Gilligan
Computer Help Please
Fri Feb 10, 2006 7:56 am
Yesterday I tried to install some new ram memory in my computer. Somehow I managed to fry the motherboard, don't ask me how. I've installed new memory before and never had this kind of trouble. Took it to the local big box store that sells audio/video and appliances and they told me it would be cheaper to buy a new machine than fix the old one. So I bit the hook and spent 650 bucks on a new machine. Today at work, talking to the tech guys, they said I could have easily replaced the motherboard and probably used the recovery disc provided by the manufacturer to get things running again. Yes? No? Maybe? I can still take the new computer back if I can get the old one going. Like to save myself the 650 bucks.
Warm winds blowing, heating blue skies, and a road that goes forever, I'm going to Texas!
JAGflyer
RE: Computer Help Please
Fri Feb 10, 2006 7:58 am
What are the specs of the old comp? That should help us determine if it worth replacing the motherboard.
If you flew today, thank a Flight Dispatcher!
nighthawk
Fri Feb 10, 2006 8:04 am
Im guessing its a desktop system, in which case yea, all you need to do is replace the motherboard, this will cost you less than $100.
If you can post what kind of processor your using, someone will be able to recommend a suitable motherboard for that type. If its a fairly old machine your only option will be a second hand mobo, but someone on ebay will have one!
NeilYYZ
Fri Feb 10, 2006 9:42 am
Quoting Nighthawk (Reply 2):
Thats right. Replacing the motherboard will cost around 100.00 depending on what type you are using. As long as you have the knowledge of how to remove the old one and hook everything up to the new one then it shouldn't be a problem at all. I have replaced many a motherboard in my days, I have a penchant for overclocking. By all means try to get the motherboard replaced. Sounds like the sales guys just wanted a little comission.
- Neil
It may be too early to drink scotch... But it is NEVER too early to think about it...
David L
Fri Feb 10, 2006 10:03 am
Quoting NeilYYZ (Reply 3):
That's the key although I'd be very surprised if "repairing" the old one would have cost 650 bucks. It would surely cost less than that for the dealer either to fit a new board or just maybe fix a broken track or three. If neither option is available then it just isn't repairable, which isn't the same as being more expensive to repair than buying a new machine!
Klaus
Fri Feb 10, 2006 10:20 am
An "OEM" or "Restore" version of Windows may or may not work with a different Motherboard... It may miss drivers for specific hardware components the original motherboard didn't have...
David L
Fri Feb 10, 2006 10:55 am
Quoting Klaus (Reply 5):
Smart@rse Smile! Yes, I hadn't thought about that but, as I see it, either it can't be done or it would still be cheaper to replace/repair the motherboard if possible than to buy a new PC. I just wonder if the dealer made that judgement without really thinking about it. That's why I have "real" copies of Windows on my desktops - for modular upgrades.
Gilligan
Fri Feb 10, 2006 11:08 am
It's an emachine T2862. The processor is a Celeron D 330. It's only a little over a year old, just outside the warranty of course. I'd like to salvage it if I could and save a few hundred. Thanks for all your help.
Cadet57
Fri Feb 10, 2006 11:19 am
Quoting Gilligan (Reply 7):
That new of a machine, fix it, MO-BO's are a cinch, but you got to know what your doin.
but it can be tricky, i've seen a few e-machines and they all had a proprietary mo-bo. But i've also just as easily put in a brand new aseus mb to replace it. Id go to a local coputer shop, screw the big boxes and have him or her pop in a new one, itd probly take all of 20 mins to install and restore your system.
Justin
Gilligan
Fri Feb 10, 2006 11:21 am
So I would have to buy a new version of Windows to fire it back up?
dan2002
Fri Feb 10, 2006 12:53 pm
Quoting Gilligan (Reply 9):
No.
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
Users browsing this forum: ha763 and 13 guests
