Treadmill Run Duration
Fri Sep 16, 2005 5:00 pm
What would be the normal duration of Treadmill run for a 3 kgs overweight guy.
Would 30 mins a day be ok.
What tilt & What Speed.
regds
MEL
smitten
RE: Treadmill Run Duration
Fri Sep 16, 2005 5:56 pm
I have to say it depends on the individual. When i had an extra 20 lbs. to loose i started running each night for roughly 30 minutes with varying speed and incline. However within a week i was up to over an hour a night... it just depends... my advice, listen to your body but dont be afraid to push yourself.
greasespot
Fri Sep 16, 2005 7:43 pm
Why run on a treadmill? Run outside
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
pilotaydin
Fri Sep 16, 2005 7:47 pm
you know you dont have to run....if you run, you might lose muscle as well, this usually puts you in the cardio zone, but if you walk, your body will use fat as the energy source first, rather than muscle and fat for immediate replenishment...
walk for a hour a day on the treadmill, it's not as easy as it sounds, go 5km an hour...
The only time there is too much fuel onboard, is when you're on fire!
Sun Sep 18, 2005 1:19 pm
Quoting Pilotaydin (Reply 3):
Great Tips.
Would Walking with Higher Tilt be more Effective than running with lower tilt.
regds
MEL
usnseallt82
Mon Sep 19, 2005 5:06 am
Quoting HAWK21M (Thread starter):
If you're not used to running, just start slow at around 3.5-4 mph(don't know what that is in kph) with only about 1% grade. If you use 0%, the treadmill doesn't give you quite the exact workout as real running. But, when you put 1% grade on it, its almost identical. Do this for about 30-45 minutes. Then, later on, you can increase the speed and decrease the overall time.....but do try to stay at or around 30 minutes. This will give you a good workout and a good sweat.
Quoting Greasespot (Reply 2):
Treadmill's are great for people who aren't used to running very much. If you start outside at first, you're a little more prone to injury and loss of motivation. Getting in a gym to run on the treadmill can be a good start for those who don't have a workout routine yet.
Crye me a river
FlyVirgin744
Mon Sep 19, 2005 7:01 am
Ummmm, air conditioning.  Smile
Sometimes I go about in pity for myself and all the while a great wind carries me across the sky.
prosa
Mon Sep 19, 2005 7:14 am
Also, when running on a treadmill try not to hold onto the handrails or other parts of the machine, as doing so reduces the quality of the exercise.
"Let me think about it" = the coward's way of saying "no"
Mon Sep 19, 2005 4:10 pm
Interesting tips.
I do run outside,But in a place like Mumbai[Bombay] its tough on the roads considering the traffic.And the Parks are crowded so one has to slow down frequently.Hence the Treadmill option.
I run a lot,but someone said running reduces Muscle too.If thats the case then Walking fast would be preffered to loose Fat.
Although 3kgs should burn off in a month I feel.
regds
MEL
Users browsing this forum: af773atmsp, jetero, lugie, seat64k, speedbird217, Teganuma, Tkfan, Yahoo [Bot] and 1 guest
