777ER
Crew
'Lost' TV Show, Which Plane?
Wed Feb 02, 2005 6:37 pm
Just watched the first screening in New Zealand of 'Lost'. For the whole two hours of watching it, I was wondering what aircraft is that. Does anyone know what aircraft it was?
[Edited 2005-02-02 10:38:09]
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
NZ747
RE: 'Lost' TV Show, Which Plane?
Wed Feb 02, 2005 7:01 pm
I was wondering about that myself. At first I thought it was a 747, as when they got to the front of the fuselage in the jungle, it looked like it had a slight hump, but in the 'inside scene' the flight deck was on the same level as the passenger deck. I think it may be a Tristar, and it is easy to get one from the scrap yard.
aerorobnz
Wed Feb 02, 2005 7:10 pm
It was either a Tristar or DC10 I think. I thought it was a DC10 for some reason. In actual fact i think it was a hodgepodge of spare parts from a whole lot of aircraft.
Flown to 126 Airports in 47 Countries on 80 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
NZ747
Wed Feb 02, 2005 7:20 pm
Actually Rob, I think you may be right it did look more like a DC10. During the start when Jack asked the fat guy to stay with the pregnant woman. Then saw that the tail was going to fall, so quickly ran over to get them to run. The falling tail did look more of that from a DC10. It didn't have the bulk that the Tristar has.
777ER
Crew
Wed Feb 02, 2005 7:42 pm
I don't think it was the tail because while in the air the rear fuslage was ripped off. It must have been the wing that fell cause the engine blew up after
Titch
Wed Feb 02, 2005 7:48 pm
Guys,
If it's the same show that was broadcast in the USA sometime last year, then the aircraft was N783DL, an ex-Delta TriStar.
There was a whole thread devoted to this subject back in September last year. See http://www.airliners.net/discussions/general_aviation/read.main/1752450
If you're interested, there's also some pictures and info on how the aircraft was scrapped and shipped out to Hawaii for the filming at http://www.mojavebooks.com/mhv/040922-1.html
Hope this helps.
Titch
I'll make weapons out of my imperfections
aerorobnz
Wed Feb 02, 2005 8:08 pm
actually I subconsciously noted that it looked like the Delta Livery, but for some reason i didn't put two & two together until I saw titch's post.
corocks
Thu Feb 03, 2005 7:49 am
Does anybody know what kind of access there is to the filming location? I Know that it is on the North Shore of Oahu. Can you go out there, or is it blocked off and you can't even see it.
I will be out there next month and was kind of curious.
777ER
Crew
Fri Feb 04, 2005 6:05 pm
Titch
Yes its the same show that was broadcasted in the USA last year.
bill142
Fri Feb 04, 2005 7:22 pm
Can the engine still operate like it was even after a crash?
777ER
Crew
Fri Feb 04, 2005 8:00 pm
Bill142, highly unlikly.
bill142
Sat Feb 05, 2005 6:59 pm
777ER, thats what I thought.
777ER
Crew
Sun Feb 06, 2005 7:36 am
Bill142
With the force of the impact, the engines will either rip apart or explode.
NZ747
Sun Feb 06, 2005 8:27 am
and so would all the people.
ClassicLover
Sun Feb 06, 2005 2:33 pm
Well, the engines on N736PA were running at the time that the KLM plane hit them. The pilots couldn't shut them off because the entire roof (where the cut off switches are) was removed from the cabin.
I was reading an account of it (I think from Dorothy Kelly) and they had to move people away from the engines as they were still running. As they were laying on the ground, the cowlings were distorted and they began to throw out bits of metal and catch fire.
Pretty similar to what happened in Lost.
So yes, it can happen, and has happened - though in the Lost case, considering the plane fell from a great height, it shouldn't have been possible.
Trent.
Users browsing this forum: Flaps and 1 guest
