airxliban
OpAmp Electrical Engr/Electrophysics Help
Mon Mar 07, 2005 12:48 pm
Could someone kindly explain the following (and I realize this may be obscenely obvious for some):
What is A_0OL, the dc open-loop gain of the amplifier...what does that mean?
What do open-loop and closed-loop refer to?
sprout5199
RE: OpAmp Electrical Engr/Electrophysics Help
Mon Mar 07, 2005 1:24 pm
IIRC this has to do with neg. feedback to keep the amp. linear.(been a long time since I have used any theory)
Dan in Jupiter
airxliban
Tue Mar 08, 2005 4:07 am
what does IIRC mean again?
Klaus
Tue Mar 08, 2005 4:12 am
I´m not a specialist for analog electronics, but as far as I understand the "open loop gain" should be the direct amplification factor without any positive (higher gain) or negative feedback (lower gain) in the "closed loop" case.
iakobos
Tue Mar 08, 2005 4:44 am
Open loop: no load, theoritical gain of a circuit (all by itself).
Klaus
Tue Mar 08, 2005 5:43 am
No, it seems this Tutorial agrees with my assumption:
By introducing negative feedback around an op-amp we can control the gain of an amplifier circuit. The resulting gain is called the closed loop gain
gkirk
Tue Mar 08, 2005 6:54 am
I'll reply with a proper answer when I can find my Physics books  Wink
Users browsing this forum: BobPatterson, OzarkD9S and 63 guests
