WhyWhyZed
I Need Webhosting Help! (TedTAce!)
Fri Jun 23, 2006 9:19 pm
I need some help. I'm trying to try something out on my webhosting, it's called "Mambo". Anyways, I uploaded all the necessary files through my FTP software, and it's all there. I then have to go to the folder I hosted it to, and it'll load an installation form page. Now... On one of the steps, I'm stumped. I can't figure out the information that is required. Here is a screenshot of the form...
What is the hostname? I've tried everything from yyzmeet.org, yyzmeet, to my member username in any way possible, i've tried EVERYTHING?! Where can I find it?
BTW, if this may by any chance be of any help... I use Globat.com webhosting and my username for everything there is WhyWhyZed or whywhyzed.
Thanks alot, to anyone who can help me out. (TedTAce  Smile)
nighthawk
RE: I Need Webhosting Help! (TedTAce!)
Fri Jun 23, 2006 9:36 pm
your "hostname" is the location of your MySQL database, check with your hosts for the address. The chances are its on the same machine, so using "localhost" will work 75% of the time..
You do have a mySQL database..???
ba757
Fri Jun 23, 2006 9:38 pm
localhost is what it would be if you were running it locally.
The hostname for a mysql database could be slightly different from your domain, I know mine is, however its fairly common for your domain to be the hostname.
Check your hosts FAQ's, it will be listed there. One last thing, you have a mysql database don't you?
Adam
[Edited 2006-06-23 14:45:10]
ba757
Fri Jun 23, 2006 9:43 pm
I have just had a look at your hosts site quickly.
You do have a mysql database and you create and manage them in your hosts control panel. I guess it will tell you the hostname for it there.
The database is on another server (it says :Separate MySQL servers) so localhost won't work.
Adam
TedTAce
Fri Jun 23, 2006 10:35 pm
YYZ, thanks for the faith in my abilities in such things however, I'm a hardware, not a software guy. You want ideas on good hardware setups, Networks, fault tolerance, UPS/Generators. I'm your man. The person I know ho would likely have the BEST answer to this (I have not comment on above (though they seem good) as I don't know) would be Wukka.
This space intentionally left blank
FlyKev
Sat Jun 24, 2006 2:11 am
Quoting WhyWhyZed (Thread starter):
Ah another Mambo user. Fine, Im now a Joomla user, but I did use mambo before doing the convert.
How I set my sites up:
You should have your database setup details from your webhost. Look at these, they should include the usernames here, and again your password. I don't know how your host does it, but thats how mine work.
In your hosts FAQ they mention:
'If you are creating databases for your own applications, the MySQL server will be localhost and the username and password are whatever you choose when creating the database.'
Hope this helps, and Im glad to meet another Joomla/Mambo user (its a great system).
Kev.
WhyWhyZed
Sat Jun 24, 2006 3:28 am
Thanks everyone, I should have actually knew this but I guess I wasn't thinking straight this morning.
Quoting TedTAce (Reply 4):
It'll be awhile till I start touching any of the hardware. lol. I'd do more damage than good. Thanks for the reply though.
Quoting FlyKev (Reply 5):
Don't be jumping to conclusions. I'm just testing it out. It seems alright for a newbie, someone in a hurry or both (me).
FlyKev
Sat Jun 24, 2006 7:45 am
Quoting WhyWhyZed (Reply 6):
Never underestimate the power of Joomla/Mambo. Its not a weak system.  Wink
Kev.
Users browsing this forum: 777222LR and 11 guests
