Zweed
Help Me With A Very Easy Math Problem
Sun Jun 05, 2005 9:39 pm
It's sunday afternoon and my girlfriend is taking some math classes, she asked for my help and as I said, its sunday afternoon and I my total lack of math skills is even larger than they would be without this hang over,
A parking lot has the area of 900 sq. metres, it has be rectangular
A fence is going to be built around this lot.
What dimension will give us the least amount of money spent on the fence?
wunala
RE: Help Me With A Very Easy Math Problem
Sun Jun 05, 2005 10:04 pm
45X20
petertenthije
Sun Jun 05, 2005 10:08 pm
30x30 = 120m fence
the 45x20 given by Wunala gives you 130m fence
Attamottamotta!
Jan Mogren
Sun Jun 05, 2005 10:12 pm
But 30x30 isn't rectangular.
/JM
36x25 is 122 meters fence
[Edited 2005-06-05 15:14:58]
AeroPresentation - Airline DVD's filmed in High Definition
aloges
Sun Jun 05, 2005 10:17 pm
Quoting Jan Mogren (Reply 3):
Well, it's square - but a square is a rectangle, whereas a rectangle is not necessarily a square.
petertenthije
30,01 x 29,999 = 120 (only very slightly rectangular but still a rectangle)
Attamottamotta!
Jan Mogren
Sun Jun 05, 2005 10:30 pm
Way back I was taught that a square is not a rectangle, but never mind.
You are probably correct.
(30,01 x 29,999 = 900,2699 if one wants to argue  Wink )
/JM
kalakaua
Sun Jun 05, 2005 10:33 pm
Sounds like a classic Calc. I problem to me?
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
wunala
Sun Jun 05, 2005 10:59 pm
Quoting Kalakaua (Reply 7):
And your answer is ??????????????
backfire
Sun Jun 05, 2005 11:01 pm
Assume the parking lot is a rectangle with length x.
Its width must therefore be 900/x
Therefore the perimeter is twice the longer side plus twice the shorter side.
Perimeter P = 2x + 2(900/x)
Therefore P = 2x + 1800/x
From this equation it can be seen that, if x is small, P becomes very high because of the second term. Similarly if x is large, P also becomes high because of the first term. In between there is a value of x for which P becomes a minimum (minimum P, of course, means the shortest fence and the least cost).
To find the minimum of the P-x curve, you have to differentiate P with respect to x:
P = 2x + 1800/x
so: dP/dx = 2 - 1800/(x^2)
The minimum of the P-x curve is the point at which the slope (dP/dx) is zero.
Thus: 2 - 1800/(x^2) = 0
1800 = 2(x^2)
(x^2) = 900
and therefore x = 30
So the length is 30 and the width is (900/x) ... also 30.
It is indeed a square, but since a square is, by definition, rectangular, the problem is solved.
ilikeyyc
Sun Jun 05, 2005 11:06 pm
Quoting Petertenthije (Reply 5):
I think that the questions means that it can not be a circle, triangle, pentagon, etc.- it has to have 4 perpendicular sides.
I have been taught that a square is a rectangle- just a special one.
Fighting Absurdity with Absurdity!
kalakaua
Mon Jun 06, 2005 11:01 am
Backfire has it... or at least has the jist of it. Other than that, everyone else is wrong!!!
airxliban
Mon Jun 06, 2005 11:08 am
ditto Backfire in different terms...
you are minimising Z=2x+2y where xy=900
so x=900/y
so Z=2*(900/y)+2y
Differentiate it...
dZ/dy = 2-1800/y^2
Set it equal to zero, y=30 or y=-30
Since y=-30 does not make sense, we reject that solution and take y=30
Then x=300/y=300/30=30
So you need to go with 30x30.
Users browsing this forum: BlueLine, wjcandee and 2 guests
