SFOMEX
Buenos Aires To Montevideo, By Plane Or Ship?
Thu Jun 23, 2005 2:41 pm
Greetings.
I'm planning my next month trip to Buenos Aires. I know that Montevideo is really close to Buenos Aires, so I think it'd be great to visit Uruguay too. I've doing my homework and I have two options:
-A 50 mins flight between EZE and MVD.
-A two hours trip in a boat.
I know, for us aviation nuts it'd be a an easy pick, especially when I can fly a UA's 767 for the short hop. Yet, I wonder if I'm going to miss nice views or other interesting stuff by skipping the ship's trip.
Hence, I'd be really grateful if our fellow Argentinean A.netters could give some input. Or if any of you have done this before, I'd like to hear your advice.
Thanks in advance pals!
The only thing worst than the GOP is the Democratic Party, think about it!
USAFHummer
RE: Buenos Aires To Montevideo, By Plane Or Ship?
Thu Jun 23, 2005 2:44 pm
Why not do both? Go out on the airplane, come back on the boat, or vice-versa...
Greg
EZEIZA
Thu Jun 23, 2005 2:50 pm
Hi SFOMEX,
ok, let's see your options.
If you want to see more of Uruguay, I would suggest you thake the Buquebus, but not the direct one to Montevideo, rather, the one that goes to Colonia, and from there you'll have a 2 hour bus ride to Montevideo. The connection is provided by Buquebus, so you don't have to worry.
If you want to get the direct Buquebus, you'll only have water around you all the time, so no real sight seeing there.
Maybe you can try going there by the first option and coming back flying. You have Pluna and AR. Plune uses 732's and ATR-42's, while AR will have also 732's or MD-80's (I don't think they are using the 735 to MVD).
A third option, also by boat, is taking the "Cacciola". This one leaves from Tigre, north of Buenos Aires and has a 2 hour trip by boat and then the bus (again, all arranged). This way you get to see much of the Uruguayan countryside as well as the Tigre area, a kind of Buenos Aires Venice  Wink
hope this helps!
Carp aunque ganes o pierdas ...
rootsair
Thu Jun 23, 2005 2:52 pm
Well strictly speaking if you go from the center of Bs As to he center of Montevideo, you are much quicker by boat due to the time it takes you to go to Ezeiza airport, check in, board,taxi, fly, land in MVD , get out of the airport and go to city center!
You have a good company called Buquebus. You can find info on prices here http://www.buquebus.com
However its true that if you have all your time and are a great Av nut like most of us here I'd say you take the flight! After all on the boat trip you get to see a great view of Bs As from the sea but then its just water and water as you go through the Mar de Plata .
Hope this helps
BM
A man without the knowledge of his past history,culture and origins is like a tree without roots
paulc
Thu Jun 23, 2005 2:56 pm
Most of the flights between Montevideo & BA use Aeroparque rather than Ezeiza - or they did when I did it a few years ago.
English First, British Second, european Never!
EZEIZA
Hi roots, todo bien?
Quoting RootsAir (Reply 3):
Actually its a River! Rio de la Plata
Mar de Plata
Mar del Plata is a city 400 km south of Buenos Aires, on the Atlantic coast
 Smile
SFOMEX
Thu Jun 23, 2005 3:01 pm
Quoting USAFHummer (Reply 1):
Why not do both?
Yep, it'd be a great way to do it. I only worry about $$, since it'd be more expensive that way.
Quoting EZEIZA (Reply 2):
Great info EZEIZA, muchas gracias! I had no idea about these two different options by boat. The third option is especially attractive since I don't want to limit myself to urban areas. Once again, thanks.
AR1300
Thu Jun 23, 2005 3:04 pm
Buquebus a litle bit cheaper.I just booked to my mother for 310 pesos, about 100 us Dollars.By plane AR has several flights, wich cost about 120 us Dollars.
I would go on the boat, as is faster.Just be there half on hour or 20 minutes before and you are in, getting down in Downtown MVD.No need for hassle, taking cabs, check in, etc.Plus, there are very cool Duty Frees on board.
Come to visit the Argie A.nutters!!!Hope to see you around!!!
Mike
You are now free to move about the cabin
SFOMEX
Thu Jun 23, 2005 3:06 pm
Thanks for the link RootsAir. You are right, I'd like to flight just for the sake of adding MVD and maybe Aeroparque to my list of airports I've visited. I only hope that the person I'm traveling with would be nice enough to accommodate to my airports' fever.  Wink
EZEIZA
Thu Jun 23, 2005 3:08 pm
Quoting SFOMEX (Reply 6):
No problem! As Mike said, let us know when you're here, maybe we can go sight seeing at AEP  Smile
SFOMEX
Thu Jun 23, 2005 3:16 pm
Quoting AR1300 (Reply 7):
Quoting EZEIZA (Reply 9):
That would be great! I'll be in Bs As during the third week of July. I'll let you know in advance about my plans and hopefully we would be able to arrange something.
MD11junkie
Thu Jun 23, 2005 4:01 pm
SFOMEX!
Great to see you are visiting "La Reina del Plata" and great for you to show interest for the princess! (MVD)  Wink
Here's some research I did for a thread Big grin AR To Appeal DUE LAN Route Concession (by Kavanagh Jun 5 2005 in Civil Aviation)
Check reply 8.  Smile.
Well.. we surely hope to hear from you!
Un saludo desde Linksys! Big grin
Cheers! wave
Gastón - The MD-11 Junkie
There is no such thing as Boeing vs Airbus as the queen of the skies has three engines, winglets and the sweetest nose!
rootsair
Thu Jun 23, 2005 4:23 pm
Quoting EZEIZA (Reply 5):
true you are right on that one! Its such a huge river I tend tzo say its the sea....plus the salt that comes from mixing in with the sea makes it smell like the sea !
[Edited 2005-06-23 09:36:43]
AR1300
Fri Jun 24, 2005 11:01 am
Quoting RootsAir (Reply 12):
Humm, they don't mix.I've been in Punta Rasa were the River joins the Ocean, and the depth is 1 or 2 feet and the water flows to the other side, towards the ocean.And you can clearly see a line in between, and brown water to your left and blue water to your right.And lots of crab.all over the place.
Maybe that smell was the polution....
Mike
Curtisman
Fri Jun 24, 2005 11:08 am
A few years back I did the boat thing from Montevideo to Buenos Aires. I must say I thoroughly enjoyed it... great timing from almost city centre to city centre. The great part was chatting with both locals and tourists. It was a great way to arrive in BA. The flights would be great but if you like to walk around and mingle and see the city from a different angle (out on the river) then I would recommend trying it at least one way.
Cheers!
Curtis
Citizen of the World
EZEIZA
Fri Jun 24, 2005 1:22 pm
Quoting AR1300 (Reply 13):
Exactly what I was about to say! Unfortunatly the river is polluted, especially on the Argentine side.
bongo
Sat Jun 25, 2005 1:11 am
Do the tourists has to show the passport when they travel from Bs As to Montevideo by the Buquebus? Or is it a "free zone"?
MDE: First airport in the Americas visited by the A380!
MD11junkie
Sat Jun 25, 2005 1:43 am
Quoting Bongo (Reply 16):
Tourists, yes. Citizens, no. Only with their DNI (Documento Nacional de Identidad). After all, you are changing countries. An Economic bloc is not a Union just like the EU.  Smile.
Cheers! wave
bongo
Sat Jun 25, 2005 1:53 am
Thanks MD-11 Junkie, I will be there in two months for vacations and want to go on a day trip to Montevideo, In every case I will of course have my passport ready.  Wink
Derico
Sat Jun 25, 2005 8:48 am
Well, I would do the ferry just because ferries are getting rarer and rarer...
Just bring some warm clothing it can get rather chilly in July!
My internet was not shut down, the internet has shut me down
SFOMEX
Sat Jun 25, 2005 2:58 pm
To all of you, thanks for the info. I'm really looking forward to visit Bs As and Montevideo and to experiment winter in July! LOL
AR1300
Sun Jun 26, 2005 12:00 pm
Quoting Bongo (Reply 18):
You are welcome too!!!
Mike
KLM685
Sun Jun 26, 2005 2:59 pm
Quoting SFOMEX (Reply 20):
It's really crazy! I just experience it myself a week ago and it really takes you out of place. The first day I didn't knew If i felt cold or hot, or weird. I even got a cold! lol
Anyway, have a nice trip!!
Alonsou
MAH4546
Mon Jun 27, 2005 12:58 pm
I would do the ferry...it's fun. I've taken Buquebus between Montevideo and Buenos Aires. Nice boats and a relaxing ride. Though I recommend paying the extra AR$50 (about $US18) to go in Especial Class. The seats in coach make most airlines' 31" pitch seem roomy.
a.
Users browsing this forum: bgm, BobPatterson, einsteinboricua, ER757, salttee, zanl188 and 39 guests
