 2005 6:19 pm
If you have the knowledge, you can use programs such as Dreamweaver MX along with PHP, etc to make a site like A.Net. But, as Saxdiva said, if you do not have strong knowledge of scripting, etc it is very difficult to build a site.
Basically, you can make something simpler using this program, which IMO is the best out there:
http://www.macromedia.com/software/dreamweaver/
There is a trial if you want to try it out.
"The greatest threat to knowledge is not ignorance, it is the illusion of knowledge."
theCoz
Fri Jan 21, 2005 1:36 pm
I've been the webmaster for a university for 3 years. Check out
http://www.uat.edu
http://www.chromosphere.com <-- all coded by hand  Smile
contact me with your questions, maybe I can help answer them.
Users browsing this forum: NSMike and 2 guests
