Rj111
What Battleship Are You? LOL!
Wed Feb 23, 2005 3:22 am
Fill in the question form and find out!
http://quizilla.com/users/TJHairball/quizzes/Battleship%20Quiz
Hint: There's a handy box which you can copy and paste the exact HTML code into your reply.
Me......
Richelieu class (Richelieu, Jean Bart)
Elegant, distinctive, innovative, and excellent.
The premier french battleship, and one of very
few battleships actually built that respected
the 35,000 ton displacement limitation set
forth in the Washington Treaty.
The Richelieu sported numerous unique
systems, such as foil-skinned bouyant foam
capsules to prevent taking on too much water
from torpedo hits, excellent void and and water
filled torpedo blisters, exceptionally well
designed armor, some of the best (and longest
range) 15 inch guns ever built with a unique
loading system. Although it started life with a
relatively weak anti-aircraft system on par
with the Vittorio Veneto, it was refitted by
the Allies during its rather eventful history
to carry a much heavier anti-aircraft suite.
This class was retired in the 1950s-1960s, with
the
Richelieu being finally scrapped in
1970.
2x4 15/45
9 6/55
12 3.9/45
12 37mm (pre-refit #1)
24 13.2mm (pre-refit #1)
56 40mm (post-refit #1)
48 20mm (post-refit #2)
28 57mm (Jean Bart, post-war)
20 20mm (Jean Bart, post-war)
ANCFlyer
RE: What Battleship Are You? LOL!
Wed Feb 23, 2005 3:31 am
YAMA YAMA
Yamato class (IJN Yamato)
With a main armament consisting of nine 18.1/45
guns, the heaviest displacement of any
battleship ever built, the Yamato is the
monster of the battleship world. More armor,
heavier weapons, and superior optics made this
battleship something nobody else wanted to get
close to. In the end, torpedos and bombers
proved its end as aircraft carriers supplanted
battleships as the kings of the sea. Few
warships of today outmass it, and none have
ever carried bigger guns or heavier armor. The
Yamato was overawing beyond any doubt.
The third planned Yamato class battleship
was actually completed as an aircraft carrier.
Battleship Quiz
brought to you by Quizilla
tristarenvy
Wed Feb 23, 2005 3:32 am
Hot Damn!!!
Pride and joy of Nazi Germany. (Bismarck and
Tirpitz)
A legendary ship that sank the famous HMS Hood, and
the most powerful German warship ever built. A
crew topping 2000 men, full displacement just
past 50,000 tons, and four paired 15 inch guns
laid out a flexible and potent warship,
potentially a match for just about any other
warship in the North Sea. Unfortunately, in
spite of good German optics and impressive
statistics, the Bismark ended up getting
toasted. Poorly supported by a relatively weak
German navy, it also suffered from poor radar,
bad fire control, and poor deck protection from
long ranged fire. The Bismarck was designed
with an eye towards the Baltic battles of WWI,
and would have done very well in that
situation.
50,932 tons
30 knots
4x2 15/47
12 5.9/55
16 4.1/45
16 37mm
78 20mm
Battleship Quiz
If you don't stand for SOMETHING, you'll fall for ANYTHING.
aviationmaster
Wed Feb 23, 2005 3:35 am
I'm a:
Richelieu
Bart
the Richelieu being finally scrapped in
1970.
2x4 15/45
9 6/55
12 3.9/45
Battleship Quiz
Who comes up with this stuff... Laugh out loud
tristarenvy
Wed Feb 23, 2005 3:38 am
Interesting that two folks have been the same. I'd like to know what the parameters are for selection...
dl021
Wed Feb 23, 2005 4:08 am
Without taking the test I'd opt to be the USS Wisconsin. Its the only battleship left in reserve that's in condition to be returned to active service (albeit with the necessity of stripping the other Iowa class vessels on display and in MARAD custody) and represents the pinnacle of battleship power.
It was the fastest and most powerful battleship ever to float (counting the guns, missile systems and protection offered) and is the image of what an effective battlewagon could be.
I personally saw her rounds landing and witnessed their effect from a range of 12 or so klicks. It is extremely impressive. Evidently the enemy tried to surrender to the UAV providing FAC for the 16" rifles after they were hit.
That said, if I had the choice I'd still prefer to have one of the converted SSGN's as my main force projector....not as traditional but more effective and less vulnerable.
Full broadsides in action. Firing high explosive shells the size of Volkswagens on Iraqi targets in Kuwait.
During her last commissioned year.
A sight never to be again seen. All 4 of the class sailing together.
[Edited 2005-02-22 20:35:55]
Is my Pan Am ticket to the moon still good?
EA CO AS
Wed Feb 23, 2005 4:10 am
Gangut The Gangut class was the largest native class of battleship actually used by the USSR in WWII. They also served in WWI, but underwent extensive upgrades and modification over the years. With four triple 12 inch guns, the Gangut carried light firepower but potentially the highest overall rate of fire of any battleship in terms of heavy shells per minute. A WWI workhorse, the Gangut class was re-used throughout WWII, providing surface bombardment to support the Soviet advance through Germany; although a heavier battleship class, the Sovietski Soyuz, was under construction as WWII opened up, it was never brought into action, leaving the Gangut the largest Soviet battleship on record.
I can't tell if this is good or bad - I'm assuming bad...or at very least, not so good...
EDIT -
Ok, so when I changed two of the answers I was "on the fence" about, here's what I ended up with:
Yamato class (IJN Yamato) With a main armament consisting of nine 18.1/45 guns, the heaviest displacement of any battleship ever built, the Yamato is the monster of the battleship world. More armor, heavier weapons, and superior optics made this battleship something nobody else wanted to get close to. In the end, torpedos and bombers proved its end as aircraft carriers supplanted battleships as the kings of the sea. Few warships of today outmass it, and none have ever carried bigger guns or heavier armor. The Yamato was overawing beyond any doubt. The third planned Yamato class battleship was actually completed as an aircraft carrier.
Now THAT'S more like it!   Big thumbs up
[Edited 2005-02-22 20:19:02]
KROC
Wed Feb 23, 2005 4:15 am
motext
Iowa class.
Battleship Quiz
tristarenvy
Wed Feb 23, 2005 4:19 am
Interesting. I never knew the Soviets even fielded a battleship in WWII. Put some cage masts on that Gangut and it's almost got a look like the USS Mississippi.
gkirk
Wed Feb 23, 2005 4:21 am
motext
Iowa class.
Battleship Quiz
dl021
Wed Feb 23, 2005 4:23 am
Well, the test says I am a Yamato class Battleship, which ain't bad. Except they were on the losing side.
That said, I did watch every episode of Star Blazers and can appreciate what a fine piece of equipment that class of vessel was.  Big grin
[Edited 2005-02-22 20:38:07]
garnetpalmetto
Wed Feb 23, 2005 4:35 am
motext
Iowa class.
Battleship Quiz
I think I can live with being an Iowa.
Pretty bad, EA CO AS. The Ganguts were pretty much obsolete before they were completed and were more of a cross between a battleship and a battlecruiser than a true battleship. They WERE extensively modified, but pretty much fell into disrepair soon after refits and were used as little more than floating batteries by the Soviet Navy. There were four hulls built - Gangut, Petropavlovsk, Poltava, and Sevastopol. All except Sevastopol, which served in the Black Sea, served in the Baltic, The Russians also built two improved variant-classes, the Imperatritsa Mariya-class and the Imperator Nikolai I-class, but all units of these classes were scrapped before World War II.
[Edited 2005-02-22 20:47:22]
South Carolina - too small to be its own country, too big to be a mental asylum.
SATL382G
Wed Feb 23, 2005 4:41 am
YAMA YAMA
Battleship Quiz
I'll have to steer clear of SBD & TBM/TBFs I guess...
ANCFlyer
Wed Feb 23, 2005 5:09 am
SATL382G, DL021, ANCFlyer - all Yamato Class . . . is there a trend here?
Ian, some of your photos in reply #5 didn't make it.
dl021
Wed Feb 23, 2005 5:15 am
Smaj....I think it might say something for knowing that brute force and ignorance prevail when sophistication and persuasion fail. You can worry about being pretty, or fast, or easy to work on, but if you're interested in winning, you gotta swing the big lumber faster, longer and better than your opponent can pitch.
There should be 5 photos. I'm getting them all here. Which ones did not appear?
Ian
aa61hvy
Wed Feb 23, 2005 5:16 am
Yamato class.
If you have an opinion on a topic, you should in detail express why you have the opinion and what made you come to that conclusion.
Go big or go home
ANCFlyer
Wed Feb 23, 2005 5:17 am
DL021, the last three: The two of Wisconsin during her last year and the one of all four together.
I agree, walk softly but carry a BIG damn stick and don't be afraid to use it. Nice guys finish last -always.
[Edited 2005-02-22 21:21:59]
LY744
Wed Feb 23, 2005 5:18 am
YAMA YAMA
Battleship Quiz
 Big thumbs up
LY744.
Jaspike
Wed Feb 23, 2005 5:25 am
motext
Iowa class.
Battleship Quiz
Tom
KiwiNanday
Wed Feb 23, 2005 5:49 am
I'm an Iowa too.... damn! I was hoping for the Graf Spee Big grin:D:D
Silly Islamic extremists, it's just a cartoon!
Catatonic
Wed Feb 23, 2005 5:52 am
venetio vittorio class
Vittorio Veneto class. (Vittorio Veneto, Roma,
Littorio.
The Italian battleship of WWII. Powerful and
relatively nimble at 30 knots, it was
nonetheless not quite as heavily armored and
turned out to be poorly protected against
torpedo attacks in spite of a combination of
interesting but largely ineffectual
innovations. Still a formidable foe, but in the
end more impressive in looks than any other
category. Although mounting three triple
turrets with unusually powerful 15/50 guns -
which had a very short barrel lifespan - the
Vittorio had a short operating radius and one
of the weakest anti-aircraft suites of any
battleship built after 1930. Although it was
officially intended to stay within the treaty
limit of 35,000 tons, it is generally
considered to have gone well beyond that.
Battleship Quiz
Equally Cursed and Blessed.
garnetpalmetto
Wed Feb 23, 2005 5:58 am
Kiwi - Graf Spee wasn't a true battleship. Although the Kriegsmarine classified her as a pocket battleship, Graf Spee and her sister Deutschland-class ships were more like light cruisers with a heavier armament, which is why a good many contemporary naval historians class them as "raiding cruisers."
wietse
Wed Feb 23, 2005 6:02 am
Richelieu
Bart
1970.
2x4 15/45
9 6/55
12 3.9/45
Battleship Quiz
Wietse de Graaf
futureualpilot
Wed Feb 23, 2005 6:04 am
Life is better when you surf.
CPH-R
Wed Feb 23, 2005 6:06 am
Wth...
Bismark
The Bismarck.
Pride and joy of Nazi Germany. (Bismarck and Tirpitz)
A legendary ship that sank the famous HMS Hood, and the most powerful German warship ever built. A crew topping 2000 men, full displacement just past 50,000 tons, and four paired 15 inch guns laid out a flexible and potent warship, potentially a match for just about any other warship in the North Sea. Unfortunately, in spite of good German optics and impressive statistics, the Bismark ended up getting toasted. Poorly supported by a relatively weak German navy, it also suffered from poor radar, bad fire control, and poor deck protection from long ranged fire. The Bismarck was designed with an eye towards the Baltic battles of WWI, and would have done very well in that situation.
Airplanepics
Wed Feb 23, 2005 6:10 am
motext
Iowa class.
Why are all the crew 'Lowa' class boats? Isnt that telling you all something?  Big grin
Simon - London-Aviation.com
KiwiNanday
Wed Feb 23, 2005 6:15 am
Quoting Airplanepics (reply 25):
Yeh, That you should make me crew!
Airplanepics
Wed Feb 23, 2005 6:22 am
Quoting KiwiNanday (reply 26):
There are somethings I aim to do in life, and your suggestion Kiwi..is not one of them  Smile/happy/getting dizzy
Scorpio
Wed Feb 23, 2005 6:23 am
KGV
Battleship Quiz
Thom@s
Wed Feb 23, 2005 6:00 pm
http://live.quizilla.com/user_images/T/TJHairball/1089185412_gvplustext.JPG
Nice...  Big thumbs up
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
JGPH1A
Wed Feb 23, 2005 7:12 pm
YAMA YAMA
Battleship Quiz
Tora tora tora !!
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
MYT332
Wed Feb 23, 2005 7:29 pm
Banana Boat
Battleship Quiz
Signed
Gkirk
[Edited 2005-02-23 11:30:27]
One Life, Live it.
Springbok747
Wed Feb 23, 2005 7:34 pm
YAMA YAMA
Nice  Big thumbs up
אני תומך בישראל
HeyMach
Wed Feb 23, 2005 7:35 pm
Riotext
Rio de Janeiro
Battleship Quiz
bully707
Wed Feb 23, 2005 8:51 pm
That's what I thought....  Big grin
Bismark
The Bismarck.
Tirpitz)
situation.
50,932 tons
30 knots
4x2 15/47
12 5.9/55
16 4.1/45
16 37mm
78 20mm
Battleship Quiz
"That's the good thing about the 707...it can do anything, but read!" Joe Patroni, Airport '70
KROC
Wed Feb 23, 2005 9:17 pm
I'm a Q-Beck Class Battleship. Pride of the Canadian Navy
Signed, LHMark
Gman94
Wed Feb 23, 2005 9:55 pm
KGV
Battleship Quiz
A good honest British battleship, Rule Britannia. Big grin
British Airways - The Way To Fly
Boeing4ever
Thu Feb 24, 2005 1:32 am
Personally, I'd have preferred to be the Bismark or Prince of Wales, but hey, this ain't bad. Historical note...the third ship of this class was completed as the aircraft carrier Shinano which was sunk by the submarine USS Archer-Fish in late 1944.
YAMA YAMA
Battleship Quiz
B4e-Forever New Frontiers
KiwiNanday
Thu Feb 24, 2005 3:00 am
Quoting Boeing4ever (reply 37):
This was the heaviest single ship sunk in the war.
Cadet985
Thu Feb 24, 2005 3:14 am
motext
Iowa class.
Battleship Quiz
srbmod
Thu Feb 24, 2005 3:24 am
USS Texas
You are the USS Texas.
You are the flagship for today's Third Texas Navy
and a museum piece linked with the pride of
Texas. Built by the US navy with ten 14 inch
guns, you're a symbol of Texan pride with a
proud history in combat. World War I was really
more your speed, though.
As far as warships go, though, you don't measure up
very well to the more modern battleships,
lacking sorely in armor and speed.
Nevertheless, a proud history lies behind you.
Battleship Quiz
TWAMD-80
Thu Feb 24, 2005 5:17 am
Not a bad result in my opinion:
KGV
Battleship Quiz
TW
Two A-4's, left ten o'clock level continue left turn!
AFC_Ajax00
Fri Feb 25, 2005 12:49 am
Pretty Cool!
Once you have tasted flight, you will walk the earth with your eyes turned skyward; for there you long to return
57AZ
Fri Feb 25, 2005 6:41 pm
YAMA YAMA
Battleship Quiz
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
mas a330
Sun Feb 27, 2005 11:14 pm
KGV
Battleship Quiz
PacificWestern
Sun Feb 27, 2005 11:27 pm
YAMA YAMA
Battleship Quiz
LH526
Crew
Sun Feb 27, 2005 11:38 pm
Richelieu
Bart
1970.
2x4 15/45
9 6/55
12 3.9/45
Battleship Quiz
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
qr332
Sun Feb 27, 2005 11:54 pm
Gangut Class
Gangut
Battleship Quiz
"The greatest threat to knowledge is not ignorance, it is the illusion of knowledge."
CORULEZ05
Mon Feb 28, 2005 12:04 am
motext
Iowa class.
Battleship Quiz
Very COOL!.......btw, I would like to know who said Mexican to the question about people you despise (don't like).....GRRRR!!!
Fly jetBlue today!!!!!!!
Users browsing this forum: Airstud, LittleFokker, ltbewr and 1 guest
