j_hallgren
Need Help With Math Problem Related To Triangle.
Tue May 31, 2005 10:27 pm
It's been 30+ yrs since high school for me so...
Need to find out how long a side of a triangle would be:
Thus starting at point A, I walk straight ahead for 50 feet to point B. I then turn right (90 degrees) and go to unknown point C.
How far should I walk to get to C if the angle from point A to C is 20 degrees off from A to B? Does that description make sense? Thanks!
COBOL - Not a dead language yet!
redngold
RE: Need Help With Math Problem Related To Triangle.
Tue May 31, 2005 10:31 pm
Here's all you need to know:
The Pythagorean Theorem (applies only to right triangles): a^2 + b^2 = c^2
and: All the angles of a triangle must add up to 180 degrees, if you're trying to figure out the degree of angle.
Up, up and away!
MD11Engineer
Tue May 31, 2005 10:35 pm
Quickly I would say:
Alpha = Angle between AC and AB
AB = distance A to B
BC = distance B to C
BC = tan (Alpha) * AB
Jan
j_hallgren
Tue May 31, 2005 10:38 pm
The problem with the application of P-T to this issue is that I only know the length of side A! And I need the length of side B, not the angle of the third corner, which I knew to be 70 degrees.
I also don't have any reference material to get the value of tangent for this issue, and search for it turns up way too many items.
[Edited 2005-05-31 15:41:38]
SLC1
Tue May 31, 2005 10:43 pm
if memory serves me correctly, and i understand your question, your length BC=50*sin20/sin70, which ultimately comes to 18.191851171331 this is because sin A/BC = sin B/AC = sin C/AB
[Edited 2005-05-31 15:46:30]
We're gonna do what we like to call a "jetBlue how do you do", which is slang for dumping a bunch of fuel in the ocean
FLYtoEGCC
Tue May 31, 2005 10:47 pm
You know the angle BAC to be 20 degrees.
Tan (angle) = opposite side / adjacent side
So if your unknown side BC = x, you would do:
Tan 20 = x / 50
So x = 50 * Tan 20
Which should give you an answer of 18.19851171 ft...
Come fly with me, let's fly, let's fly away...
redngold
Tue May 31, 2005 10:48 pm
Argggh I didn't read the question well enough... Definitely need the sines and tangents here...
Up, up and away!
j_hallgren
Tue May 31, 2005 10:51 pm
Tried Google with different phrase and found:
http://www.pangolin.com/userhelp/scanangles.htm
Which deals with scanner and screen but gives the formula and value of Tangent for 20 deg as .364
Edit: I was posting this at same time FlytoEgc did so didn't see that reply but THANKS to all who helped me!  Smile
[Edited 2005-05-31 15:58:48]
Users browsing this forum: Dutchy, JannEejit, N14AZ, oly720man and 1 guest
