Kieron747
A Question About Baseball...
Wed May 04, 2005 1:35 am
Hello,
You might thinkh me a completely ingnorant Brit, but can someone answer me some questions about Baseball?
I watched my first game on TV last week and was trying to get to grips with the rules. So, here goes...
If the batsman misses the ball three times is he out?
If the batsman hits the ball and a fielder catches it is he out?
If the batsman whacks the ball outside of the field into the crowd, does he still have to run around the field?
If the batsman hits the ball, does he have to run or can he stay put?
Normally, I am a fan of cricket, but i have to say that I did quite enjoy watching Baseball the other day, so if anyone can help me with the rules, or any more information that would be great. Also, seeing as I know nothing of the game, which teams would you recommend watching for the best games?
Kieron747
Airliners.Net - The Jam Rag Of The Web.
Logan22L
RE: A Question About Baseball...
Wed May 04, 2005 1:43 am
Hey Kieron: If you had come to see us in Montreal, I could have answered these in person.
Quoting Kieron747 (Thread starter):
First, off, it a batter, or hitter. Three strikes and you are out. Whether it's a swing and a miss or a called strike by the umpire. Caveats: foul balls (balls not hit inside the foul lines along the first and third baselines) count as strike 1 or strike 2. A foul ball with two strikes is simply a foul, and the batter stays up there, unless he was trying to bunt. A foul bunt (a play in which the hitter squares around and tries to push the ball softly up a baseline to advance a runner or to get to first) with two strikes counts as a third strike, and he's out. Another caveat, the catcher must catch the third strike, or the hitter can run to first. If he beats it, he's safe at first.
Yes. The fielder must catch it before it hits the ground, or a wall. Alternatively, if it bounces, the fielder can "force" him out a first (no tag needed, but a tag is OK before he gets to first, he's out), or a fielder can tag him with the ball in his glove (for example, if the batter is running from home, past first, and trying to get to second).
Assuming it's a fair ball, yes. He must touch all bases in order.
He can stay put, but there's no point to doing that. All a fielder has to do is either "force" him out by throwing to first (the firstbaseman catches the ball with his foot on the base), or a fielder can tag him out. The batter's box is not a safe zone as in cricket.
Not quite as simple as rounders, is it? There's a thousand more rules; I'd be glad to share with you.
Logan
[Edited 2005-05-03 18:48:44]
"The deeper you go, the higher you fly. The higher you fly, the deeper you go."
xjramper
Wed May 04, 2005 1:48 am
If he swings and misses the ball three times, or strikes out, yes. However, there are foul lines that run from home plane (where the batter stands) to the wall. If the batter hits the ball outside those lines, then its considered a strike as well. However, if they do that more than three times, the batter only accumulates 2 strikes. (dont know the details behind that).
Yes.
Yes. thats called a homerun. For the home run to count, the batter must touch all four bases.
That depends. If he hit it in the field and it is a "fair" ball (inside the foul lines), then he needs to run to 1st base. But if he hits it foul, then they stay for another hit.
Hope that gives you some info.
XJR
Look ma' no hands!
Greyhound
Wed May 04, 2005 1:50 am
If the batter swings and misses three times, yes, that's a strikeout.
If the batter hits the ball and a fielder catches it BEFORE it hits the ground, he's out.
If the batter hits one out into the crowd IN BETWEEN THE FOUL POLES, it's a home run. Unless it hits the field first, then bounces into the stands, where it becomes a ground rule double, and all runners can advance only 2 bases. Anything hit into the crowd outside of the foul poles is a foul ball. The batter just goes back and tries again.
If the batter hits the ball, and does not run, he'll be working at a 7-11 by the end of the day.
As far as which teams to watch... take your pick... Not to pick on anyone, but any game involving the Kansas City Royals is just boring. If you like offense, Baltimore, New York (Yankees), Boston, LA Angels of Anaheim, Texas, and St. Louis. If you like pitching, Minnesota, Atlanta, New York (Yankees)*kinda, but not the way they're playing right now*, St. Louis, LA Dodgers, Chicago Cubs (they could be doing better)...
That's just my OPINION as far as who to watch...
29th, Let's Go!
cptkrell
Wed May 04, 2005 1:58 am
>" If the batsman hits the ball and a fielder catches it is he out?"
Yes, and additionally, if the ball is caught by ANY player on the opposing team, in-bounds or out-of-bounds, he is out.
Typing in - rules of baseball - in your search engine will give you a wealth of sites for info (baseball has a wealth of rules, too; so many, they hard to keep track of, especially in rare-play instances). Regards....Jack
all best; jack
Logan22L
Wed May 04, 2005 2:02 am
It's too bad that the Montreal Expos left town at the end of last season. You could have gone to see them and basically sat wherever you wanted for a low price (translation: they usually sucked, and no one cared up there).
Anyway, there's a lot of hype surrounding the Yankees-Red Sox rivalry (as most A.netters will tell you, they're sick of it). But, there's a fundamental problem with baseball: 4 or 5 teams have huge payrolls, and there is no revenue sharing, so for the last 10 years or so, small market teams (e.g., Milwaukee Brewers, Kansas City Royals) just have had no shot at the playoffs. So, the best games (i.e., teams with the best players, not always the best games) are often between teams like Boston, New York, Atlanta, Los Angeles, Houston, etc. Keep in mind, there are two leagues, American and National, and most of the games are played within each league, but there are some inter-league games also.
Notwithstanding what I said above, it looks like this year, the Yankees are off to a lousy start, Boston is so-so, and teams like Baltimore, Toronto, and Chicago are doing well. Your best best is to go to Toronto and try to take in a game against Baltimore, Boston, Los Angeles Angels of Anaheim  crazy , or Chicago White Sox.
Logan
TedTAce
Wed May 04, 2005 2:23 am
I hope these help  Smile
Official site:
http://mlb.mlb.com/NASApp/mlb/index.jsp
Rules:
http://mlb.mlb.com/NASApp/mlb/mlb/of...l_info/official_rules/foreword.jsp
If you really read the rules, you'll probably know more then 'most yanks'  Smile
This space intentionally left blank
SLC1
Wed May 04, 2005 3:40 am
One more very simple rule that people above have not explained, that is the idea of "balls," in other words the pitcher must put the ball inside of a strike zone, otherwise it's called a "ball." The batter can choose to swing at these, but if he misses it's a strike. If he doesn't swing, then it's a ball. Three strikes and the batter's out, but alternatively, if he gets four balls, he gets a "walk" to first base.
We're gonna do what we like to call a "jetBlue how do you do", which is slang for dumping a bunch of fuel in the ocean
September11
Wed May 04, 2005 3:48 am
never "talk back" to the umpire .... or you may be ejected from the game
Airliners.net of the Future
September11
Wed May 04, 2005 3:50 am
also .. when you hit homerun, your 3rd base coach will spank your butt when you run past 3rd base towards home plate  bigthumbsup
Newark777
Quoting XJRamper (Reply 2):
Unless you are bunting. If you bunt with two strikes, and you foul, you strike out.
Quoting Greyhound (Reply 3):
It's also a home run if he hits the actual foul pole itself.
Harry
prosa
Wed May 04, 2005 4:13 am
Quoting SLC1 (Reply 7):
Also, if the pitcher puts the ball inside the strike zone and the batter does not swing, it is a strike, just as if he had swung and missed.
"Let me think about it" = the coward's way of saying "no"
flymia
Wed May 04, 2005 6:44 am
Quoting Logan22L (Reply 1):
That rule only applys if there is no runner on first base.
If you want to see a team with Awesome pitching and good hitting watch the Florida Marlins!
Also no one explained base running. Really dont have the time.
Baseball is a game of rules and there are alot to know. Watch a few more games you should start to get it.
CaptOveur
Wed May 04, 2005 6:48 am
Quoting FlyMIA (Reply 12):
Someone could write a book on how to run bases.. It is almost an art that some players get, and others don't.
Things were better when it was two guys in a dorm room.
Newark777
Wed May 04, 2005 6:56 am
Want to get really confused? Read about balks here. It is item number 8.05. Rarely seen, and even more rarely understood.
Harry
Users browsing this forum: 9vswr, coolian2, Jalap, Osubuckeyes, tz757300 and 49 guests
