KaiGywer
Crew
Installing Linux
Wed Mar 08, 2006 11:13 pm
Hey there. I have an older computer that I'm not using. I want to install Linux on it, just to try it out. It is a P3 450 Mhz, with 192 Mb RAM and 6.5Gb HDD. Would this be good enough to run Linux?
Also, I tried installing Red Hat a long time ago, but could never figure it out. Are there any other versions that are more "Windows-user friendly"?
Any Linux people out there, please help me out  Smile
Go3Team
RE: Installing Linux
Thu Mar 09, 2006 1:21 am
That computer should be good enough to run Linux. I have run it on slower computers with success. IMO Red Hat is one of the easiest flavors to use, with the graphical interface of course. Good Luck.
Yay Pudding!
hawaiian717
Thu Mar 09, 2006 12:11 pm
What's called Red Hat these days costs money, however they support a free version that is essentially the development wing for Red Hat, called Fedora. The installer is pretty easy, it works much like Windows. A graphical installer that you just point and click. I haven't tried Ubuntu, but hear some good things about it being easy to work with, so that might be worth looking into as well.
traveler_7
Thu Mar 09, 2006 6:09 pm
I used SUSE and think that it is quite "Win-user friendly".
Also Mandriva suppose to be quite easy to use, configure and install, but never tried myself.
MD11Engineer
Thu Mar 09, 2006 7:16 pm
I use SuSe Linux with KDE as a GUI on a 5 year old machine with an AMD Duron processor comparable to a P3 (don't ask me for the frequency) and 40 Gb HDD. The only thing I did was to boost the RAM to about 400 MB (the more the better), the computer works fine with it.
SuSe Linux comes with an installer and system control program called YAST, which does most of the configurations on installation and update. It's user interface is largely intuitive and can be set to support many languages.
Jan
KaiGywer
Crew
Thu Mar 09, 2006 9:36 pm
And since Linux is free, I can download this, right? Any good and fast sites?
jush
Thu Mar 09, 2006 9:38 pm
Well the newer Linux distributions are almost as easy to install as Windows releases. But I'm not so sure wheter you can run Linux on that configuration.
Regds
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
traveler_7
Fri Mar 10, 2006 12:05 am
Quoting KaiGywer (Reply 5):
In some case you can download live iso images burn it on CD or DVD and first play and see if your hardware functions well.
Also you can download full installation CD or DVD usually links to the mirrors a provided in the site of distribution.
Many distributions could be installed on-line in this case you just have to prepare boot CD and find mirror site which is close to you
KaiGywer
Crew
Fri Mar 10, 2006 1:49 am
Quoting Traveler_7 (Reply 7):
Any good links?
yowza
Fri Mar 10, 2006 1:52 am
In a word Fedora is what you're looking for.
http://fedora.redhat.com/
YOWza
traveler_7
Fri Mar 10, 2006 4:50 am
Quoting KaiGywer (Reply 8):
Any good links?
http://www.novell.com/products/suselinux/index.html
http://www.knoppix.com/
here http://distrocenter.linux.com/
you can find links to the most popular distributions together with short description.
seanp11
Fri Mar 10, 2006 5:04 am
My brother is an advocate of Gentoo. He uses it on his laptop.
I have heard that Kunbutu is very easy for the non Linux user.
I use Fedora Core on P4 workstations at school.
I recommend you go shopping and see what distro works best for you.
traveler_7
Fri Mar 10, 2006 5:25 am
Quoting Seanp11 (Reply 11):
I think that KDE is what makes Linux friendly for "Win-users"
As to ubuntu and kubuntu I am not sure that it is more easy compare to SuSE with KDE
hawaiian717
Fri Mar 10, 2006 11:31 am
Gentoo is my first choice for myself, but I don't recommend it to someone unless they're interested and willing to spend a bit of time getting to know it. The new installer probably makes things a lot easier, but it would still probably prove daunting to someone new to Linux.
Plus, this is going onto older hardware, which most people might not like with Gentoo. Gentoo doesn't install binary packages; by default everything is downloaded and compiled from source. While it's an automated process that works extremely well, it does take time. On old hardware (like the 10 year old machine that I run my web site on), a lot of time.
Stas
Fri Mar 10, 2006 12:45 pm
I suggest Ubuntu for any person who would like to learn Linux. I find Ubuntu the friendliest distribution which is perfect for both a newbie and a professional user. You could get it for free at www.ubuntu.com. Also, check out www.distrowatch.com where you can find reviews of various distributions.
UAalltheway
Fri Mar 10, 2006 1:38 pm
Quoting Traveler_7 (Reply 3):
I've had really bad experiences with SuSe in the past, especially trying to get it installed. I reccomend you stay away from it.
saxdiva
Fri Mar 10, 2006 2:37 pm
Another distribution with a reputation for being friendly is Mandrake. My personal experience with it was that it wasn't *quite* as easy to deal with as I had hoped--it seemed to be a bit on the buggy side when I last used it. But others have had better luck, I guess.
On the other hand, I've run Fedora (Red Hat's community-supported distribution) on two different machines, and found installation and updates on that to be very simple. Just make sure you've got a pretty good idea of what hardware you've got installed, in case you need to track down a rogue driver or something.
-Leanne
Users browsing this forum: Bing [Bot] and 39 guests
