wardialer
Playstation 2 HELP...URGENT...
Sun Feb 05, 2006 10:07 am
I had played DVDs before on my PS-2 before without any issues and I just rented out a DVD and I started playing it...But it will not play because its asking for Parental Control Password....This is very strange because I had tried playing DVDs before without any issues like I said...
Its asking me for a password but I dont know it...I dont know why this particular DVD which I rented will not play unless I have the Parental control password....
This is very strange...VERY VERY VERY WEIRD...
KaiGywer
Crew
RE: Playstation 2 HELP...URGENT...
Sun Feb 05, 2006 10:08 am
Try 0000. It works in mine.
wardialer
Sun Feb 05, 2006 10:10 am
This is very very very strange because every DVDs I have will AND WILL play without issues...Why would this one will not play...???Beats me...
I will try 0000....
Will that work for sure???
KaiGywer
Crew
Sun Feb 05, 2006 10:11 am
Not for sure. That's why I said try  Wink
wardialer
Sun Feb 05, 2006 10:13 am
Nope..I picked 0 and I kept on tapping the X button and no go....
Whats next???
Am I basically screwed??
WHY IS THIS HAPPENING?????!!!!
wardialer
Sun Feb 05, 2006 10:20 am
How come it will not play this DVD and the otheres will play?? Please, I need to see this.....Please help...
This is the weirdest and strangest thing I ever saw..
jutes85
Sun Feb 05, 2006 10:25 am
PC FTW
nothing
NeilYYZ
Sun Feb 05, 2006 10:26 am
Where did you rent the DVD from and is the PS2 new or did you buy it used?
If you bought the PS2 used then perhaps a rating control was put on by the last owner and you would have to contact them to get the release code. Or perhaps the DVD that you rented is a pirated copy, although I doubt that if you rented it from a reputable place.
- Neil
It may be too early to drink scotch... But it is NEVER too early to think about it...
NeilYYZ
Sun Feb 05, 2006 10:29 am
I'm bored so I looked up how to break the Parental Lock code on the internet -
Here is how it's done.
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
http://www.techlore.com/article/10505/
Hope this helps.
- Neil
wardialer
I got it from a friend....But I doubt that he would put a code on it..And I rented the DVD at blockbuster.
Is there anyway to trick it or something?
wardialer
Sun Feb 05, 2006 10:33 am
I am already confused at step 1...
Do I have to put the DVD in the tray in order to do this?? All it says (without) the DVD inside is Browser or System Configuration...
I dont understand
NeilYYZ
Sun Feb 05, 2006 10:39 am
I have no idea, I have an XBOX, try it both ways though, once with the disc, and once without.
- Neil
wardialer
Ok..I got it...Thanks alot...
But I cannot turn off the parental control because the lowest number is 1 instead of OFF....Where can I turn this OFF??
DLKAPA
Sun Feb 05, 2006 10:43 am
Wow, for the way you're blowing this up it's almost like you're trying to watch porn...o wait it's a.net, of course you're trying to watch porn!
Meethinks you need to get out more  Wink
NeilYYZ
Sun Feb 05, 2006 10:47 am
The man's profile says he's between 21-25, I say let him watch whatever he want's, it's not for Sony to say.
- Neil
Users browsing this forum: stratosphere and 1 guest
