CaptOveur
So What Do I Want To Write About?
Wed Jun 29, 2005 1:54 am
For my obnoxious Freshman composition class (which I have been putting off for so many years) I need to write a cause and effect paper. I get to pick the topic so I was looking for suggestions.
I need to be able to find at least 3 resources, and I should be able to git R done in 3-5 pages.. Any suggestions?
Things were better when it was two guys in a dorm room.
DLKAPA
RE: So What Do I Want To Write About?
Wed Jun 29, 2005 1:56 am
Cause: Richard Nixon pulling the US Dollar off a gold-backed standard.
Effects: exponentially rising inflation and all the problems that go with it.
CaptOveur
Wed Jun 29, 2005 4:22 am
Got anything slightly aviation related? No reason to punish myself wading through piles of data for that... and it might be hard to only get 3-5 pages out of that.
KROC
Wed Jun 29, 2005 4:24 am
I always have found this website helpful for such matters...
www.doyourowndamnwork.com/lazyass
CaptOveur
Wed Jun 29, 2005 4:25 am
shouldn't you be out spray painting hummers or something?
KROC
Wed Jun 29, 2005 4:27 am
Quoting CaptOveur (Reply 4):
Consulting LHMark for insult material now? And you had so much potential too.  Sad
CaptOveur
Wed Jun 29, 2005 4:29 am
Quoting KROC (Reply 5):
I guess thats what they tell all the kids in special ed.
When I apply to that company you work for can I use you as a reference?
futureuapilot
Do something so technical that it will sound like you know exactly what your talking about. I've done a whole bunch of essays on the "Aerodynamics of the horizontal stabilizer" and such... A+ !
-Sam
The Pilot is the highest form of life on Earth!
Kieron747
Wed Jun 29, 2005 4:30 am
Quoting CaptOveur (Reply 2):
I'm sure there are loads of aviation related cause and effect things you could write about.
How about...
Cause: Failure of a 19 cent light bulb.
Effect: The downing of Eastern 401.
Kieron747
Airliners.Net - The Jam Rag Of The Web.
KROC
Wed Jun 29, 2005 4:47 am
Quoting CaptOveur (Reply 6):
Absolutely. I'll square you away then if you are in town LHMark can square you away in other ways.
flyAUA
Wed Jun 29, 2005 5:18 am
How about...
Cause: Airlines becoming more cost conscious
Effects: Manufacturers using more and more composites in their aircraft
Not drinking, also isn't a solution!
tristarenvy
Wed Jun 29, 2005 5:59 am
Cause: Deregulation
Effects: How's that flight on Eastern/Braniff/PAA going?
If you don't stand for SOMETHING, you'll fall for ANYTHING.
redngold
Wed Jun 29, 2005 6:05 am
Cause: I don't like writing term papers.
Effect: I write a term paper about writing term papers.
Desired Effect: Professor now understands why term papers may not be the most productive assignments to give students.  Wink
Up, up and away!
Users browsing this forum: BobPatterson, DIRECTFLT and 37 guests
