richardnhsv
Help With Older Topic
Wed Dec 28, 2005 11:53 pm
A while ago (month or so) someone posted a topic about a website that we would add a dot on the map representing where we live. Does anyone remember the link? I tried the search function, but can't remember the title of the topic.
Thanks for your help.
regards,
Richard
"If you've ever had a filet this good, welcome back." - Ruth Fertel
kiwiandrew
RE: Help With Older Topic
Thu Dec 29, 2005 12:03 am
Hi Richard
one way is to use the Great Circle mapper
for example
use the following entry ( you have to start with "< img scr " and finish with " > " - but dont use the inverted commas )
=http://gc.kls2.com/cgi-bin/gcmap?PATH=akl,bru
to produce the following map showing AKL and BRU - you just replace akl and bru with the point(s) you want to show
richardnhsv
Thu Dec 29, 2005 12:08 am
Thanks kiwi, that's one of the ones i was looking for. The other one was similar to google maps with the inverted water drops. Thanks for such a quick answer, though!
regards,
richard
andz
I know the map he means, it put little flags on the map to show where you are and you can put your name and a comment, I searched back through the archived topics but couldn't find anything.
richardnhsv
Thu Dec 29, 2005 12:09 am
Andz... that's the one....!!!
andz
Thu Dec 29, 2005 12:15 am
I searched "map" and "live" in the older topics going back to January but didn't find anything, maybe something more obscure in the search might turn something up.
richardnhsv
Thu Dec 29, 2005 12:16 am
i've been searching for about an hour trying to use different combinations...even googled it...nothing...
thanks for your help
richardnhsv
Thu Dec 29, 2005 1:18 am
Found it...
The service is called Frappr
Thanks for the help kiwi and Andz!
richard
Users browsing this forum: flyguy89, wingman and 1 guest
