RNOcommctr
Mac: How To Handle Zip Files?
Sun May 15, 2005 3:38 am
I am having trouble downloading and viewing video clips in zip format on a Mac with OSX. When I click on the download link, a small Aladdin icon appears momentarilty and I believe also one almost at the same time that says something about "Stuffit". So then I am left with a desktop icon that does absolutely nothing but reproduce itself when I click on it. How do I view the clip???
Jeez, I'm ignorant enough with Windows applications, much less Mac. Thanks for any help.
Active loading only, ma'am, keep it moving!
TedTAce
RE: Mac: How To Handle Zip Files?
Sun May 15, 2005 3:42 am
If you can move the file to a windows box I can help. elsewise you'll have to wait for the Mac users :|
This space intentionally left blank
AeroWesty
Sun May 15, 2005 4:01 am
When downloading via a browser, I usually hold down the Control key before clicking on the link, so I get a menu of choices on how to download, usually there'll be something like "download file to ..." to choose from.
If the extension of the file name is .zip, OSX will automatically unzip it for you when you double-click the file. If you're getting a file with .sit, you'll need Stuffit Expander, available here:
http://www.stuffit.com/mac/expander/index.html
If the resulting file comes with the extension .wmv, then you'll need to download and install the Windows Media Player for Mac, that you can download from microsoft.com. If the resulting file is .avi, .mov, .mpg, etc., they'll usually play just fine in Quicktime.
International Homo of Mystery
ACDC8
Sun May 15, 2005 5:06 am
Oh, a Mac question....Klaus, where are you?  Smile
A Grumpy German Is A Sauerkraut
bezoar
Sun May 15, 2005 6:05 am
If you don't have Stuffit Expander, I think downloading it should do the trick. Let us know if it doesn't.
"There are none so blind as those who will not see."
Klaus
Mon May 16, 2005 11:42 pm
And here I am! Big grin
ZIP files aren´t a problem under OS X. Even the Finder supports them directly, although most people have the free version of Stuffit installed which also supports unpacking them.
Packing files or folders into a .ZIP file can be done as simply as selecting "make archive" from the context menu in the finder. Unpacking them is a simple double-click.
To your concrete problem, RNO:
Having Safari(?) mention Stuffit when downloading the file is normal; When Stuffit is installed, .ZIP files are mapped to it as the unpacking tool.
I´d like to know more about what´s going on when you say the icon is "replicating" itself. In all cases I know about, the contents of the folder would just be unpacked and would then be accessible as usual. What has happened, exactly?
One thing you should do in every case: Go to the Finder preferences and activate "show all file extensions". (It should always remain enabled.) Then look at the .ZIP file and the unpacked one again. What are their extensions?
If it´s a small .WMV file, it could be a streaming link file; In that case it can be fed to the player directly. Some .MOV files work in a similar way. If it´s an .EXE, they were just trying to coax you into installing Windows spyware, which fortunately won´t work under OS X.
You may not need to install the Windows Media Player, by the way. It reports back to Microsoft what you´re watching. There are two Open Source players which can handle most files that can´t be played in the QuickTime Player:
VLC media player
MPlayerOSX
In addition to that, there are several codec plugins for QuickTime which extend its native playback capabilities (3ivx, divX etc.).
RNOcommctr
Tue May 17, 2005 1:52 am
Thanks for all the help, guys. Never could get Quicktime to play the files, but for some reason, Klaus, the MPlayerOSX did allow me to play the ones ending in .zip and .rm. Thanks again for the help.
Users browsing this forum: LittleFokker and 1 guest
