sacflyer
Something Neat In This Picture
Wed May 25, 2005 1:33 am
Check out the refraction of the sunlight in the #2 engine exhaust. This picture would make a great example for a high school science class. Also, a great example of how the eyes can be fooled into seeing something that isn't really there. UFO's anyone?
Photo © Tim de Groot - AirTeamImages
[Edited 2005-05-24 18:34:57]
I'm just happy that RR ratings can't be in negative numbers!
DLKAPA
RE: Something Neat In This Picture
Wed May 25, 2005 2:42 am
Oh my god that engine is on fire...o wait.
Mr Spaceman
Wed May 25, 2005 5:41 am
Hi guys.
I think it's probably the condensed moisture in the exhaust that's reflecting the sunlight like a mirror.
Cool photo.
Chris  Smile
IHadAPheo
Wed May 25, 2005 5:47 am
Chemtrail spreading device malfunctioning spreading it's evil gases at low level
IHAP
Why is that black helicopter flying around the swamp??
Pray hard but pray with care For the tears that you are crying now Are just your answered prayers
Thom@s
Wed May 25, 2005 5:55 am
Quoting Ihadapheo (Reply 3):
Are we looking at the same photo?  Smile
There is a car on the bottom left... but I can't see any helicopters.
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
sacflyer
Wed May 25, 2005 6:00 am
Quoting Mr Spaceman (Reply 2):
I guess that is possible, but wouldn't there be much less condensation in the exhaust as compared to the surrounding air. And, why doesn't it work when there is visible vapor in the air. Wouldn't that make a cloud a large mirror?
I think what is happening here is a vertical mirage caused by the refraction of the light through the hot exhaust as opposed to a horizontal mirage that occurs on a roadway or desert.
I had a physics professor explain that an inversion layer could cause an inverted mirage. This could cause street lighting, for example, to mysteriously appear in the sky if the conditions were right. Still looking for an example of that though.
sacflyer
Wed May 25, 2005 6:11 am
Quoting Thom@s (Reply 4):
You must not be looking hard enough, I see it.
Thom@s
Wed May 25, 2005 6:19 am
Quoting Sacflyer (Reply 6):
Good for you, care to give me a hint on where it is?  Smile
Would be easier to find Waldo...
Thom@s
sacflyer
Wed May 25, 2005 6:24 am
It was a joke, however, Waldo is the one standing next to the car.
KFLLCFII
Wed May 25, 2005 8:12 am
Quoting Sacflyer (Reply 5):
No. Actually the fuel/air combustion adds more water into the atmosphere:
Gasoline and diesel (including jet fuel) is essentially a mixture of hydrocarbon molecules (hydrogen and carbon atoms). When they are combined with oxygen (burned), the atoms are rearranged to form carbon dioxide (CO2) and water (H2O). For every gallon of fuel combusted, approximately one gallon of water is produced. This water, of course, is in vapor form. (Note: this is why car exhaust systems are so prone to rusting)
Since the air entering the engine's intake already contains a certain amount of water, the combustion only adds more to it. If this extra water content pushes the air past its saturation point, and the air temperature is cool enough to freeze water vapor, then a contrail will form!
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
sacflyer
Wed May 25, 2005 9:01 am
Quoting KFLLCFII (Reply 9):
Okay, that makes sense. Do you have an opinion as to why the sun's light is appearing in the exhaust?
atrude777
Wed May 25, 2005 9:23 am
wait, the comment says its a sunrise? But doesnt it look like a sunset? either way it is a BEAUTIFUL picture and it is my baxkground now.
Alex
KFLLCFII
Wed May 25, 2005 9:39 am
Quoting Sacflyer (Reply 10):
Because the hot gas is at such a different density (due to higher temperature) than the surrounding air, that it actually appears to be a separate fluid from the surrounding air. If you look at the rest of the exhaust stream, the flow appears to take on the same look as if you pour clear cooking oil in a water jug and shake it up. Why? Because each of the fluids have different densities, hence you can see one within the other. Another good example is a lava lamp.
Regarding the sun's light appearing in the exhaust, this is because the light is reflecting off the exhaust's boundary to the surrounding air. This is the same reason that you can see the sun's reflection on the ocean during any given time of day: Water (as a liquid) has a significantly different density than air.
PS: The sun's light is not the only thing being reflected: Note the same effect from the buildings below.
Springbok747
Wed May 25, 2005 10:06 am
Quoting Sacflyer (Thread starter):
Ah, I know what that is. It IS a secret UFO super weapon constructed by the LIBERALS and gays and negroes, all a part of their secret agenda to take over the world, and get rid of good white Christian folk like us.
I know all this because I am a very very smart 10...er....13....er...14 year old who KNOWS the secret agenda of their kind.
I also know that the UFO is MASSIVE, because I measured it using my pee-pee. As you can see, it is about 2 cm on the picture, which is 1.9 cm longer than my pee-pee (I used this as I don't have a ruler, so I use my pee-pee as the standard to measure everything).
Anyway, by extrapolating (see, I am smart, I use big words!) the distance and doing calculations and stuff, I have concluded that this super-weapon is 300 m in length and will strike us in 3 days....GOD SAVE US!!!!!!!!!
OH...and God also bless G.W Bush, our commander-in-chief so that he can lead the rebellion and crush the oppressors (yeah, I just saw Star Wars, but it was too complicated for me to understand though).
Signed
Liberalturdslayer
אני תומך בישראל
Users browsing this forum: kasimir, petertenthije, vrbarreto and 3 guests
