desertjets
Attn MAC Experts, Help Needed Asap
Wed Jun 08, 2005 11:52 pm
So I have just inherieted a bunch of old floppy disks that contain a variety of old archived content that might be useful. I thought I would just load it up onto my PC, organize it, and burn it onto a CD and call it a day.
As it turns out most of these floppies are MAC format. But I did luck out, as 3 old PowerMac G3s are in the next room (the original beige ones, not the cool teal ones). Just from looking at a few of these disks it appears that most of the files were created in AppleWorks, most of them are text documents or spreadsheets, but at least one is a database.
Either way it looks like lots of floppy swapping to make all of this happen. What would you suggest I do here?
-Take all the word processing docs and open them in Word and save them on a Windows formatted floppy and swap, or is there something easier that I can do.
Also note that those MACs are not connected to any server at this point.
Klaus
RE: Attn MAC Experts, Help Needed Asap
Thu Jun 09, 2005 3:19 am
It would indeed be the easiest way to load the documents and export them in a format you can use (ASCII / RTF for text, CSV for data bases).
ZRH
Thu Jun 09, 2005 3:25 am
Perhaps you can export the into a normal Word (.doc) format which can be read by Mac or Windows.
Klaus
Thu Jun 09, 2005 3:29 am
Just look at the exporting options - and try the import on your target system before putting the originals away...
desertjets
Thu Jun 09, 2005 3:33 am
That is what I pretty much thought. I've been dumping the floppies onto the MAC on and off all day. Then I will go through and figure out what is worth archiving and convert whatever I need to over to an MS Office format and be done. Just wish there was an easier (read less time consuming) way.
Klaus
Thu Jun 09, 2005 3:54 am
Sure there is... use a Mac! Big grin
Users browsing this forum: casinterest, N415XJ and 1 guest
