Twistedwhisper
Are You Good With Word? Real Good?!
Wed Dec 07, 2005 11:42 pm
Here's one for those of you that consider yourselves to be advanced Word users.
I have a form that I need to fill out like 10-15 times per day. In this form there are 6 different fields that I need to put following information in (example text within the brackets:
Flight# (SK943/08)
E.T.A (1830/08)
Master AWB# (117-40503033)
Destination (ORD)
Exit Gateway (CPH)
Special Instructions (KEEP COLD ON ARRIVAL)
Today I use a function where you press F11 to move the marker to the next field, but what I want is a dialogue box with a brief explanation of what needs to be filled in and in what format, i.e. "Please enter the estimated time of arrival in following format: HHMM/DD" and a text box where you enter the data requested and press OK. The text is then transferred to the appropriate box and the next dialogue box comes up, i.e. "Enter flight and date in following format: XX000/DD where XX is carrier code, 000 is flight No and DD is the flight date"
Is there a way to do this without using macros? Does anyone have a ready code example to send me? You can send it to ehagglun@hotmail.com, put airliners.net in the subject....
Read between the lines.
andz
RE: Are You Good With Word? Real Good?!
Thu Dec 08, 2005 2:45 am
hmm, if you had put this through the grammar checker it would have suggested replace "real good" with "really good"
Sorry, I couldn't help it but someone had to get your thread back to the top!
AeroWesty
Thu Dec 08, 2005 2:47 am
What you're really trying to do is make a word processor work like a database app, right? Why don't you just use a database app instead?
International Homo of Mystery
fr8mech
Thu Dec 08, 2005 9:05 am
If I'm not mistaken, it is possible to do exactly what you say in Excel. I've seen it done, but don't know how to do it.
noelg
Thu Dec 08, 2005 9:53 am
The only way you will do this is by creating a macro in VBA and setting it to run when you enter the field. Pretty straightforward:
In the VBA editor, you need to create a userform for each textbox (rt click on the "Project" pane in top left, Insert, Userform).
Design your form with question and textbox using the properties pane on the bottom left to name the question etc.
Add a button for OK, assign the following code:
ActiveDocument.FormFields.Item("text1").Result = UserForm1.TextBox1.Value
UserForm1.Hide
Add a cancel button if you wish with:
UserForm1.Hide
as the code.
Where "text1" is the name of your textbox in Word, UserForm1 is the name of your userform and Textbox1 is the name of the textbox.
In the VBA editor, add a new Sub with the following lines:
Sub Text1ShowUserform()
UserForm1.Show
End Sub
Finally, in the Word Document itself, in the textbox properties under the "Run macro on entry", select "Text1showuserform" from the list.
You should then get something like this:
http://www.marshgiddings.com/aviation/fieldautomationexample.doc
In this example only the first field is automated, so if you tab to the second field and Shift+tab back you will get your result.
Not entirely sure how to set the focus automatically to the next field though, the SetFocus function seems to only work for the window rather than individual controls.
All the code is there!
Hope this helps.
Noel
SpinalTap
Thu Dec 08, 2005 12:48 pm
A simple but not particularly elegant way would be to use Excel and Insert comments in the cells where data is to be entered. Comments can be entered by right clicking on a cell then selecting "Insert comment" from the menu. The comments will then appear when you run the mouse cursor over the cell.
Otherwise its VBA I'm afraid. It can be done very easily if you have a basic knowledge of VBA or another modern programming language but if you are completely unfamiliar with any programming language it may seem difficult.
"I get what they call a stipend, a stipend is like money but its such as small amount they don't really call it money"
Users browsing this forum: jetero, salttee, TheF15Ace and 35 guests
