L.1011
Advice On Efficient HD Use
Sun Mar 27, 2005 11:43 am
I have a hard drive space situation. I have two hard drives, C is 16GB and D is 58.5GB. The strange thing is, whenever I download some program that gives me information about my computer physically, it states I have one 80GB HD. I have found little purpose for cracking my case open, except to install a new video card (went from a SiS 650 integrated chip (thanks computer-clueless parents) to a 256MB nVidia) at which point I didn't even think of checking out the hard drive situation. So I question whether there is just a partition on it that I could boot off, or if it really is two drives. Could they be a master and slave?
Anyway, I wouldn't even care if I wasn't running low on space on C. C has just 435MB of free space, which I am not happy with because I can't defrag it properly nor do I have breathing room to install anything else large. D has 56.6GB of free space (it is completely empty but for Grand Theft Auto 2 (I know I'm out of date, but it's free at their website!)). If I do in fact have two physical drives, what should I move? I have a 2.4GHz P4 and 512MB of RAM, so I don't think this will be too time consuming, but the fragmented C drive is definitely damaging system performance. PC Pitstop affirms this. I am rather concerned that shifting files to my D drive will screw up filepaths, and I'd like to avoid that inconvenience as much as possible.
The breakdown of space usage on C is as follows:
Documents & Settings: 3.7GB
HJT (HijackThis): 256KB
nVidia: 18.6MB
Program Files: 7.11GB, around half of which is FS2004
ucd: (I question what this is, it doesn't look important, but there is an MS-DOS icon in it, which makes me hesitant): 1.06MB
WINDOWS: 2.5GB
1.3GB of Documents and Settings comes from my music collection, which is centrally located and could be easily moved.
As for programs, here are the big players
Flight Simulator 2004: 3.281GB + 799MB of downloaded freeware components
Midtown Madness 2: 389MB + 130MB of downloaded freeware
MS Office Pro 2003: 414MB
Risk 2: 312MB
MS Links LS 2000: 307MB
Java Runtime Environment: 130MB (was it actually nessecary for me to download this, for java on the internet)
Photoshop Elements 2: 95MB
Bearshare: 88MB
Adobe Reader 7: 62MB
WindowBlinds: 52MB
Anyway, my question is: what should I move? Advice is appreciated.
jfkaua
RE: Advice On Efficient HD Use
Sun Mar 27, 2005 1:59 pm
how do they show up in explorer? as one or two?
Go3Team
Sun Mar 27, 2005 2:28 pm
80GB these days are not enough. In my main computer I have the following:
(2) 250GB 1 @ 99% and the other at 50%
(1) 200GB in 100GB partitions - both partitions at around 90%
(2) 80GB both at abt 75%
(1) 40GB at around 40%
Trying to remember where files are can be a pain in the ass sometimes, but having a terabyte of data capacity, I still need a lot more. I have one more slot on a controller card, so I guess I have to get a 400.
What I would do in your situation - don't move anything. Your registry and operating system know where everything is. If you move it, the operating system will not know where it is. Here is what I would do:
Buy a 120 gig harddrive, and set it as master. Do a clean install of your preferred OS, and install the current drive as a slave, that way you still have all your data..
If you don't want to have to reinstall everything, you can clone your smaller drive onto larger drive without having to go thru much pain.
If you need any more help let me know.
Yay Pudding!
L.1011
Mon Mar 28, 2005 12:43 am
Quoting Jfkaua (Reply 1):
They show up as two drives
Quoting Go3Team (Reply 2):
I'm very happy with 80GB thanks. As you can see from my numbers, I'm not close to using the entire setup.
If I do it in Explorer? If that's the case, that's news to me.
dan2002
Mon Mar 28, 2005 1:08 am
You could do what I do and run a RAID array. Basically what that does is combine both drives so they show up as one. Very handy, I have and array that combines my 10GB and my 20GB so it shows up as a 30GB in windows, and I combined my 120GB and 40GB so it shows as a 160GB. But I would take Burke's advice here and get another HD, they arent that expensive, most under 100$ these days.
-Dan
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
nighthawk
Mon Mar 28, 2005 1:26 am
if software is saying you have an 80gb HD, then you probably have a single disk split into two partitions. The best solution would be to simply merge the two partitions so you have a single 80GB disk. Windows XP should do it by itself, otherwise use "Partition Magic" to merge them.
Other than that i would recommend moving some data onto your second partition. Moving your MP3 collection would be a great start, as there will be no links for them oher than in your playlist, which can easily be set up again. That will leave enough space to defrag. From then on install any new games onto the second partition.
Another option might be to uninstall FS9 and reinstall on the second partition.
BTW L1011 what the hell are you storing to use up 1 terrabyte of data? You must have a pretty large film collection on there..?
Go3Team
Mon Mar 28, 2005 1:28 am
Quoting L.1011 (Reply 3):
These programs will give you problems if you move them. They all make notations in the registry, and editing the registry can be a scary thing.
Midtown Madness 2
MS Office Pro 2003
MS Links LS 2000
Adobe Reader 7
WindowBlinds
As for the other programs, I don't know anything about them, so they could also be the same way.
Another way to do things, would be to uninstall the above programs, and install them again. When it asks you for a location to install, it will probably say something like c:program filesbla bla, you just change the c to a d.
Yay Pudding!
L.1011
Mon Mar 28, 2005 4:40 am
Alright, my Device Manager shows it as one drive, so I should just be able to drop the partition and use them as one drive, right?
Go3Team
Mon Mar 28, 2005 5:38 am
Dropping partition = losing everything.
Yay Pudding!
L.1011
Mon Mar 28, 2005 10:05 am
Well, I could move what is currently on my D partition to my C partition, temporarily, and then drop the D partition, giving me a single 80GB C drive, could I not?
aloges
Mon Mar 28, 2005 10:09 am
Don't you dare doing anything without BACKING UP your important stuff on a device that is physically separated from your PC!!
Edit: That being said, I'll go ahead and try adding my  twocents :
Quoting L.1011 (Reply 9):
I assume you got the letter wrong, right? If your C partition is already full, you can't really copy anything from D to it, can you? If you can because it's not that full yet, forget what I said; your idea should work in case the software you have supports that kind of stunt. But again: BACK UP your stuff before you touch anything.
[Edited 2005-03-28 02:15:18]
L.1011
Mon Mar 28, 2005 11:12 am
Well, Aloges, the drive isn't full to the brim, I think with a little bit of creativity I could cram the little bit that's on D onto the C. Should I look at picking up an Iomega Rev drive and backing up all of C? I also have another question. Why the hell would Sony or Seagate have put the partition on in the first place? What possible benefit does it serve?
aloges
Mon Mar 28, 2005 11:22 am
Well, there's a heap of gadgets you can use to backup your files. I'd recommend a LAN, but that depends on availability, of course. If you want the highest security you can get, have someone who knows what he's doing connect your HDD to his computer and copy everything from your drive to his. It's relatively easy and cheap and your drive can do whatever it wants without making you lose anything important.
As for the partitions, many distributors advertise that one (usually the smallest) partition is for the OS and other system software while others can be used for office software, games and all kinds of files - how that is supposed to be better than just separate folders is beyond me. Sure, you can easily format one of those partitions, but you can just as well perma-delete files using software that overwrites them with senseless data several times.
L.1011
Mon Mar 28, 2005 12:15 pm
Considering that I already experienced two catastrophic computer crashes that are even within my memory (we already had a dinosaur 25MHz NEC when I was born), I was thinking about a REV drive anyway. Might that be a good idea? Especially considering that there are some files that I wouldn't really appreciate a data recovery guy viewing.
aloges
Mon Mar 28, 2005 8:11 pm
Tsk, tsk, tsk, L.1011...  Silly
I can't exactly give you advice on that REV drive, but I can say that I wouldn't spend any money on a drive that I'd use only a few times, there are cheaper ways. You could copy those very personal files (and maybe your email inbox & outbox, too) to a USB memory stick or some other low-cost storage device you may already have and then ask someone you can trust if he can help you.
You see, I don't want you to spend any money on drives or services you don't need. Usually, opening a PC case doesn't void any warranties and it can save you the money you'd spend on an external backup drive. If a friend who knows what he's doing agrees on copying all your files (minus the personal ones you should have backed up and deleted from the HDD by then  Wink ) to his HDD, you'll be able to back up everything for exactly zero dollars.
L.1011
Tue Mar 29, 2005 5:54 am
Well that's the thing. I intend to use it more than a few times. I'll have to look into it more. Time to unlock my inner salesman to deal with my dad. Thanks for your help Aloges.
Users browsing this forum: Bing [Bot], LMP737, NeBaNi and 1 guest
