Superfly
Drilling A Hole Through Planet Earth
Sat Nov 05, 2005 2:01 am
Inspired by the losing the sun thread.
http://www.uni-mainz.de/FB/Geo/mineralogie/Earth_System_Cycles/whole%20earth.jpg
Hypothetical question.
What if a whole of 6feet in diameter was drilled through the planet all the way to the other side?
What would happen?
Would molten lava shoot out both ends?
What effect on gravity would that have?
If a person or object fell in the whole, would they fly out the opposite end or would they be suspended in the middle?
Would everything on the surface near it get sucked in like rapid decompression?
Bring back the Concorde
TPASXM787
RE: Drilling A Hole Through Planet Earth
Sat Nov 05, 2005 2:07 am
Quoting Superfly (Thread starter):
That would be the biggerst drill bit ever.
What would happen?
There would be a 6ft diameter hole in the Earth  Wink
That would be cool.
I'd say it would be a sure way to screw up the magnetic field if nothing else.
Both good questions. Perhaps this is where the servers go when a.net is down.
This is the Last Stop.
Logan22L
Sat Nov 05, 2005 2:11 am
Assuming you could round up enough auger flights to do this, by the time you got down to the molten core, lava would indeed come gushing up. So, you'd never make it past the core unless you have an asbestos jumpsuit with a big "S" on it.
If someone fell in the hole, they'd be vaporized by the heat of the core, but leaving that aside, the person would go past the center, then get drawn back the other way, and would oscillate back and forth in damped motion until finally coming to rest in the center - all of this due to the pull of gravity, which eminates from the center of the Earth.
I don't believe that anything would necessarily get "sucked in." Then again, what the hell do I know? I don't even know how the can opener works. - Woody Allen
[Edited 2005-11-04 18:12:21]
"The deeper you go, the higher you fly. The higher you fly, the deeper you go."
Superfly
Sat Nov 05, 2005 2:27 am
Quoting Logan22L (Reply 2):
Well the earths gravity is really powerful. Is it possible that they wouldn't go past the core? Afterall, it's gravity that is pulling you down.
What does the "S" do?
Is that like a Ghostbuster?
Only Bon Jovi can stand temperatures that high. Remember there 7800 Fahrenheit album?
Also Rick Wakeman took a Journey to the Center of the Earth.
SlamClick
Sat Nov 05, 2005 2:31 am
This has long been my transportation dream. Imagine, a tunnel straight from San Francisco to, say, Tokyo. It wouldn't be straight through the center but it would be pretty steep.
Now the actual vehicle is cylindrical. It sits on rollers and when everything and everyone is boarded you just tip it down a gentle ramp into the hole. Gravity takes over and it freefalls to the center. Then its momentum carries it fairly close to the surface on the other side (a few hundred miles maybe) Then we fire the steam rockets. The energy in the steam was imparted by passing through the really hot parts of the Earth's interior. It may just be the perfect mode of transport - no energy use from outside sources.
Okay, there are a couple of problems to solve and a couple of inherent solutions.
If the Earth's center is molten then it seems probable that the middle part is a giant pousse cafe of molten metals. Somewhere down there, arranged according to its specific gravity is a layer miles deep of pure molten gold. That will pay for the project. There are probably even elements that have never been found at the surface - that will provide the scientific justification.
So, fly, meet me at next year's Burning Man and we'll discuss it.  Smile
aloges
Sat Nov 05, 2005 2:37 am
think this is a bad idea.
Logan22L
Sat Nov 05, 2005 2:39 am
Quoting Superfly (Reply 3):
Think kryptonite.
Doubtful, although thinking about this, gravity is caused by mass, and at the center of the Earth the mass is largely "above" you. Hence the real answer is I have no freakin' clue. You know like the way ConcordeBoy and MaverickM11 talk about volcanos having more effect on global warming than man's activities.
SATL382G
Sat Nov 05, 2005 2:43 am
Unless you're "hypothetically" suspending the physical laws which govern the universe....
The hole will collapse when the pressures encountered overcome the bearing strength of the holes walls or of the drill bit.
If you are suspending the physical laws of the universe then I suggest we build a hi-speed rail link with a line change station and underground shopping area at the center of the earth. Such a train line would generate it's own energy, utilizing the potential energy it has prior to being dropped in the hole. The train will accelerate all the way to the line change station and decelerate all the way out to the other side of the earth coming to a complete stop only at the destination station. Passengers changing trains or going shopping will need to "jump" off at the at the change station, landing in a large pool of decelerative goo. Passengers leaving the station will be fired, by rail gun, into the observation car of a passing train.
Air travel, as we know it, will come to be seen as a slow and energy inefficient means of transportation. The phrase "catch a plane" will be replaced by "jump in a hole", as in "Sorry, gotta run. Gotta go jump in a hole". Atlanta Hartsfield will no longer be the predominant transportation hub in the U.S. That honor will go to the train change station, hereafter known as Hell (HLL). So to go from Poughkeepsie to Boise everyone would need to "go to Hell" first.
See, things really are easier if we just suspend reality.  Smile  Smile  Smile
SlamClick
Sat Nov 05, 2005 2:50 am
Quoting SATL382G (Reply 7):
Well hell, if we are going to suspend reality let's get back to politics.
Superfly
Sat Nov 05, 2005 2:52 am
Quoting SlamClick (Reply 4):
Sounds cool!
The closest we can get to that experience is if I drive my car and bring my quad 8track tape of Rick Wakeman's 'Journey To The Center Of The Earth'.
You'd need some acid or LSD to really feel like your are there. I'd just stick to pot brownies.  Smile
SATL382G
Sat Nov 05, 2005 2:53 am
Quoting SlamClick (Reply 8):
I thought of that, but decided not to derail the thread.....
SATL382G
Sat Nov 05, 2005 2:59 am
Such a transportation scheme is going to require an outside source of energy as gravity will impart drag enroute. Of course with reality suspended you could pretty much do whatever you want.
That's the trouble with discussions like this, nobody but the thread originator knows what portions of reality are suspended and which are not.
Banco
Sat Nov 05, 2005 3:02 am
Of course, if the departure point was in the UK, services would be disrupted by any leaves that fell down the hole, or if it snowed.
She's as nervous as a very small nun at a penguin shoot.
stlgph
Sat Nov 05, 2005 3:08 am
they would be suspended in the middle.
if assumptions could fly, airliners.net would be the world's busiest airport
SATL382G
Sat Nov 05, 2005 4:05 am
Quoting Stlgph (Reply 13):
What would happen to the kinetic energy the item developed as it fell to the middle? You would have to dissipate it somehow otherwise the object will tend to continue in motion....
Lots of kids who enjoy swingsets are going to be dissappointed when you explain this and all the swings stop their motion halfway thru there arc....   Also their parents are probably going to be unhappy with you due to the damage done to their offspring from the sudden stop....
[Edited 2005-11-04 20:07:03]
[Edited 2005-11-04 20:09:25]
B744F
Sat Nov 05, 2005 4:56 am
raise your hand, congrats you just defied the "powerful" gravity of earth
What would happen?
First, it has to be hypothetical, because we've yet to get past a few miles, the Russians drilled down the farthest.
Second, it would be possible, but the problems would be the extreme heat, the core of the planet is as hot as the sun.
Third, not much on gravity effects, it would be possible, and according to some scientists, once you get past the liquid between the mantle and the core, you would have zero gravity effects, since that liquid accounts for the gravitational pull to begin with.
And that person would be in a zero gravity environment, but would melt because of said extreme heat and pressure changes.
No because of the pressure from the core and the gravity from the liquid, it wouldn't effect the surface.
But this is all hypothetical, scientists are really guessing through most of it, and our knowledge of our planet past the mantle is extremely little
stlgph
Sat Nov 05, 2005 5:02 am
Quoting SATL382G (Reply 14):
motion would continue. just suspended in a convectional current pattern.
usnseallt82
Sat Nov 05, 2005 5:03 am
Quoting B744F (Reply 15):
Leave it to you to actually think this is possible.  crazy
Crye me a river
B744F
Sat Nov 05, 2005 5:57 am
Quoting Usnseallt82 (Reply 17):
Your super intelligent response to my comments leaves me speachless
Once again, I suggest you quietly sit in the corner since you haven't a clue about the topic at hand
SATL382G
Sat Nov 05, 2005 10:05 am
Quoting Stlgph (Reply 16):
What force would suspend the travel of the body and start it in the "convectional current pattern"?. Let's not forget about conservation of momentum here.
dl021
Sat Nov 05, 2005 10:17 am
Fly....stop drinking and typing! Or dropping acid and staring at album covers by wanna-be Frazettas......  Wink
Are you serious? Dude........stop the insanity! Tell us you know what he's talking about.....
 rotfl
Well, the aliens told him it would work!
Is my Pan Am ticket to the moon still good?
ilikeyyc
Sat Nov 05, 2005 10:22 am
Interesting theory (source?) but I would believe that an object would simply be crushed by the force of gravity as it gets closer to the center of the earth. The inner core of the earth is believed to be solid iron and the most dense of all 4 layers of the earth. Gravity also acts from the center of mass, not the surface or any layer inbetween (such as the mantle in your theory). The Earth is approx. 7,900 miles (12,700 km) in diameter [3,950 miles (6,350 km)] in radius. The equations for gravity are exponential, not linear.
So if I go from the surface (3950 miles from the center of mass) to a point that is half the radius (1975 miles from the center of mass) I have decreased my distance by half, but the gravitational force has quadrupled.
But since someone pointed out that the laws of physics would have to be suspended to even have this scenario, why should we expect to be crushed by the force of gravity?
http://hypertextbook.com/facts/1999/RicardoMartinez.shtml
http://jersey.uoregon.edu/~mstrick/AskGeoMan/geoQuerry8.html
http://csep10.phys.utk.edu/astr161/lect/history/newtongrav.html
Fighting Absurdity with Absurdity!
kaddyuk
Sat Nov 05, 2005 10:26 am
There becomes a point in your "hole" where 'Up' is no longer 'Up'...
Remember DIRECTION is relational  Wink...
swisskloten
Sat Nov 05, 2005 10:28 am
Believe it or not, Hitler thought the earth was hollow and carried out flights in WWII to determine an entry point into the core. His plan was to have the Nazis hide out there if the Allies won the war. Fortunately, he was dead wrong.
dl021
Sat Nov 05, 2005 10:29 am
Yeah, but the Flash is faster than Superman and Aquaman is capable of withstanding incredible pressure found at the bottom of the ocean and J'onn J'onzz is not related to Spike Jonz and Spiderman is not a mutant from birth simply from accident which proves that people should be careful in laboratories with nuclear reactors and spiders.
jafa39
Sat Nov 05, 2005 10:43 am
Some of these answers make 9/11 conspiracy theories seem plausible!!  Smile
We, the undersigned, do hereby consent.....
B744F
Sat Nov 05, 2005 11:38 am
Quoting DL021 (Reply 20):
No, geologists have only been able to theorize
Quoting Jafa39 (Reply 25):
Interesting how you can come to this conclusion, since the experts in the field know very little to begin with
Quoting Ilikeyyc (Reply 21):
According to some scientists, the force of gravity is caused by the molten core which is liquid. Scientists are still not sure what is beyond that, some say solid though. So the theory is that once you are beyond this point of the magnetic field that creates the gravity, you may not feel the effects of gravity at all. But again, it is just a theory, so far scientists are just guessing, and that is all we know
ilikeyyc
Sat Nov 05, 2005 11:50 am
Quoting B744F (Reply 26):
Whoa, whoa, whoa...time out. You mean to tell me that the earth's gravity is created by the magnetic field? [gasp!] I've been lied to by all of my physics teachers! HAHAHAHA. It sounds like you are the one who doing is doing all the guessing. The aliens really did something to your mind! Once again, can I please have a source to this theory?
usnseallt82
Sat Nov 05, 2005 11:54 am
Quoting Ilikeyyc (Reply 27):
Yes.....his sources come from wavelength alpha emitted from the mothership. They are highly reliable and cannot be disputed by us mortal beings. Unfortunately, he is the only one selected to receive these transmissions.....as he has the only tin foil in the world that will work.
 Big grin
Crye me a river
B744F
Sat Nov 05, 2005 11:56 am
How can your physics teachers tell you about something which we know so little about and you can call it the absolute truth?
ilikeyyc
Sat Nov 05, 2005 12:02 pm
Quoting B744F (Reply 29):
Look, the Gravitational LAW (not theory, a proven LAW) is based on mass, not magnetic fields (see my reply, #21). So for you to suggest that gravity comes from a magnetic field is just utterly hilarious!!!
usnseallt82
Sat Nov 05, 2005 12:07 pm
Quoting Ilikeyyc (Reply 30):
You get to listen to him long enough and most of what he says becomes hilarious.  Big grin
The only thing I will throw out there is quantum mechanics. While this field is so largely based on theory right now, it holds lots of weird things that common physics don't allow for. Still, what he churns out is nothing more than interference from his transistor hat.
Crye me a river
dl021
Sat Nov 05, 2005 12:14 pm
 boggled  hypnotized  crazy
B744F
Sat Nov 05, 2005 1:14 pm
oops, my mistake. Long week at work. Anyway, the magnetic field is generated by the liquid core, while the core itself, made out of something unknown, has the most mass, and generates the graviational pull. If you drop something inside that mass, you won't feel the effects of it
Did you ask the same thing of your professors when they told you a particle can only give you its speed or its location, not both. Or how about a pair of electrons, when separated, will spin in opposite directions instantly no matter how far away you put them.
photopilot
Sat Nov 05, 2005 1:48 pm
Damn, I'm going to have to learn to say Beam Me Down Scotty
hahaha,
Steve
usnseallt82
Sat Nov 05, 2005 1:51 pm
Quoting B744F (Reply 33):
welcome to my world of quantum love  Big grin
Crye me a river
SATL382G
Sat Nov 05, 2005 1:56 pm
Well if you know that the material generates a magnetic field and you know it's approximate mass it's not hard to figure out what the material is. In this case it's liquid iron..................
jafa39
Sat Nov 05, 2005 5:23 pm
And the difference is?????
cornish
Sat Nov 05, 2005 5:30 pm
Quoting Banco (Reply 12):
and of course a replacement bus service would be offered on weekends due to "Essential Engineering Works"  Wink
Just when I thought I could see light at the end of the tunnel, it was some B*****d with a torch bringing me more work
KevinL1011
Sat Nov 05, 2005 6:37 pm
Bugs Bunny already did it.
Of course!....Cherynoble!
474218, Carl, You will be missed.
dl021
Sat Nov 05, 2005 10:58 pm
Wow...hey everyone! The aliens are talking to geologists now! Hooray!
Quoting Kevinl1011 (Reply 39):
No...he missed the turn at Albequerque
Mr Spaceman
Sat Nov 05, 2005 11:30 pm
Hi guys.
What would happen?
Finally, you would find Jimmy Hoffa.  eyepopping
Chris  Smile
MD11Engineer
Sun Nov 06, 2005 1:02 am
I had to calculate this problem once as an assignment when I was still studying physics. When you jump into the hole (assuming there is no friction), you will accelerate due to gravity, but since with every meter you fall there is more mass above you pulling you upwards, the acceleration will go from 9.81 m/sec square to zero when you reach the center. Due to your kinetic energy you will fall through the center and will feel an increased deceleration force until you reach the surface on the other side, by which time you will have slowed dwn to standstill. Then you will fall back into the hole, go through the center and come up again on the original side. So no friction involved, you will oscillate through the center of earth forever.
Jan
2H4
Sun Nov 06, 2005 1:31 am
Market this as an amusement park ride, and the revenue generated would pay for the research, construction, and then some.
 biggrin
2H4
Intentionally Left Blank
SATL382G
Sun Nov 06, 2005 1:39 am
Quoting MD11Engineer (Reply 42):
Ok, great as far is it goes. Now, how to compensate for the rotational speed of the earth? At the surface the object will appear motionless in relation to the rest of the earth, but in fact will be moving in a trajectory around the center of the earth at approx. 2000 MPH. Assuming a frictionless environment and considering that objects in motion tend to remain in motion the object will NOT fall in a straight line (in relation to the earth) to the center. What shape will the tunnel take? My puny brain can't quite picture this but I know it's an arc and will intersect the surface and the exact center.
edit: After thinking about it for a minute it'll work like a ball on a roulette wheel perhaps even a arc greater than 360 degrees i.e. a spiral....
[Edited 2005-11-05 17:50:35]
MD11Engineer
Sun Nov 06, 2005 2:29 am
Obviously with a rotating planet and the hole not equal to the axis of rotation the falling body would be subject to the Corriolis force and the path through earth would be a curve looking like a flower, not a spiral.
You can easily plot it with a protractor and a compass.
Jan
SATL382G
Sun Nov 06, 2005 2:58 am
Quoting MD11Engineer (Reply 45):
It's a spiral, there are many examples of the effect in nature. Something lost in translation perhaps?
This video is an even better example of the spiral effect....
http://www.divnick.com/images/Vortx_Medium.swf
Or are you saying that the acceleration of gravity is such that the trajectory becomes ballistic vs. orbital?
[Edited 2005-11-05 19:03:44]
[Edited 2005-11-05 19:09:37]
Jet-lagged
Sun Nov 06, 2005 12:10 pm
Quoting SATL382G (Reply 44):
Yes! So if you are falling down this hypothetical hole, your body would tend to move to the 'east' (since the earth rotates from west to east) and you'll be scraping along the eastern edge of the hole. Before you reach the center you will be a long red stain.
Now, if the hole went from exact north pole to exact south pole, then you could fall, and then oscilate back and forth, rotating around the north-south axis as you went. Wheeee!
Actually, if such a hole suddenly came to exist, I think it would simply immediately collapse.
SATL382G
Sun Nov 06, 2005 12:31 pm
Quoting Jet-lagged (Reply 47):
Exactly, but our engineers will dig a perfect, frictionless hole so the falling body will never contact the east wall. Coming in contact with the east wall would add drag and screw up all physics
I hadn't thought of that. Seems reasonable but given that the earth is orbiting the sun a straightline along the north south axis may not possible either --- that's way to much math for my brain to process though...
On second thought I take that back. The north/south axis is roughly (within 23 deg) perpendicular to the plane of the ecliptic so the velocity along the length of the axis should be pretty much constant. A hole down the axis should be relatively straight.
  That's why we had to suspend reality real early in this thread
[Edited 2005-11-06 04:38:08]
SATL382G
Sun Nov 06, 2005 1:00 pm
Oh BTW:
I just realized there's another factor we haven't accounted for: tidal forces
In other words, the path a falling body takes to the center of the earth will vary depending on where the moons mass is located relative to the falling body.
A hole sufficiently wide might be enough to compensate, but I don't know.
... and I'm tired....
Users browsing this forum: aerlingus747, L410Turbolet and 1 guest
