flymia
Specifications Of Your Car?
Thu Nov 24, 2005 8:17 am
We all seen what kind of car do you drive threads and pictures of your car threads but this time lets see the specifications of you car. Anything engine type, special options, 0-60 times what you like.
I have a 2004 Volkswagen Touareg.
2004 Volkswagen Touareg Specifications or 4.2-liter V8 (310hp @ 6,200 and 302 lb.-ft. @ 3,000) Transmission: Six-speed Tiptronic automatic Drive: Permanent four-wheel drive
Curb weight, lbs 5,300/2409kg Towing capacity: 7,716 lbs/3507kg I get around 10-12mpg equipment: Front, side, and curtain airbags, ABS; traction
0-60 times is around 7.3 pretty good for such a large SUV. 1/4 mile in about 15.6
Top Speed 137mph.
So what does you car have?
[Edited 2005-11-24 00:21:22]
[Edited 2005-11-24 00:23:01]
jafa39
Thu Nov 24, 2005 1:03 pm
Nissan Cefiro (Maxima)
2.0 ltr V6 Auto.
150 Horsepower and quite fast, probably about 125 mph top end.
We, the undersigned, do hereby consent.....
AC777LR
Thu Nov 24, 2005 1:34 pm
Dodge Magnum RT
Type 4-door, 5 passenger full-size wagon
Layout longitudinal front engine, rear-wheel drive (opt.AWD)
Engine 5.7 litre V8, OHV, 2 valves/cylinder, automatic 4
Horsepower 340 @ 5000 rpm
Torque 390 lb-ft @ 4000 rpm
Transmission 5 speed automatic with manual shifting mode
Tires Continental ContiSeal P225/60HR-18 all-season touring self-sealing
Curb weight 1880 kg (4142 lb.)
Towing capacity 907 kg (2,000 lbs.) or 1724 kg (3,800 lbs.)
Wheelbase 3048 mm (120.0 in.)
Length 5021 mm (197.7 in.)
Width 1881 mm (74.1 in.)
Height 1481 mm (58.4 in.)
Cargo area 770 litres (27.0 cu. ft.) rear seats up
2030 litres (71.6 cu. ft.) rear seats down
Fuel consumption City: 13.8 l/100 km (21 mpg)
Hwy: 8.8 l/100 km (32 mpg)
Fuel type Unleaded mid-grade, 89 octane recommended
Unleaded regular, 87 octane acceptable
Warranty 3 years/60,000 km
Powertrain Warranty 5 years/100,000 km
Assembly location Brampton, Ontario
Member since April 2000
prosa
Thu Nov 24, 2005 1:38 pm
2006 Subaru Forester X
2.5 liter horizontally opposed 4-cylinder engine
173 horsepower
5-speed manual
All-wheel drive
"Let me think about it" = the coward's way of saying "no"
trvyyz
Thu Nov 24, 2005 1:45 pm
Oldsmobile Intrigue GL
- 3,791 cc 3.8 liters V6 90deg front transverse engine with 96.5 mm bore, 86.4 mm stroke, 9.4 compression ratio, cast iron block, cast iron head, overhead valve, automatic valve adjustment and two valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 7.8
- Multi-point injection fuel system
- Main 68 liter fuel tank
- Power: 146 kW , 195 HP @ 5,200 rpm; 220 ft lb @ 4,000 rpm
0-60 MPH 8.5 seconds
Top speed 125 mph
aerobalance
Thu Nov 24, 2005 2:15 pm
2006 BMW 330i
Powertrain/Chassis
Drivetrain layout Front engine, rwd
Engine type I-6, aluminum block & heads
Valve gear DOHC, 4 valves/cyl
Bore x stroke, in/mm 3.35 x 3.46 / 85.0 x 88.0
Displacement, ci/cc 182.8 / 2996
Compression ratio 10.7:1
Max SAE net horsepower 255 @ 6600 rpm
Max SAE net torque, lb-ft 220 @ 2750 rpm
Specific output, hp/liter 85.1
Weight to power, lb/hp 13.3
Redline, rpm 7000
Transmission 6-speed Steptronic auto
Axle/final-drive ratio:1 3.64 / 2.51
Suspension, front; rear Struts, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Brakes, f;r 13.0-in vented disc; 13.2-in vented disc, ABS
Wheels 17 x 8.0 cast aluminum
Tires 225/45ZR17 91W
Dimensions
Wheelbase, in 108.7
Track, f/r, in 59.1 / 59.6
Length, in 178.2
Width, in 71.5
Height, in 55.9
Turning circle, ft 36.1
Curb weight (Mfr), lb 3450
Weight dist (Mfr), f/r, % 51 / 49
Seating capacity 5
Headroom, in 37.4 / 37.1
Legroom, in 41.5 / 34.6
Shoulder room, in 55.4 / 55.1
Cargo vol, cu ft 12
0-60 mph, sec 6.3 (MT est)
Consumer Info
On sale in u.s. May of 2005
Base price $37,500
Stability/traction control Yes / yes
Airbags Front side, front & rear head
Basic warranty 4 yrs/50,000 miles
Powertrain warranty 4 yrs/50,000 miles
Roadside assist period 4 yrs/50,000 miles
Fuel capacity, gal 15.9
EPA mpg, city/hwy 21 / 30 (est)
Range, miles, city/hwy 334 / 477 (est)
Recommended fuel Unleaded prem
2005 Nissan Titan SE Crew Cab 4X2
Engine
Endurance 5.6-liter DOHC 32-valve V8 engine
305 hp @ 4,900 rpm
379 lb-ft of torque @ 3,600 rpm S S S
Emissions — LEV S S S
Nissan Direct Ignition System S S S
Platinum-tipped spark plugs S S S
Electronic drive-by-wire throttle S S S
Alternator (130 amps) S S S
Battery (650 CCA) S S S
Heavy-duty battery (710 CCA) [TW] [TW] [TW
Fuel tank skid plate S S S
Additional seven-pin wiring harness [TW] [TW] [TW]
Trailer brake pre-wiring [TW] [TW] [TW]
Drivetrain
Front engine/rear-wheel drive S S S
5-speed automatic transmission with Tow/Haul Mode S S S
Lower final gear ratio (3.357:1); similar to a four-speed
automatic 4.10:1 ratio [TW] [TW] [TW]
2-wheel Limited-Slip (ABLS) (4x2) [T] [T] S
Electronic locking rear differential (4X4) [OR] [OR] [OR]
Brakes
Front vented disc/rear disc brakes S S S
4-wheel Anti-lock Braking System (ABS) S S S
Electronic Brake force Distribution (EBD) S S S
Brake Assist [AB] [AB] [AB]
Suspension and Steering
Front: Independent double-wishbone with stabilizer bar
Rear: Multi-leaf with solid Dana® axle S S S
Engine speed-sensitive power-assisted
rack-and-pinion steering S S S
Wheels and Tires
18" x 8.0" Five-spoke aluminum-alloy wheels S
P265/70R18 Tires with raised outlined white lettering S S
Full-size spare tire S S S
Tire Pressure Monitor System (TPMS) S S S
Styling/Functionality
Class IV receiver hitch [TW] [TW] [TW]
Tow hooks (standard on 4x4 models) [T] [T] S
Chrome bumpers, grille and door handles S S
Extendable tow mirrors [TW] [TW]
Utili-track channel system with four tie-down cleats [UB] S
Factory-applied spray-on bedliner O1 [UB] S
Driver-side lockbox [UB] S
Tailgate illumination [UB] S
Rear 12-volt DC power outlet [UB] S
Locking tailgate with dampened assist S S S
Cargo bed light S S S
Bed rope hooks, stake holder and separator/shelf
provision S S S
Body side moldings S S
Sliding rear window [PR] S S
Rear privacy glass [PR] S S
Rear sonar sensors [PRF] S
Convenience
Air conditioning S S
Power door locks S S
Power front windows S S
Remote keyless entry with remote front windows down S S
HomeLink® Universal Transceiver [PRF] S
Cruise control with steering wheel-mounted controls S S S
Tilt steering column S S S
Variable intermittent speed-sensitive windshield wipers S S S
Door courtesy lights S S
Footwell lights S
Auto-dimming rearview mirror [PRF] S
Digital compass and outside temperature display [PRF] S
Digital clock S S S
Retained accessory power S S S
Battery saver S S S
Transmission temperature gauge [TW] [TW] [TW]
Dual two-way sun visors with extenders and dual
illuminated visor vanity mirrors S S
Power adjustable pedals [PRF] S
Six cup holders and two bottle holders S S S
Grocery hooks (rear cab) S S
Overhead center console [PR] S S
Seating and Appointments
Front captain's chairs with driver-side manual lumbar S S
8-way power driver's captain's chair with manual lumbar [PRF] S
Fold-down front passenger's seat S S
60/40 split fold-up rear bench seat S S S
Cloth seat trim S S
Leather-wrapped steering wheel S S
Leather-wrapped floor-mounted transmission shifter S S
AM/FM/in-dash 6-CD audio system [PR] S
MP3 CD-ROM capability [PR] S S
Radio Data System (RDS) [PRF] S
Steering wheel-mounted audio controls [PRF] S
Eight speakers, including center speaker and subwoofer [RF] S
Satellite radio pre-wiring [PR] S
Nissan Advanced Air Bag System with dual-stage
supplemental front air bags with seat belt sensors
and occupant classification sensor S S S
Roof-mounted curtain supplemental air bags for side
impact and rollover protection for front and rear
outboard occupants [AB] [AB] [AB]
Driver and front-passenger side-impact
supplemental air bags [AB] [AB] [AB]
3-point ALR/ELR passenger seat belt system
(ELR for driver) S S S
Front seat belts with pretensioners and
load limiters S S S
LATCH System (Lower Anchors and Tethers for
Children) S S S
Zone Body construction with front and rear
crumple zones S S S
Hood buckling creases S S S
Energy-absorbing steering column S S S
Pipe-style steel side-door guard beams S S S
Vehicle Security System S S
Nissan Vehicle Immobilizer System S S
4x2 4,835 4,905 5,036
4x4 4,893 4,958 5,097
"Sing a song, play guitar, make it snappy..."
TheRedBaron
Thu Nov 24, 2005 2:20 pm
VW Beetle Turbo
1.8 liter turbo Engine.
K04 Upgrade with Unitronic chip management.
Front mount intercooler
Ram Air intake.
silicone 2.7 inch hoses.
Stage III brakes
Bilstein Coilovers. 18 inch Oz racing superturismos with Goodyear F1 rubber
Miltek High flow cat and remus twin chamber muffler.
Ported intakes and manifolds.
Dinoed to 245 WHP@ 6700 rpm and 267 w torque at 5100rpm
Top Speed 257 km/h (142mph)
The best seat in a Plane is the Jumpseat.
KAUSpilot
Thu Nov 24, 2005 3:33 pm
2006 Ford Mustang GT Deluxe Coupe
4.6 Liter V8 3-Valve Engine
300 horsepower @ 5750 RPM
320 ft/lbs Torque @ 4500 RPM
EPA Estimate Fuel Economy:
18 MPG city/ 25 MPG highway
Fuel Capacity: 16 Gallons
0-60 MPH: 5.3 Seconds
1/4 mile: 13.6 Seconds
tfsphoto
Thu Nov 24, 2005 5:19 pm
Mine has 4 wheels and a sunroof!
Lew  rotf
ACDC8
Thu Nov 24, 2005 5:27 pm
Just the basics:
2000 Ford Mustang GT
4.6L V8
260 HP @ 5000 RPM
302 foot lbs./torque @ 4000 RMP
Fuel economy (city/hwy) 17/26 MPG
Goodyear Eagle F1 245/55 ZR 17
0-100 km/h in 5.9 seconds
A Grumpy German Is A Sauerkraut
oldeuropean
Thu Nov 24, 2005 5:31 pm
Mine is bigger than yours!  Wink
Axel
Wer nichts weiss muss alles glauben
QANTAS077
Thu Nov 24, 2005 5:33 pm
Jaguar XJ 8 sedan
Vehicle 2001 Jaguar XJ8 X308 SPORT Anthracite 5 Speed Automatic Sedan
Body Colour Anthracite
Trim Colour Oatmeal Leather
Doors 4
Seats 5
Cylinders 8
Fuel Type Premium ULP
Capacity 4.0
Gears 5 Speed
Gearbox Automatic
Odometer 65856
Drive Type RWD
ABS Brakes
Central Locking
Immobiliser
Power Windows
Air Bag
Child Restraint
Leather Trim
Sun Roof
Air Conditioning Climate Control
Traction Control Alloy Wheels
Cruise Control
Metallic Paint
Trip Computer
CD Player
ElectricSeats Power Mirrors
Car Alarm Electronic fuel injection Power Steering
17" Alloy Wheels, 8 Speaker Stereo, ABS (Antilock Brakes), Adjustable Steering Col. - Tilt & Reach, Air Cond. - Climate Control, Airbags - Driver & Passenger (Dual), Airbags - Side for 1st Row Occupants (Front), Body Colour - Grille, CD Stacker - 6 disc, Central Locking - Remote/Keyless, Control - Automatic Stability, Control - Traction, Cruise Control, Engine Immobiliser, Fog Lamps - Front, Integrated Security System, Leather Trim (Incl. Seats, inserts), Power Door Mirrors, Power Steering, Power Windows - Front & Rear, Radio Cassette, Rain Sensor (Auto wipers), Sports Seats - 1st Row (Front), Suspension - Sports, Suspension - Touring, Trip Computer, Wood/Leather Steering Wheel, Woodgrain - Gear Knob, Woodgrain - Inserts
MrChips
Thu Nov 24, 2005 6:06 pm
Current Car - 1987 VW Cabriolet
White with white top, white + black interior
181,200 km
1.8L inline-4, 94 bhp @5500 rpm, 110 ft.lb. @3000 rpm - SEE THAT HONDA??? TORQUE FROM A STOCK 4-BANGER!!!
average fuel economy - 29 mpg
0-60 in about 9.5 seconds, top speed of approximately 195 km/h.
other than that, it's bone stock, rust-free, and in fantastic condition.
And if anyone is interested, it's for sale, since I just bought a new car...
1988 Mercedes-Benz 560SEC European model
Navy blue with dark grey leather interior
89,000 km
5.5L V8, 300 bhp @5200 rpm, 333 ft.lb. @3300 rpm
Estimated fuel economy - 16 mpg
0-60 in 7.0 seconds (new), and a limited top speed of 260 km/h (155 mph)
Lots of switches with German labels (very cool), alas, I was expecting a label under the hood saying:
"ACHTUNG!!! DAS MOTOR IST NICHT FUR GEFINGERPOKEN BY DAS DUMKOPFEN!!!"
[Edited 2005-11-24 10:10:28]
Time...to un-pimp...ze auto!
We're Nuts
Thu Nov 24, 2005 7:31 pm
Everything inside is stock....
Signed,
Matt D
Dear moderators: No.
airxliban
Thu Nov 24, 2005 8:43 pm
2000 Volkswagen Jetta GLS VR6
2.8 litre 12 degree V6 engine
174 hp and 180 something ft-lbs of torque
5-speed manual transmission
Black leather.
Nothing like running it through the gears while driving down pacific coast highway.
RobertNL070
Thu Nov 24, 2005 9:28 pm
Lots of testosterone here, I'll tone it down a little:
Peugeot 206 1.6 16v 110pk
0-100 km/h 9.5 seconds
top speed 196 km/h or 122 mph
average petrol consumption 14.9 km/l
CO2 emmissions 159 gram/km
Regards, Robert
[Edited 2005-11-24 13:44:21]
Youth is a gift of nature. Age is a work of art.
JAGflyer
Thu Nov 24, 2005 9:50 pm
Quoting Jafa39 (Reply 1):
The Cerfiro looks more like an Infiniti I30 but with a nissan symbol instead of the infiniti one.
Support the beer and soda can industry, your recycle old airplanes!
TheRedBaron
Thu Nov 24, 2005 10:29 pm
Quoting RobertNL070 (Reply 15):
lots of testosterone here, I'll tone it down a little:
Regards, Robert
I also have a Pug. a 2003 XT 1.6, for my city driving, wonderful little car!
portcolumbus
Fri Nov 25, 2005 12:13 am
2004 Hyundai Elantra
Horsepower @ rpm (ULEV) 138 @ 6000
Torque (lb-ft) @ rpm 136 @ 4500
4-speed automatic 24/32mpg
0-60 = ? 8.4 for the manual version
DfwRevolution
Fri Nov 25, 2005 12:30 am
2003 Honda Accord LX [Sedan- North American version]
Powertrain: 2.4 Liter i-VTEC engine (LEV) 160 HP @ 4800
5-speed manual 26/32 mpg
Body: Silver paint, black cloth interior
Curb weight: 3,000 lbs
TEBGuy
Fri Nov 25, 2005 1:07 am
1986 BMW 5 series
4.0L inline 6 engine (bored out from a 3.5L)
5-speed manual gearbox
power sunroof, windows & doorlocks
CD player
Rear wheel drive
Ricaro racing seats
Momo wheel & shift knob
Numerous performance modifications
0-60 time: dunno, the needle is a blur  Cool (ok, ok, so i've never actually timed it)
Top speed 150mph
Remember, taking off is optional, landing is mandatory.
MiCorazonAzul
Fri Nov 25, 2005 1:23 am
My favorite being:
Black Chrysler 300C Hemi 5.7L V8, 340 HP
Fully loaded (everything Chrysler offers for the car) and also fully customized.
Soon to come as in for Christmas:
Black Chrysler 300C SRT8 Hemi 6.1L V8, 425 HP. Leaving that baby untouched. Only lowering it and putting a two-tone paint job (looks better and distinguish it from my other black 300C) Will also be fully loaded with only Chrysler factory items. No outside customizing (besides paint job)
Yes, I LOVE THOSE CARS!  Big grin
[Edited 2005-11-24 17:29:58]
Live for Today.....tomorrow is NOT guaranteed.
RobertNL070
Fri Nov 25, 2005 1:26 am
Quoting Theredbaron (Reply 17):
Great. But its also makes for good driving out of town!
Regards, Robert  bouncy
DeltaGuy
Fri Nov 25, 2005 1:42 am
SPECIFICATIONS
2000 Chevrolet Camaro SS
Base Price $ 21,515
Price As Tested $ 28,350
Engine Type aluminum alloy pushrod overhead
valve 16-valve V8
Engine Size 5.7 liters / 346 cu. in.
Horsepower 320 @ 5200 rpm
Torque (lb-ft) 345 @ 4400 rpm
Transmission 6-speed manual
Wheelbase / Length 101.1 in. / 193.5 in.
Curb Weight 3439 lbs.
Pounds Per Horsepower 10.7
Fuel Capacity 16.8 gal.
Fuel Requirement unleaded premium, 91 octane
Tires P275/40 ZR17 Goodyear Eagle F1
Brakes, front/rear vented disc / vented disc
Suspension, front/rear independent short-and-long-arm with
coil springs /solid axle with coil springs
Drivetrain front engine, rear-wheel drive
PERFORMANCE
EPA Fuel Economy - miles per gallon
city / highway / observed 18 / 27 / 20
0 to 60 mph 5.3 sec
1/4 mile (E.T.) 13.7 sec
Speed times have come down siginificantly since some work was done
DeltaGuy
A350
Fri Nov 25, 2005 2:11 am
Why do you all have so incredibly small vehicles? I usually move around in that one:
 bigthumbsup
A350
flymia
RE: Specifications Of Your Car?
Fri Nov 25, 2005 6:00 am
Wow Anet has alot of powerful cars eh? I did not expect all that. Its nice to see though  Smile
Dakar
Fri Nov 25, 2005 1:31 pm
2005 BMW F650GS Dakar motorcycle
Gelande/Strasse (Trail/Road in English) Enduro style bike modeled after the Paris-Dakar winning enduro race bike
650 cc single cylinder, dual-spark Rotax
Fuel injected
Anti-Lock Brakes
21" front wheel
17" rear wheel
5-speed gearbox
2-position heated handgrips
Handguards
44 lb/ft torque
50 HP
Approx 105 mph top speed
Best part about it... 65-75 MPG
Shoei helmet
Olympia jacket and pants
BMW and Olympia gloves
AlpineStar boots
Chicane tank bag with hydration bag
When crotch rockets whiz by me, I smile, because I can go off-road at any minute and go riding, they are stuck on the street.
I also have a 2001 Audi A4, 2.8L, 5-speed, Quattro, profile wheels and tires.
Nick
DfwRevolution
Fri Nov 25, 2005 1:35 pm
Quoting FlyMIA (Reply 25):
More proud over-compensating men than anything.
I have no problem with practical  duck
MD11junkie
Fri Nov 25, 2005 5:13 pm
1998 Jeep Cherokee
-4.0 litre, Flat-6 cylinder engine
-215HP
-Max. speed: 195km/h (self test, Jeep declares 180km/h as max. speed)
-4WD CROSSTRAC system
2004 Peugeot 206 HDi
-1.4 HDi (TDCi), Flat-4 cylinder engine
-85HP
-Max. speed: 175km/h
-Fuel consumption: 3lts every 100km at 120km/h - city usage: 5lts every 100km.
Believe me, the Cherokee's mpg is horrible, you DON'T want to know it.}
Cheers! wave
Gastón - The MD11 Junkie
There is no such thing as Boeing vs Airbus as the queen of the skies has three engines, winglets and the sweetest nose!
ozguy
Fri Nov 25, 2005 9:27 pm
Four doors, Four wheels, grab handles for mum and dad, bright yellow Learner plates, forgiving brakes and a decent insurance policy. Luckily - and I mean very luckily a few times - the last item hasn't yet been needed and I'm hoping to keep it that way.
EI747SYDNEY
Fri Nov 25, 2005 10:10 pm
Hi Guys  wave
My car is a Honda Prelude 1992, Black,5 Spd Manual
2.2ltr Engine
Cruise Control
Electric Sunroof
6 Disk CD Changer
Electric Seats  smile
Air Con
Full Digital wrap around dashboard.
Oh yeah...It goes like stink  eyepopping
Rob  wave
''Live life on the edge, Live each and every day like it's your last, Hell you only live once''
sudden
Fri Nov 25, 2005 10:58 pm
Quoting We're Nuts (Reply 13):
Sorry,
but you got to be kidding me!
Me?
Well, lets say I'm beating the shit out of the GTI drivers with my Subaru
Aim for the sky!
Sudden
[Edited 2005-11-25 15:14:34]
When in doubt, flat out!
LGWspeedbird
Fri Nov 25, 2005 11:09 pm
This is what my car has
Ford Fiesta Zetec:
15" 5-spoke alloy wheels
Rear spoiler
Front fog lights
Clear side indicators
Black gear knob with silver insert and
gaiter ring
Choice of five specially-selected fabric trim and body colour combinations
Available with 1.25, 1.4, 1.4 Durashift EST advanced manual petrol and 1.4 TDCi diesel engines
Available in three and five door bodystyles
Electrically-operated heated door mirrors
‘Quickclear’ heated front windscreen
CFC-free air conditioning with air recirculation
I have the 1.4 petrol model in a metallic green colour. I still cant park the damn thing!!  biggrin   banghead
upcoming flights LHR-LAX-HNL-SFO-LHR
cptkrell
Sat Nov 26, 2005 12:23 am
Probably most everyone is familiar with 300C 5.7L, Silverado 5.3L and S10 4.3L specs, so here's my other vehicle just for smiles:
Ford 2810
2.6L 3 cyl diesel
Compression ratio 17.3 : 1
Distributor gear drive fuel injection
Max no load RPM 2200 / rated op RPM 2000
Mechanical, wet disc brakes; right+left+master pedals
gear drive power steering
gear drive independent 1800 RPM hydraulic PTO, 2500 PSI
8X2 manual gearbox, Max road speeds @ 2000 RPM:
(calculated by tachometer and shift pattern - no speedometer)
Gear MPH / KPH
1: 1.73 / 2.79
2: 2.16 / 3.48
3: 3.79 / 6.10
4: 5.16 / 8.30
5: 6.18 / 9.94
6: 7.71 / 12.41
7: 13.52 / 21.76
8: 18.49 / 29.75
R1: 2.49 / 4.00
R2: 8.89 / 14.30
Wheelbase: 75.8 in (1925mm)
OAL: 126.5 (3213mm)
OAW @ min adjusted track: 63.4 (1610mm)
OAH to exhaust (not including roll bar): 79.2 (2011mm)
Min turning radius (using LH or RH brake only): 9.75 ft (2.97m)
Shipping weight w/o optional axle weights: 3475 lbs (1576 kg)
As someone asked in another thread: "Do you ever drive just for the fun of it?"
Yep. Regards...jack
all best; jack
TR763
Sat Nov 26, 2005 1:53 am
1999 Silver VW Passat
armored,
1.8 Turbo,
Tiptronic,
150hp,
20 valve,
I usually can do 370 to 410 km with a full fuel tank,
There's a blue light that imitates xenon - it's actually in my plans to install xenon in this car,
Already with ~ 94.000km
Here it is
Rgs
TR763
Marambio
Sat Nov 26, 2005 2:08 am
Mercedes Benz A 190 Elegance
- Max. speed: 190 kmph
- Acceleration (0 to 100 kmph): 9.4 seconds
- 4.000 rpm @ 180 kmph
- Piston displacement (litres): 1.9
- Piston configuration: 4 in a row
- Transmission: Manual (Stick)
Marambio
aerobalance
Sat Nov 26, 2005 2:09 am
Quoting DfwRevolution (Reply 27):
Yep, the BMW hauls clients around and the Titan hauls test fixtures around - very practical, thank you.....
AA777
Sat Nov 26, 2005 3:10 am
2004 Audi A4 3.0 Ultra- Sport Package
3.0L 30V DOHC V6
220 Horsepower @ 6300 RPM
221 ft Lbs Torque
6 speed manual transmission
0-60 ~6.8 seconds
And of course.... Quattro All-wheel-drive  Smile
-AA777
flymia
Sat Nov 26, 2005 4:19 am
Quoting MD11junkie (Reply 28):
It cant be that bad its a V6. I get around 10-12MPG City and 12-14MPG Highway.
I am guessing 15-18?
MD11junkie
Sat Nov 26, 2005 5:53 am
Quoting FlyMIA (Reply 38):
It's a flat 6. The 4.0l flat-6 engine is the old Cherokee engine but with 24-valves rather than 12. The engine has electronic injection. Even so, it's a 30yr old design. It is a bad.
I usually need 19.5lts every 100km city use, 14lts on the road and 16.1lts going top speed.
Cheers! wave
TR763
Sat Nov 26, 2005 7:26 am
Quoting Marambio (Reply 35):
Have you ever tested it?
Because my father has a 190 elegance too and once in my hands in a highway near São Paulo i got nearly 210km/h!!! What an engine this little car have! I got impressed!
Rgs!
TR763
TheRedBaron
Sat Nov 26, 2005 2:44 pm
As I see some of us Here have a sports car and / or a gas guzzler , and a eco friendly car.
Who else here has 2 cars?
I love the power of the Beetle but is completely useless in city traffic, hence I spend4 days a week in the 206 and 3 on the Bug...
Best regards TRB
My car:
aer lingus
Sat Nov 26, 2005 7:02 pm
2003 Peugeot 307 SW
Engine & Performance:
1,587 cc 1.6 litres in-line 4 transverse engine with 78.5 mm bore, 82 mm stroke 80 kW, 110* BHP@ 5,800 rpm, 147* Nm@4,000 rpm
10.8 compression ratio
Bosch ECU
Exhaust gas recirculation
Drive By Wire electronic throttle
DOHC and four hydraulic operated valves per cylinder
Cast iron block aluminum head
3-way catalytic converter
K&N box air filter
Plastic oil filter
Unleaded fuel 95 octane
Maximum speed (mph): 113, (km/h): 182
*Acceleration 0-100 km/h (secs): 11.9
Emission control level EURO 3 - carbon dioxide level (g/km): 178
*(excluding the use of an K&N filter)
Drivetrain:
Front wheel drive
Manual five-speed transmission with gear lever on floor, 3.418:1 first gear ratio, 1.81:1 second gear ratio, 1.278:1 third gear ratio, 0.975:1 fourth gear ratio, 0.767:1 fifth gear ratio and 3.584:1 reverse
Hydraulic clutch
Steering & Suspension:
Vehicle speed proportional power steering
Independent strut front suspension with anti-roll bar and coil springs , semi-independent torsion beam
Rear suspension with anti-roll bar and coil springs
Brakes:
Front ventilated discs, rear discs
4 Wheel ABS, Brake Assist
Electronic brake distribution
Peugeot/Bosch brake pads
Safety:
Front and rear roof airbag
Driver and passenger front airbag with occupant switch off
Front side airbag
Height adjustable 3-point reel front seat belts with pre-tensioners
3-point reel seat belts on all rear seats
Isofix
EuroNcap Crash Test 4 out of 5 stars: 75% safety on frontal impact, The car strikes a deformable barrier that is offset @ 64kph , 100% safety on side impact, Trolley fitted with a deformable front is towed into the driver's side of the car to simulate a side-on crash @ 50kph
Wheels/Tyres:
15" 7 Spoke Aluminum Alloy Rims
Dunlop SP 300E 195/65 R15 91H
Full size steel spare wheel
Seating:
Row 1: 2 individual seats with seat back table, manual forward/backward, height and recline adjustments
Row 2: 3 individual seats with manual forward/backward and recline adjustments
Row 3: 2 individual seats with manual recline adjustment
Interior Stuff:
Single automatic climate control with air conditioning
6 speaker RDS EON audio player with AM/FM and CD player
2 speaker SW/FM cassette player
Steering wheel mounted remote audio controls
Delayed/fade courtesy lights
Front and rear reading lights
Illuminated driver and passenger vanity mirror
Service interval indicator
External temperature display
Computer with average speed, average fuel consumption, instantaneous fuel consumption and range for remaining fuel
Cloth seat upholstery
Leather covered steering wheel with tilt adjustment and telescopic adjustment
Refrigerated storage compartment glove compartment
Automatic dimming rear view mirror
Front and rear electric windows with one-touch and safety operation
Two 12V sockets
Dimensions & Weights:
Lenght 4,419mm
Width 1,762mm
Height 1,580mm
Load compartment capacity: 137 litre with rear seats up, 1,539 litre with rear seats down
60 litre main fuel tank
2 litre aux fuel tank
Gross vehicle weight 1,940 kg
Exterior Stuff:
Coefficient of drag: 0.33
Body colour front and rear bumpers
Twin complex surface lens halogen bulb headlights
Headlight with height adjustment and dusk sensor
Front fog lights
High mount brake light
Roof rails
Electric foldable mirrors
Fixed rear windscreen with intermittent
Tinted glass on cabin
Heat reflective glass
Windscreen wipers with rain sensor
Part alloy and galvanised non-corrosive body
Glass roof
Problems:
Electronic throttle failed twice
1st gear is locked in place between 2500-3800rpm (unable to change to 2nd)
Unable to change to 1st gear above 3mph
Very hard or impossible to change gear on cold days or when the car hasn't warmed up for a while
The gearbox doesn't seem to suit this car
The Crib of my car  bigthumbsup
Split Scimitar or Sharklets?
Boogyjay
Sat Nov 26, 2005 8:33 pm
Don't worry you're not alone. And yours is already quite good.
Mine:
Peugeot 205 XS
- Engine: 1.4 - 85 bhp - single twin-choke
- Performances:
. * Acceleration:0-100km/h - 0-62mph = 9.5s
. * Top speed: 178km/h - 110mph (I've done 190 on speed indicator)
- Fuel consumption: City 8 to 12 liters/100km or 33mpg (and I thought it was consuming a lot, you US SUV owners are really environment unfriendly  Wink )
The MOST important thing is the pleasure of driving: UNBEATABLE. First, you have a choke, which means that you have as much fuel injected as you push the accelerator, you don't have any electronic injection calculating the optimal in term of consumption/perf/emissions... Today's cars can be very frustrating, they are sterilized.
+ This car can beat a lot of powerful cars in acceleration. I like it when people think they have a more powerful car and are beaten because this one doesn't look powerful. Examples: Peugeot 306 XSi (2.0), Ford Fiesta 1.4Si 16v Zetec, Ford Probe 2.0i 16v, Subaru Impreza 1.8, Mazda MX5 Miata 1.6i, BMW 316i, VW Golf GTi Mk3,  tongue  ...
Here it is (it's not the one I own):
HAJFlyer
Sun Nov 27, 2005 7:31 am
2003 BMW 316 ti
4 cylinder engine
1800 cc
115 hp
165 nm
5 speed manual transmission
Vmax: 200 km/h
0-100 km/h: 10.9 s
Marambio
Sun Nov 27, 2005 8:33 am
Quoting TR763 (Reply 40):
LOL! I have tested it on a highway here, too, and reached 175 kmph. However, since the engine seemed to be doing alright I thought the maximum speed should be around 190 kmph. Now I must test it again!  Smile
Anyway, really nice little car!
Marambio
Users browsing this forum: 1337Delta764, tz757300 and 1 guest
