Leezyjet
The Poo Name List!
Mon Jan 16, 2006 6:58 am
The Poop Name List
The Perfect Dump - Every once in a while, each of us experiences a perfect dump, it's rare, but a thing of beauty in all respects. You sit down expecting the worst, but what you get is a smooth sliding, fartless masterpiece that breaks the water with the splashless grace of an expert diver. But that's not the end of it. You use some toilet tissue only to find that it was totally unnecessary. It makes you feel that all is right with the world and you are in perfect harmony with it.
The Beer Dump - Talk about nasty dumps. Depending on the dumper's tolerance, the beer dump is the end result of too many beers. it could have been 2 or 22, it doesn't matter. What you get is a sinister, lengthy, noisy dump accompanied by a malevolent fog that could close a bathroom for days.
The Chili Dump - Hot when it goes in, and rocket fuel when it leaves. The chili dump stays with you all day, making your tush feel like a heat shield.
The Cable Dump - Long, curly and perfectly formed like 2 feet of E13 telephone CO-axial cable. It loops lazily around the bowl, like a friendly serpent. You wonder admiringly, "DID I DO THAT? Where did it come from?" you leave the bathroom pleased with yourself.
The Latrine Dump - In case you didn't know, a latrine is a hole in the ground with a tent around it where soldiers, boy scouts and flies go to dump. Tip: Don't ever, ever look in the hole.
The Mona Lisa Dump - This is the masterpiece of dumps. It's as perfectly formed as it can be. Delicate and slender with intricacies that would make da Vinci weep. And just think, you made it yourself. You may even want to break out the Polaroid, but maybe that's going a bit too far.
The Empty Roll Dump - You're done...you reach for the toilet paper only to discover that empty cardboard cylinder. A mild panic begins coldly in your throat. You could use the curtains...no, someone would say "Where are the curtains?" Then what would you say? The rug?...too cumbersome. Then you must come to the same conclusion that every "empty roll dumper" must face...Pull up your slacks, tighten your tush and wriggle yourself to the nearest full roll.
The Splash Back Dump - You send the dump on its way, it drops like a depth charge into the bowl creating a column of cold bowl water that washes your bottom with a startlingly unpleasant shock. Now you're wet and embarrassed.
Tip: Blot instead of wiping.
The Aborted Dump - You are in mid-dump when the phone rings. What do you do? ABORT! Pinch it off, go for the phone, and save the rest for later. It isn't pretty, but you've gotta do what you gotta do
The Caesarian Dump - Pain, that's what this dump and childbirth have in common. Its simply a case of too much dump trying to go through too small a hole, and there's no obstetrician to help.
The Alfresco Dump - Everyone has had to go outdoors from time to time. This can be a rather pleasant experience really. The open air, the nature, and a good bush all contribute to the peaceful ambiance that our primitive forefathers must have enjoyed. What can screw up this harmonious interlude is a troop of brownies or a patch of poison ivy.
The Childbirth Dump - This is a dump that is simply too big to go through the aperture provided by nature for the purpose. You sit there, thinking over your dilemma. First it hurts, and it isn't going to get any better. You wonder if you'll ever see your loved ones again. You imagine the newspaper headlines screaming "Man dies trying to hatch monster loaf". You realize you'll have to resolve the crisis before you can leave the bathroom. Basically there are only three things you can do:
1. Scream
2. Call an Obstetrician
3. Hope like hell have enough Vaseline to get you through it.
The Tijuana Trot Dump - The phrase "Sh*t Happens" really applies here in a big way. When the ice in your tainted margarita makes contact with your lower intestinal tract, the fun begins. For the next 72 hours you'd be better off if you carried your own portable toilet with you because you will spend most of that time on the pot and the rest of the time in a fetal position. Now you realize why Mexico never had a navy.
The Machine Gun Dump - You're just sitting there in a state of sublime peace when all of a sudden you emit a group of noisy gassy bursts that break the silence like machine gun fire. The guy in the next stall hits the floor like a combat veteran cradling his umbrella like an M16...damn commies.
The Sound Effect Dump - You feel a noisy one coming on. Relatives, friends or work mates are within earshot, so you must employ some clever techniques to cover the disgusting sounds you are about to emit. Timing is obviously very important here. At the precise moment of release, try the following sound effects:
1. Flush the toilet
2. Sing the first two stanzas of your national anthem
3. Drop a handful of quarters on the floor
The Security Dump - You have enough on your mind when you're in the bathroom without worrying about a lockless door and someone bursting in to find you in mid-dump mode. So how can you prevent this embarrassing spectacle from taking place? One way is to strategically place your foot against the door. If you can't reach to do this...hum loudly
The Cling-On Dump - For the most part you've completed your dump, but there's one little morsel that refuses to drop off. You're getting impatient. Someone else wants to use your stall. So, you grip the seat with both hands and wriggle, twist and pump but that last little stubborn piece just hangs there, suspended, clinging like a canned peach between you and the bowl water. Maybe the person pounding impatiently on the door has scissors
The Houdini Dump - You go, then you stand up to flush, and the darn thing has disappeared. Where'd it go? Did it creep down the pipe? Did you dream the whole thing? Is it lurking out of sight? Should you wipe...maybe you should just to make sure you went. Should you flush? you'd better, because if you don't, you know it will reappear and smile at the next person who comes in
The Flu Dump - You feel so bad that you don't know which end of you to put down first. You have roaring cramps, so you sit down. Then a wave of nausea rolls over you like a cold fog, so you stand up and cramps squeeze your intestines like a vice so you sit down again...up down up down. Don't you wish Mom were close by?
The Porta-Pottie Dump - Construction workers and outdoor concert goers will tell you about going in a portable toilet. My best description would be, "Its like taking a shit in an upright coffin". Its claustrophobic and it smells bad...best advice...go in a paper cup.
The Proctologist Dump - In the beginning, the lord created the earth, the sky and the firmament, but I hope he didn't create this dump, because there is nothing biblical about it, you run out of gas. That's right, you run out of propulsion. The dump is right there at the end of your barrel and refuses to go any further. You grunt, you squeeze, you wriggle but it just stays there like a lump of lead. You've only got two choices here. One is to squeeze the damn thing back up your intestine and wait until next time. The other is to pretend you're a proctologist and go after it yourself. Not a pretty picture is it??
The Whole Roll Dump - No matter how much you wipe, it doesn't seem to be enough. You blow the whole roll and you have to flush 25 times too. The whole episode is consumer waste.
The Graffiti Dump - You flush the dump and the swirling motion of the receding bowl water forces the dump to the porcelain sides, scraping a creative squiggle on its way down. You flush again but the curlicue hangs there...love it or leave it. Its your choice.
The Encore Dump - Ahhhh, you're done, so you wipe, put yourself together, wash your hands and are about to vacate the bathroom when you feel another dump coming. You have to return for a curtain call. The world's record is seven encores.
The Born Again Dump - This is a dump that's going so badly, you say "Lord, if I live through this, I'll take up religion" you always get through it, but seldom keep the promise you made in desperation, because a born again dump is like childbirth...you forget the pain quickly.
Ghost Poopie
The kind where you feel the Poopie come out, but there's no poopie in the toilet.
Clean Poopie
The kind where you poopie it out, see it in the toilet, but there is nothing on the toilet paper.
Wet Poopie
The kind where you wipe your butt fifty times and it still feels unwiped, so you have to put some toilet paper between your butt and your underwear so you don't runie them with a stain.
Second Wave Poopie
The kind that happens when you're done poopie-ing and you've pulled your pants up to your knees, and you realize you have to poopie some more.
Turtle Poopie
The kind of poopie that pops out a little and goes back in a few times before it finallly comes out
Pop-a-Vein-in-your-Forehead-Poopie
The kind where you strain so much to get it out, you practically have a stroke.
Lincoln Log Poopie
The kind of Poopie that is so huge you're afraid to flush without first breaking it into little pieces with the plunger.
Gas-sy Poopie
The kind where it's so noisy, everyone within earshot is giggling!
Drinker Poopie
The kind of Poopie you have the morning after a long night of drinking. It's most noticeable trait is the skid marks on the bottom of the toilet.
Corn Poopie
(Self explanatory)
Gee-I-Wish-I-Could-Poop Poopie
The kind where you want to Poopie, but all you do is it on the toilet and fart a few times.
Spinal Tap Poopie
That's the kind when it hurts so badly coming out, you swear it was leaving you sideways.
Wet Cheeks Poopie (The Power Dump)
The kind that comes out of your butt so fast, your butt cheeks get spashed with water.
Liquid Poopie
The kind where yellowish-brown liquid shoots you of your butt and spashes all over the toilet bowl.
Mexican Poopie
The kind that smells so bad your nose burns.
Upper Class Poopie
The kind of Poopie that doesn't smell.
The Suprise Poopie
You are not even at the toilet, because you are sure you are about to fart, but, OOPS---a Poopie!
The Dangling Poopie
This Poopie refuses to drop into the toilet even though you know you are done poopie-ing. You just pray that a shake or two will cut it loose.
Fisherman's Bobber Poopie
You are in a public restroom with two people waiting on your stall, you poopie and flush two times, but several golfball pieces are still floating above the water line.
Question is - which will you have next ?
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
pogo
RE: The Poo Name List!
Mon Jan 16, 2006 7:20 am
Quoting Leezyjet (Thread starter):
Also known as drawing an ace.
When in doubt give it a clout
planesarecool
Mon Jan 16, 2006 7:27 am
What about a toffee poopie? The one that sticks to the bottom the toilet and doesn't budge without the use of the brush? I'm good at those!
aerorobnz
Mon Jan 16, 2006 7:54 am
LOL that list is great. I was ticking them off as I went down the list.
Flown to 126 Airports in 47 Countries on 80 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
Airplanepics
Mon Jan 16, 2006 8:22 am
One of the funniest things I've ever read in this forum. Classic.
Simon - London-Aviation.com
JBLUA320
Mon Jan 16, 2006 8:28 am
OH MY GOD THIS IS THE SINGLE BEST THREAD I HAVE EVER READ ON AIRLINERS.NET YOU MADE MY LIFEEEEEEEEEEEEEEE.
Leezyjet, you are on my RU list. THANK YOU.
JBLU
nhgrafx
Mon Jan 16, 2006 9:20 am
Just what I have always wanted. An encylcopedia on pooping. I shall call it "The Encyclopoopia".
Is it weird I have a RemoveBeforeFlight pitot cover on my car rear view mirror?
PMN
Mon Jan 16, 2006 9:22 am
Quoting Pogo (Reply 1):
Also known as the 'freebie'. Always more than welcome after a night on the beer  Smile
Paul
Edith in his bed, a plane in the rain is humming, the wires in the walls are humming some song - some mysterious song
dazultra
Mon Jan 16, 2006 9:23 am
this thread is a load of shit.
 rotfl
good one Leezy  Wink
eaglekeeper101
Mon Jan 16, 2006 9:45 am
This list should be required reading in the event that NASA launches a manned flight to Uranus.
Sorry, couldn't resist  Smile
"The earth is but one country, and mankind its citizens." - Bahá'u'lláh
Logan22L
Mon Jan 16, 2006 10:11 am
Your forgot to mention the "Mile-long." That's where one end disappears down the pipe - for all you know, the leading edge could already be at the wastewater treatment plant - the other end is perched majestically in the bowl above the water-line.
"The deeper you go, the higher you fly. The higher you fly, the deeper you go."
AR1300
Mon Jan 16, 2006 10:21 am
This is simply amazing.How true!!By far one of the best non av threads!!THX!!
mike
You are now free to move about the cabin
aaden
Mon Jan 16, 2006 2:41 pm
lol oh god
your a funny man
AGC525
Mon Jan 16, 2006 3:15 pm
I have one I call "Mt. Everest". Bascially it's just piled up in the toilet, with some sticking out of the water. When you toss the toilet paper in, it looks like clouds around the peak of Mt. Everest.
 Smile
American Aviation: From Kitty Hawk to the Moon in 66 years!
Garri767
Mon Jan 16, 2006 3:17 pm
lmao!!!!!!!!!!!!!!!!!!!!! this thread is hilarious , someone was bored! but made good use of their time! lol
Two wrongs may not make a right, but three lefts do!
skidmarks
Mon Jan 16, 2006 5:58 pm
Quoting AGC525 (Reply 13):
While having a dump can be a satisfying experience, I feel looking at it afterwards and then decorating it is a step too far!!
Shit!! Big grin
Andy  old
Growing old is compulsory, growing up is optional
ABfemme
Mon Jan 16, 2006 6:43 pm
 rotfl   rotfl   rotfl   rotfl   rotfl
Here in the UK we in the medical fraternity have what's called a 'Bristol stool form chart' made up by a drug company advertising a drug called MOVICOL
It's hilarious, there's pics of poo and they're in types 1 - 7
1. Separate hard lumps, like nuts (hard to pass)
2. Sausage-shaped but lumpy
3. Like a sausage but with cracks on the surface
4. Like a snake ( !!!!!) or sausage, smooth and soft...............another sausage LOL
5. Soft blobs with clear cut edges ( passed easily)
6. Fluffy pieces with ragged edges, a mushy stool
7. Watery, no solid pieces EXTREMELY LIQUID
It is meant to be serious but is so funny so a copy of it is pinned to our bathroom door and always causes a laugh when visitors visit the loo !!
Leezyjet - great descriptions !!!
Claire  Silly
Women do not have hot flushes, they have power surges
n229nw
Mon Jan 16, 2006 8:06 pm
Dude, this is hilarious. But, erm, people, Leezyjet didn't write it. At least the second half has been going around on the internet for a lond time. Good post though.
By the way, this is my favorite, because the wording here just cracks me up:
OOPS---a Poopie!
All Glory to the Hypnotoad!
777
Mon Jan 16, 2006 8:27 pm
Soory but I can't resist...
The Fart Name List
The Alarm Fart - This is a good fart for the beginner. It is easy to identify. It starts with a loud unnaturally high note, wavers like a siren, and ends with a quick downward note that stops before you expect it to. It sounds like something is wrong. If it happens to you, you will know right off why it is called the Alarm Fart. You will be alarmed. The alarm fart however is rare.
The Amplified Fart - This is any fart that gets its power more from being amplified than from the fart itself. A metal porch swing will amplify a fart every time. So will a plywood table,and empty fifty gallon drum, a tin roof, or some empty cardboard boxes if they are strong through being amplified in this way can be called an Amplified Fart. These are common farts under the right conditions
The Anticipated Fart - This one warns that it is back there waiting for some time before it arrives. A person who is uneasy for a time in a crowd and who later farts at a time when they think no one will notice has farted an Anticipated Fart.
The Back Seat Fart - This is a fart that occurs only in automobiles. It is identified chiefly by odor. The Back Seat Fart can usually be concealed by traffic noise as it is an eased-out fart and not very loud. But its foul odor will give it away, due to the way air moves around in a car. It is often followed by someone saying, "Who farted in the back seat?"
The Barn Owl Fart - A familiarity with owl calls is helpful in identifying this fart. Almost any morning if you get up just before daybreak you can hear one of these birds talking to himself. It's a sort of a crazy laugh, particularly the way it ends. If you hear a fart that has about eight notes in it, ending on a couple of down notes, and it sounds maniacal, you have heard the rare Barn Owl Fart.
The Bathtub Fart - People who would never in their life know one fart from another, who would like to act like fart don't exist, will have to admit that a Bathtub Fart is something special. It is the only fart you can see! What you see is the bubbles. The Bathtub Fart can be either single or multiple noted and fair or foul as to odor. It makes no difference. The farter's location is what does it. Maybe there is a kind of muffled pong and one big bubble. Or there may be a ping ping ping and a bunch of bubbles. The sound I should point out depends somewhat on the depth of the water, and even more on the tub. If it is one of those big old heavy tubs with the funny legs you can get terrific sound effects. While one of the new thin ones half buried in the floor can be disappointing.
The Biggest Fart in the World Fart - Like the great bald eagle, this fart is pretty well described just by its name. This can either be a group one or a group two fart and can occur just about anywhere. I heard it one time, a group two identification, in a crowded high school auditorium one night, right in that silence that happens when a room full of people has stopped singing the Star Spangled Banner and sat down. It came from the back. There was not a soul in that room that missed it. A fart like that can be impressive. The most diagnostic characteristic of the Biggest Fart In The World is it size.Fart freaks who go around showing off, farting like popcorn machines, and making faces before they fart or asking you to pull their finger and then they fart, never have what it takes for this one, which is rare even among your most serious farter's.
The Bullet Fart - Its single and most pronounced diagnostic characteristic is its sound. It sounds like a rifle shot. The farter can be said to have snapped it off. It can startle spectators and farter alike. Fairly common following the eating of the more common fart foods, such as beans.
The Burning Brakes Fart - A silent fart identified by odor alone. Usually and adult fart, occurring while the adult is driving a car or has a front seat passenger who farts. The Burning Brakes Fart actually does smell a little like burning brakes, and seems to hang around longer than most farts Which gives whoever farted a chance to make a big show of checking to see if the emergency brake has been left on. When he finds it hasn't you know who farted. A common automobile fart.
The Car Door Fart - Either a group one or a group two fart. Very tricky. It is meant to be a concealed fart. A matter of close timing is involved, the farter trying to fart at the exact moment he slams the car door shut. It is usually a good loud fart. It is one of the funnier farts when it doesn't work, which is almost every time. It is a desperation fart and not too common.
The Celestial Fart - Not to be confused with the Did An Angel Speak Fart, which is simply any loud fart in church. The Celestial Fart is soft and delicate, surprising in a boy or an adult. It is probably the most shy of all farts and might be compared with the wood thrush, a very shy bird. It does not have the sly or cunning sound of the Whisper Fart. It is just a very small clear fart with no odor at all. Very rare.
The Chinese Firecracker Fart - This is an exceptional multiple noted fart identified by the number, and variety of its noises, mostly pops and bangs. Often when you think it is all over, it still has a few pops and bangs to go. In friendly company this one can get applause. Uncommon.
The Command Fart - This fart differs from the Anticipated Fart in that it can be held for long periods of time waiting for the right moment. Unlike the Anticipated Fart, it is intended to be noticed. Harold Tabor recently held a Command Fart for the whole period in history class and let it go right at the end when the teacher asked if there were any questions.
The Common Fart - This fart needs little description. It is to the world of farts what the house sparrow is to the world of birds. I can see no point in describing this far any further.
The Crowd Fart - The Crowd Fart is distinguished by its very potent odor, strong enough to make quite a few people look around. The trick here is not to identify the fart but the farter. This is almost impossible unless the farter panics, and starts a fit of coughing or starts staring at the ceiling or the sky as though something up there fascinates him. In which case he is the one. Very common.
The Cushioned Fart - A concealed fart, sometimes successful. The farter is usually on the fat side, sometimes a girl. They will squirm and push their butt way down into the cushions of a sofa or over-stuffed chair and ease-out a fart very carefully without moving then or for some time after. Some odor may escape, but usually not much. Common with some people.
The Did An Angel Speak Fart - This is any loud fart in church. This fart was first called to my attention by my father. He probably read about it somewhere. For fart watchers who go to church, this is a good one to watch for as this is the only place it can be found.
The Dud Fart - The Dud Fart is not really a fart at all. It's a fart that fails. For this reason it is strictly a group one identification fart, because there is no real way you can identify a fart that somebody else expected to fart but didn't. It is the most private of all farts. In most cases the farter usually feels a little disappointed.
The Echo Fart - This is a fart that can be wrongly identified. It is not some great loud fart in an empty gym or on the rim of the Grand Canyon. The true Echo Fart is a fart that makes its own echo. It is a two-toned fart, the first tone loud, then a pause, and then the second tone. Like an echo.
The G and L Fart - This is one of the most ordinary and pedestrian of farts, known to everyone. Certainly it is the least gross. If you have not already guessed, G and L stands for Gambled and Lost. One of the most embarrassing of all farts, even when you are alone.
The Ghost Fart - A doubtful fart in most cases, as it is supposed to be identified by odor alone and to occur, for instance, in an empty house. You enter and smell a fart, yet no one is there. People will insist that only a fart could have that odor, but some believe it is just something that happens to smell like a fart.
The Hic-Hachoo-Fart Fart - This is strictly an old lady's fart. What happens is that the person manages to hiccough, sneeze, and fart all at the same time. After an old lady farts a Hic-Hachoo-Fart Fart she will usually pat her chest and say, "My, oh my," or "Well, well." There is no reason she should not be proud, as this is probably as neat an old person's fart as there is.
The Jerk Fart - The Jerk Fart is a fart by a jerk who smirks, smiles, grins, and points to himself in case you missed it. It is usually a single-noted, off-key, fading away, sort of whistle fart, altogether pitiful, but the jerk will act as if he has just farted the Biggest Fart in the World Fart.
The John Fart - The John Fart is simply any ordinary fart farted on the john. It is naturally a group one identification, with the sound, whatever it was, somewhat muffled. If it is all the person's trip to the john amounted to he will be disappointed for sure. Common as pigeons.
The Lead Fart - The heaviest of all farts. It sounds like a dropped ripe watermelon. Or a falling body in some cases. It is the only fart that goes thud. Except for the odor, which is also very heavy, it could be missed altogether as a fart. What was that, you might think? And never guess.
The Malted Milk Ball Fart - Odor alone is diagnostic and positively identifies this fart. It smells exactly like malted milk balls. No other food works this way. It is rare.
The Oh My God Fart - This is the most awful and dreadful stinking of all farts - a fart that smells like a month-old rotten egg - as the Oh My God Fart. If you should ever encounter it, however, you may first want to say, oh sh*t, which would be understandable.
The Omen Fart - This is the adult version of the Poo-Poo Fart. About the only difference is that the farter will not say anything. He will just look kind of funny and head for the john. This one is easy to spot if you pay attention.
The Organic Fart - Sometimes called the Health Food Nut Fart. The person who farts an Organic Fart may be talking about the healthy food he eats even when he farts. If he is heavily into health foods he may even ask if you noticed how good and pure and healthy his fart smells. It may smell to you like any other fart, but there is no harm in agreeing with him. He is doing what he thinks is best.
The Quiver Fart - A group one identification fart only. When you fart, it quivers. If it tickles, then it is the Tickle Fart. If you have to scratch it, then it is the Scratchass Fart.
The Rambling Phaduka Fart - You must not be fooled by its pretty-sounding name, as this is one of the most frightening of all farts. It is frightening to farter and spectator alike. It has a sound of pain to it. What is most diagnostic about it, however, is its length. It is the longest-lasting fart there is. It will sometimes leave the farter unable to speak. As though he has had the wind knocked out of him. A strong, loud, wavering fart, it goes on for at least fifteen seconds.
The Relief Fart - Sound or odor don't matter on this one. What matters is the tremendous sense of relief that you have finally farted. Some people will even say, "Wow, what a relief." Very common.
The Reluctant Fart - This is probably one of the oldest farts known to man. The Reluctant Fart is a fart that seems to have a mind of its own. It gives the impression that it likes staying where it is. It will come when it is ready, not before. This can take half-a-day in some instances.
The Rusty Gate Fart - The sound of this fart seems almost impossible for a fart. Is is the most dry and squeaky sound a fart can make. The Rusty Gate Fart sounds as if it would have worked a lot easier if it had been oiled. It sounds like a fart that hurts.
The S.B.D. Fart - S.B.D. stands for Silent But Deadly. This is no doubt one of the most common farts that exists. No problem of identification with this one.
The Sandpaper Fart - This one scratches. Otherwise it may not amount to much. You should remember that if you reach back and scratch, it automatically becomes a Scratchass Fart. Common.
The Skillsaw Fart - A truly awesome fart. It vibrates the farter. Really shakes him up. People back away. It sounds like an electric skillsaw ripping through a piece of half-inch plywood. Very impressive. Not too common.
The Sonic Boom Fart - The people who believe in this fart claim it is even bigger than the Biggest Fart In The World Fart. The Sonic Boom Fart is supposed to shake the house and rattle the windows. This is ridiculous. No fart in the world shakes houses and rattles windows. A fart that could do that would put the farter into orbit or blow his crazy head off.
The Splatter Fart - Unfortunately the Splatter Fart exists. It is the wettest of all farts. It probably should not be called a fart at all.
The Stutter Fart - If you think stuttering is funny, this is a very funny fart. It is a fart that can't seem to get going. The sound is best described as pt,pt,pt-pt,pt-pt-pt,pop,pop-pop-pop-POW! It is usually a forced-out fart that gets caught crossways, as they say, and only gets farted after considerable effort.
The Taco Bell Fart - The Taco Bell Fart is far richer and full-bodied than your ordinary Junk Fart and takes longer to build up. Sometimes hours or even a day. But it will get there. And it will hang around after, too. Even on a windy day.
The Teflon Fart - Slips out without a sound and no strain at all. A very good fart in situations where you would rather not fart at all. You can be talking to someone and not miss saying a word. If the wind is right he will never know.
The Thank God I'm Alone Fart - Everyone knows this rotten fart. You look around after you have farted and say, "Thank God I'm alone." Then you get out of there fast!
The Tickle Fart - A group one only and one of the easiest to identify. Usually a slow soft sort of fart. If you like being tickled this is the fart for you!
BA380
Mon Jan 16, 2006 8:56 pm
what a wonderful thread. Best I have read in ages. Nice work, fella!
cabin crew: doors to automatic and cross-check...
Users browsing this forum: BobPatterson, LittleFokker, phluser and 2 guests
