Jalto27R
USB-Attachable Storage?
Sat Mar 18, 2006 1:51 pm
Hi guys. I'm not much of a computer techie, but I know the basics. For awhile now my family computer has run extremely slow, and I think it might have alot to do with my music library. I was interested in buying one of those cards you can insert into the USB port, and store so much stuff on it. I figure it would help with the speed of my computer. Any advice would be greatly appreciated.
Mike
NeilYYZ
RE: USB-Attachable Storage?
Sat Mar 18, 2006 4:24 pm
Get a Sony with the MicroVault. It automatically compresses the files when you move them to your USB storage drive and decompresses them when you move them back onto a regular hard drive. Worth the money in my opinion. I have a 1GB USB drive that I got off of eBay and I am very pleased with it. While you might pay more for the name brand Sony, I am not sure if any other brand has the MicroVault technology, which I suppose is not that fancy, but like you, I'm not that computer savvy and I quite like how the Sony USB drive works, it also has a key ring on it if you feel so inclined as to carry it around with your house keys.
- Neil
It may be too early to drink scotch... But it is NEVER too early to think about it...
eilennaei
Sun Mar 19, 2006 5:04 am
Quoting Jalto27R (Thread starter):
4 out of 5 home computers are infected with a malware of some kind. A mysterious slowing down is the most common symptom.
airbusA346
Sun Mar 19, 2006 5:14 am
Quoting Eilennaei (Reply 2):
Does AdAware check for Malware, becuase I can't remember.  Sad
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
eilennaei
Sun Mar 19, 2006 5:39 am
The best tool for detecting browser-related malware is I think Spy Sweeper ( www.webroot.com ) Unfortunately the trialware now only informs of, will not remove the pests. If you encounter anything browser-related, there's a very good chance an active net virus/worm will be found as well, but you'll need another tool for them, e.g. trialware from www.f-secure.com .
desertjets
Sun Mar 19, 2006 5:40 am
If you have a large music library a USB flash drive isn't going to be big enough to fit much. I have a 2GB one I use at work, and with everything on it (including a full back-up of all my work files) I have half a gig left.
I'd suggest you invest in a proper spyware and anti-virus software, burn any important files to CD-Rs (really the least expensive solution) and do a complete system scan.
nighthawk
Sun Mar 19, 2006 6:34 am
Is your hard disk full? If so then your computer will run slower, and freeing up space (such as by deleting MP3s) will help.
A 1G USB Flash disk will cost you �30-50, whereas a 120G hard disk will cost about the same amount. If its just extra space you need, buy a new hard disk.
Check also your computers memory usage, right click on the taskbar, and select "Task Manager" then click the performance tab. Have a look under "Physical Memory (K)" and check the "available" is showing a reasonable amount. With no programs running you want to have at least 100,000 available, even more ideally. Anything less than this and your computer is going to struggle running applications.
hawaiian717
Sun Mar 19, 2006 7:38 am
First thing to definitely check is do a sweep for viruses and spyware. I usually use both AdAware Personal and Spybot Search & Destroy for spyware, as no one program catches everything. If you don't have any antivirus software, AVG is a good free option.
AdAware: http://www.lavasoft.com/software/adaware/
Spybot: http://www.spybot.info/
AVG: http://free.grisoft.com/
As far as moving your music library to external storage, I definitely suggest going with a hard drive like Nighthawk suggested. If your music collection is that big, a 1 or 2 GB flash drive won't make that much of a difference. NeilYYZ's suggestion of a MicroVault drive won't help much either. Most likely your music is in MP3, WMA, or AAC format, all of which are already compressed and adding further compression won't make much of a difference. You can see this for yourself -- create an archive folder in XP, which is really a Zip compressed file, and put one of your songs into it. You'll see that the compressed folder isn't much smaller than the original. If you music is in an uncompressed format like WAV, than converting them to a compressed format will make a huge difference.
As an alternative to the hard drive, you could burn the music to a CD-R. By creating an MP3 cd (where you copy the MP3 files to the disc like any other file), you can get a lot more onto one disc than if you burn it as a standard Audio CD. There are some CD players out there now that can handle MP3 CDs, but many cannot. You can still use the CD on your computer. The downside is that you won't have access to all of your music at the same time.
Jalto27R
Sun Mar 19, 2006 10:27 am
Thanks guys. I have Spybot, Adaware, Norton Anti-Virus, and run another anti-virus every so often, and nothing ever seems to come up. Yet our computer is so ridiculously slow it drives me nuts.
Mike
EGGD
Sun Mar 19, 2006 10:30 am
I don't see the point in getting a Flash Drive/USB Stick when you can just get an external Hard Drive. They run on either USB or Firewire and are just as simple to install as a small USB Stick but can be up to 300gb in storage rather than 1 or 2 gig. They're slightly more expensive but definitely worth it.
Users browsing this forum: Baidu [Spider], Bing [Bot], fr8mech, jetwet1, SoJo, tommy1808, UltimateDelta, UltimoTiger777 and 2 guests
