jfkaua
Math S.A.T. Question.
Sat Apr 02, 2005 2:46 pm
Hey can anyone tell me how to solve this problem. I tried to recreate it best as possible.. Just couldnt make the pi sign so i just wrote pi...
DfwRevolution
RE: Math S.A.T. Question.
Sat Apr 02, 2005 3:12 pm
E... they will never intersect
Very simple solution:
The radius is 4, so the full area of the circle is (4^2)(Pi) = 50.26
Now find the area of (4)(pi) = 12.56
This means that 4(pi) is exactly 25% of the circle, thus, the angle from BA to AD is a 90 degree angle.
If line BC is tangiental to point B, and AD is perpendicular BA... AD and BC are parallel.
Never overanaylize SAT math... look for easy solutions, don't work the problem. Pick the answer you think is right and work it backwards. That's how I worked this one... took me about 15 seconds once I grabbed by TI-83
[Edited 2005-04-02 07:15:51]
jfkaua
Sat Apr 02, 2005 3:18 pm
no the answer is (D).. just trying to figure out why. E is actually the first I eliminated because since the diagram is not drawn to scale the line could tangent the circle at any angle..
[Edited 2005-04-02 07:21:56]
jfkaua
Sat Apr 02, 2005 3:20 pm
hmmm your answer does seem to be logical.. any idea how it could be d?
jhooper
Sat Apr 02, 2005 3:22 pm
Hmmmm.......I'm no math expert by any stretch of the imagination, but I'd say the lines won't intersect (E).
This is because we know the area of the entire circle is pi X r X r, or 16(pi). Divide that by 4 and you get 4(pi). Therefore, we know the shaded area represents 90 degrees of the circle (even though the figure isn't "drawn to scale"). Since that's true, AB and AD make a right angle and therefore the lines won't intersect.
Am I smoking crack here or does my logic work?
Last year 1,944 New Yorkers saw something and said something.
jfkaua
ooppss i read the answer key wrong!! you were absolutley right..
DfwRevolution
Sat Apr 02, 2005 3:24 pm
Quoting Jfkaua (Reply 2):
E is actually the first you can eliminate because since the diagram is not drawn to scale the line could tangent the circle at any angle
If Angle-BAD is perpendicular, BA is tangental, then segment AD will always be parallel. If the solution manual says D then I will shut-up and let someone else have a go... I can't see any other solution than E
jfkaua
Sat Apr 02, 2005 3:26 pm
yep E is certainly correct.. I have 2 more ?'s that I got wrong on the math portion.. I'll post them tommorow as I am do lazy to make the question up now..
Mir
Sat Apr 02, 2005 3:27 pm
E is actually the first you can eliminate because since the diagram is not drawn to scale the line could tangent the circle at any angle..
DfwRevolution did the work mathematically and so proved that the angle BAD is a 90-degree angle.
A tangent line will always be at a right angle to a radius that touches the circle at the same point.
So since angle ABC is a right angle, and angle BAD is a right angle, then lines BC and AD would be parallel and never intersect.
His work seems pretty sound to me. Are you sure that it's not E?
-Mir
jhooper
Sat Apr 02, 2005 3:29 pm
sorry DfwRevolution for repeating exactly what you said. I guess I should have refreshed my browser before posting because I didn't notice your reply...
DfwRevolution
Sat Apr 02, 2005 3:31 pm
Quoting Jfkaua (Reply 5):
Lol.. no problem, it happens. One thing to remember about circle geometry is that there is only a single tangental line at a single angle from at a given point. Try to find another tangental line and you'll cross over another point of the circle.
HB-IWC
Mon Apr 04, 2005 3:04 pm
Quoting DfwRevolution (Reply 10):
I'm not sure what you are trying to say here, so I might be misunderstanding your line, but one can draw exactly TWO tangental lines to a circle from any point outside of that circle.
As for the original problem, a nice variation and typical SAT question could be:
In the figure above, line BC is tangent to the circle with center A and radius 4 at point B. The area of the shaded region is (8/3)(pi). What is the distance from A to the intersection of lines AD and BC?
The answer to this question would be 8, and you could for instance use special formulas for 30-60-90 right triangles to easily solve it.
As for preparation for the SAT Math Sections, don't forget that the New SAT 1 is quite a bit more difficult than the old one, and that, although the Quantitative Comparisons have been eliminated, additional topics including Pre Calculus, Counting Problems (General Counting Principle, Combinations,...) and Elementary Probability and Statistics have been included.
Users browsing this forum: casinterest, Iemand91, kasimir, KL785, RJLover, StarAC17, Tugger, WIederling and 9 guests
