KaiGywer
Crew
Please Help Me With A Dodge Caravan
Thu Mar 23, 2006 9:38 am
Hey there. I promised my friend I would help him troubleshoot why his tail lights won't work (I suspect a shorted wire), and was wondering if anybody here has the repair manual for the 96 and newer Dodge Caravan. If you do, and have a scanner, any chance you could scan the page with the wiring diagram for tail lights?
Any help would be appreciated.
Kai
saxdiva
RE: Please Help Me With A Dodge Caravan
Thu Mar 23, 2006 9:41 am
Kai,
I've got a 2003--would that work?
-LEanne
Superfly
Thu Mar 23, 2006 9:48 am
KaiGywer:
Is his instrument panel lights out too?
I used to have a Chrysler LeBaron convertible and the tailights went out as did the instrument panel lights. The short was found under the dash. The rubber coating had rubbed off exposing the copper wire to bare metal causing the short.
Bring back the Concorde
KaiGywer
Crew
Thu Mar 23, 2006 9:52 am
Quoting Saxdiva (Reply 1):
I believe they are the same model, so should help.
Quoting Superfly (Reply 2):
Don't know. I will ask him.
Cadet57
Thu Mar 23, 2006 9:57 am
Quoting KaiGywer (Reply 3):
They are, 96- 04/5 i beleive, but i know the 96 and 03 are the same.
FiddleSticks
Thu Mar 23, 2006 10:25 am
The current bodystyle Caravan was introduced in 2001 so the manual you'd need would be for the 1996 through 2000 model vans. The 2001 and newer models are different so manuals for those wouldn't be much help.
I would either visit a bookstore for a manual or drop by the closest Dodge dealership and see if they'd let you take a look at that particular manual.
If you love yourself, go now to western union and send me the sum of $10,000 to save your life.
Dougloid
Thu Mar 23, 2006 10:28 am
I will help you with advice. Tell your friend to go to a bar in the seediest part of town. Park the POS in the lot with the keys in it. Take a taxi home and forget about the entire affair. Call the cops and the insurance man. Buy a Mazda.
Now....how do I know all this?
Simple. I had a 1987 Voyager that I bought brand new, and scrupulously maintained-professional aircraft mechanic, the best of care. The last 75,000 miles and four years it was a money pit, and I was under it every damned weekend trying to keep it running or it was in the Plymouth dealers getting some hugely expensive component replaced.
air conditioning never worked worth a damn
$750 bowling ball plastic carburetor died
radiator blew up
both halfshafts destroyed
axle boots every four months
rear axle bearings
alternator
$500 timing gears and chains
2 head gaskets
two exhaust systems
front end and McPherson struts self destructed
wouldn't run in the rain
finally the transmission died with a hole in it a block from home. Good thing-the engine was shot too.
the guy who towed it away acted as if he was doing me a favor.
all that to get a lousy 216,000 miles out of it which must be some kind of a fucking record.
KaiGywer
Crew
Thu Mar 23, 2006 10:31 am
Quoting Dougloid (Reply 6):
Lol. That's almost what happened the first time. Somebody broke into it, stole his golf clubs, a bunch of Burger King coupons (must have been hungry) and then opened the fuse box and ripped out the entire fusebox, as well as cut every wire under the hood.
Dougloid
Thu Mar 23, 2006 10:38 am
Quoting KaiGywer (Reply 7):
The radiator actually DID blow up. The top and bottom tanks were plastic and they always wept a little along the seam. So one day me and mamasan are in the van putting along in town, not a particularly hot day, plenty of coolant, all temps normal and I hear from under the hood: POOT! and this big cloud of steam comes out.
The top tank blew off. It was lying there.
What a huge nasty piece of shite and expensive at that.
They're like Fiats-good if you dump them every three years or 60,000 miles, but beyond that, you're toast.
petmbro
Thu Mar 23, 2006 12:46 pm
While not a minivan but still in the Chrysler family, My parents use to own a 1993 Grand Cherokee. Never a problem with the good 'ol AMC I6 but practically every electrical component that came from Chrysler was replaced. They replaced the radio 4 times in 10 years, put a computer in for $1000, 3 ignition switches, 3 front axles, you name it and it probably was replaced. This Jeep was bought new by my parents and was always very well kept. She made it to just under 229,000 before they got tired of it and gave up. If you're into vans, then avoid Chrysler/Plymouth/Dodge unless you like throwing money away.
"don't pee on my leg and tell me it's raining!" - Judge Judy
saxdiva
Thu Mar 23, 2006 4:04 pm
Hey, Kai,
I forgot to mention that my dad is a retired Dodge service advisor, and the shop just brought him back for a few months to help out. I'm supposed to call him tomorrow and he'll try and get that diagram for me. He also asked if your friend had ever towed anything with this van; apparently, it's common for people to short the lights out by having a wire touch a trailer hitch (or something like that), and he says that if that's the case, it should be as simple as replacing a fuse. You might check into that... meanwhile, I'll find out tomorrow if he's got what you're looking for.
Leanne
Superfly
Thu Mar 23, 2006 4:06 pm
KaiGywer, Petmbro, Dougloid:
I can relate to the horror stories of owning a front-drive Chrysler product.
My 1987 Chrysler LeBaron convertible was a very beautiful car that stayed in showroom condition, even when I got rid of it in 2003. That's because it spend half it's life in the repair shop. I learned to be an excellent mechanic the 5 years I had that car.
My best advice would be to get rid of the Caravan and buy the Dodge Magnum instead!
That has all the cargo room you need and best of all, it's a rear-drive Hemi powered V8.
Same gas milaged as the minivan, yet twice the power.
Now that is something Chrysler CAN do right!
If you insist on a minivan, go for the GMC Safari. Again that is a rear-drive van with a potent 4.3 V6.
Don't buy a Mazda, that's just silly.
Front-drive vans should have NEVER happened.
[Edited 2006-03-23 08:14:12]
Dougloid
Thu Mar 23, 2006 11:25 pm
Quoting Superfly (Reply 11):
93 Mazda MPV rear wheel drive. Love it.
Dougloid
Thu Mar 23, 2006 11:28 pm
Quoting Fumanchewd (Reply 12):
Fumanchewd From United States, joined Jun 2005, 704 posts, RR: 0
Reply 12, posted Thu Mar 23 2006 09:24:09 UTC+1 and read 19 times:
Thats dishonest and not right. You have no "credibility".
Don't you recognize satire when you see it?
I would have been perfectly happy to give you my Voyager.
KaiGywer
Crew
Thu Mar 23, 2006 11:35 pm
Quoting Saxdiva (Reply 10):
Hey, Kai,
Leanne
Awesome. As far as I know, he hasn't towed anything. He said the problems started when somebody ripped his van apart in the parking lot. He had a "mechanic" get it back up and running, but it keeps burning the wire he said. I'm gonna check it out on Saturday, but it would be nice to have the schematics. Send me an email through the interface if you get a hold of them.
Kai
Hehe, he's buying a Mustang convertible, but needs a winter beater.
fumanchewd
Fri Mar 24, 2006 3:29 am
Quoting Dougloid (Reply 13):
My bad. I was drunk and all worked up about some stupid tomatoes.
In the time of chimpanzees, I was a monkey...
Superfly
Fri Mar 24, 2006 4:31 am
Quoting Dougloid (Reply 12):
...and best of all, Mazda is owned by Ford.  Smile
Dougloid
Fri Mar 24, 2006 11:52 am
Quoting Superfly (Reply 16):
Well, I was looking for a Toyota Previa because I am finished with expensive and fragile front wheel drive setups but I could not find one at a price I wanted to pay. I got the Mazda with everything working fine and 90,000 miles on it for $2,400. It's a lot better than my Voyager was brand new.
Tom in NO
Fri Mar 24, 2006 12:34 pm
I've got a '96 Grand Caravan that my dad gave us about three years ago. They bought a Honda Odyssey. While I'm glad he gave it to us, and it enabled me to outgrow my '93 Saturn (which was having its own issues), it's now become a money pit.
I had to replace the transmission in it about 18 months ago, and just a couple of weeks ago I had to change the solonoids/sensors. Now I'm starting to notice a slight shake in the tranny when shifting from low into second. Friggin' Aamco ripped me off. It's also got numerous minor leaks in both the oil lines and the a/c lines, that aren't major issues in and of themselves, but I ain't laying out the $2,500 I've been quoted to fix everything.
I should have bought that Mercury Mariner I was ogling a month or two before Katrina, though Superfly's Safari idea sounds like a winner.
Tom at MSY
[Edited 2006-03-24 04:36:37]
TheRedBaron
Fri Mar 24, 2006 1:21 pm
Love this site !
Someone ask for advice on how to flush a bathroom and off come a lot of bozzos speaking of subatomic particles....
STAY ON FREAKING TOPIC....
I have the Manual for that particular Minivan:
First remove the lower dash over the pedals
Locate the switch to the brake lights (easy is a cable that goes into a plastic dohikey)
That plastic part has to be removed (its easy)
Buy the switch for less than 15 USD$, replace it and reconect.
It has a piston that can be adjusted so the brake lights, light up at the ammount of depressing the pedal you want to set...
It wont be a fuse since the rear left and right light have diferent fuses and the probability of both going at the same time is ASTRONOMICAL.
Best regards and if you have further Question do not hesitate to ask...
Best regards TRB
The best seat in a Plane is the Jumpseat.
KaiGywer
Crew
Fri Mar 24, 2006 9:34 pm
Quoting Theredbaron (Reply 19):
The brake lights work fine.
Yeah, it's not a fuse. What happened is that when the knuckleheads ripped apart his fusebox, it all had to be put in place. Somewhere along the line, I'm believing a short happened. The mechanic who fixed reinstalled the wires, but it has since then burned twice, according to my friend. Exactly what he means with burned, I don't know. I will bring my voltmeter with me and do some poking around.
Thanks for any advice you have Big grin
halls120
Fri Mar 24, 2006 9:54 pm
 rotfl
Quoting Dougloid (Reply 8):
A guy in my carpool bought - against all advice - a 2001 Dodge Stratus. Before the car hit 60,000 miles, he had a blown head gasket, the water pump crapped out, and the alternator died.
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain, a Biography
KaiGywer
Crew
Fri Mar 24, 2006 10:07 pm
Quoting Halls120 (Reply 21):
I have the big brother myself, and I'm very happy with it (98 Interpid). I bought it in Aug 04 with 84,000 miles on it. It currently has 126,500, and all I've had to change was the ignition cylinder and idler tension pulley. (Plus the stuff I broke when I crashed obviously...lol). My tires are starting to get bad, and of course maintenance items (plugs, oil, filters etc.)
Users browsing this forum: aerlingus747, BobPatterson, einsteinboricua, Francoflier, UltimoTiger777, vc10 and 2 guests
