airxliban
Macroeconomics Help
Mon Jun 26, 2006 8:56 pm
I've got a Macroeconomics exam tomorrow and I have been studying for it but not quite enough unfortunately (Derivatives at 14:30 BST today).
So I thought I would be really cheeky and post some macro questions on here in the hope that some fellow a.nutters could lend me their ears.
These questions are quite interesting, I reckon. With the exception of the 3rd one, I think they may be of wider interest to more than just the economists among us.
Here goes:
1. Is there any good reason to expect output to follow a cyclical patten over time?
2. How can one account for a short-run tradeoff between unemployment and inflation?
3. How would you judge a long-run growth model to be satisfactory?
4. Why has inflation targeting become so popular?
5. Why might a country fix its exchange rate?
Thanks in advance!
comorin
RE: Macroeconomics Help
Tue Jun 27, 2006 8:08 am
Quoting AirxLiban (Thread starter):
Yes, since demand is also cyclical. Cyclicality results from a system seeking equilibrium. Any perturbation in demand will cause a lagged response in output, and the swings ( overshoots and undershoots) occur as things catch up and reach equilibrium again. You have analogues in the physical world - control systems, damped springs and so on.
Any increase in the inflation rate will cause the Central Bank to increase interest rates. This makes borrowing costlier and slows down the economy. This in turn leads to fewer new jobs in the sort term until equilibrium is reached.
DK
Greenspan believed that inflation was an insidious corrosion of wealth as purchasing power dipped, and this is the view of most economists today in the industrialized world. Monetary policy today is aimed at controlling inflation, taking precedence over other objectives such as employment or GDP growth.
Countries fix their exchange rate for one of two reasons. First they may want to support a rate that keeps their goods and services cheaper than if the currency floated (China). Secondly, They could also peg their local currency to the dollar to dollarize their economy and remove FX risk to foreign investors and provide cost stability to local importers. I think Argentina did this for a while, if I remember correctly.
PS: I also do brain surgery in my spare time!  Wink
N174UA
Tue Jun 27, 2006 8:57 am
Economists, as well as businesses, always look to tomorrow and beyond, and not focus on today. Therefore, price stability is ultra-critical, so if businesspeople can reliably forecast say, 3-4% inflation every year, they can budget more accurately both short term and long term.
I think a more appropriate question is why would a country fix it's rate, and not let it float in the international market? If a nation has a fixed exchange rate, they are going to have to continually buy or sell its cash reserves in order to maintain that specified rate. If a nation's exchange rate is fixed, the BP curve will be steeper (inelastic). Refer to the IS-LM-BP discussion in your text.
I just finished Macro at Seattle Univ. this Spring...got a B, only because I tanked on the Aggregate Supply and Demand part. Interesting topic, but the theory is complicated and abstract. I should be able to answer the rest, but they seem subjective, so I guess as long as you can support yoru answers with relevant theory and data, you should be OK!
Good luck on your exam!
airxliban
Tue Jun 27, 2006 9:35 am
Thank you, gentlemen, for the responses. Exam is in 8 hours. I'm screwed. Will report back in 12 hours.
KevinL1011
Tue Jun 27, 2006 9:55 am
Seasonal Demand and Product life cycle
When inflation rises, demand drops. When demand drops, production drops and fewer workers are needed.
By NET earnings. Net earnings (profit) should increase 3-5% annually.
Because Consumer Confidence and Personal Disposable Income are directy affected.
Because Inflation or Deflation is out of control.
[Edited 2006-06-27 02:59:02]
474218, Carl, You will be missed.
airxliban
Tue Jun 27, 2006 3:54 pm
Exam in 1 hour 10 minutes, going to DIEEEEEEEEEEEEEEEEEE
airxliban
Tue Jun 27, 2006 9:12 pm
Wow - actually passed. Test wasn't that bad. I answered questions on persistent unemployment, monetary policy implementation changes and of course the comparison between fixed and floating rates.
Thanks guys.
comorin
Tue Jun 27, 2006 10:04 pm
Congrats! Now GET SOME SLEEP!!  Wink
airxliban
Tue Jun 27, 2006 11:59 pm
Quoting Comorin (Reply 7):
Fixed income exam tomorrow Sad then two more on Friday before freedom!
comorin
Wed Jun 28, 2006 9:55 pm
OK, so how did it go? I'm curious about the type of questions you got in Fixed Income...
All the best!
airxliban
Thu Jun 29, 2006 1:12 am
Part A (50% marks): Answer ALL questions
1. State Irving Fisher's Theory of interest. Can the real interest rate be negative? Now, consider an economy that is expected to grow in the future and where inflation is expected to decrease due to contractionary monetary policy. What would happen to real and nominal interest rates? Explain your ansewr.
2. Consider two portfolios with the same duration. Under which conditions would the change in their values when interest rates change be the same? Explain your answer.
3. What is the difference between the Basel Accord and the proposed New Basel Accord? How would the regular optimally adjust banks' risk-weights when loan default increases? How would banks adjust their risk-weights under the proposed New Basel Accord, if they use the IRB approach? What would be the effect on credit extension in each case?
4. What question is being asked in VaR? State the formula. What are the advantages and the disadvantages of VaR?
5. What are the assumptions of the Merton Model and how is it implemented? What is it trying to achieve? What are its advantages and disadvantages?
Part B: long answers - there were two, dealing with the term structure of internet rates (deriving the yield curve) and calculating the price of a call option from a binomial tree.
SInGAPORE_AIR
Thu Jun 29, 2006 6:26 am
What kind of exam is that?! My Macroeconomics (year 2, Honours degree) was much easier... I think.
AeroWesty
Thu Jun 29, 2006 6:31 am
Quoting AirxLiban (Reply 10):
Is there a word or two missing in this question?
International Homo of Mystery
airxliban
Thu Jun 29, 2006 7:24 am
In reply 10 I was answering Comorin's question in reply 9. That was my fixed income exam.
Quoting AeroWesty (Reply 12):
Nope - what were you thinking of?
comorin
Thu Jun 29, 2006 8:39 am
Airxliban,
Thanks for sharing your exam. Those are pretty good questions - now you are ready to be a bond trader !
I note that you were fortunate in not having to calculate the OAS on a callable bond !
In question 2, all I can think of is that if portfolios with the same duration have different convexities, then for anything more than a small delta in rates, they will end up with different values.
I'm pretty impressed with your program, as this would usually be MBA-level knowledge.
Anyway, it's over now. Time for you to enjoy real life, and time for me to get back to Sudoku!
AeroWesty
Thu Jun 29, 2006 8:46 am
Quoting AirxLiban (Reply 13):
Quoting AeroWesty (Reply 12):Is there a word or two missing in this question?
It's missing either a couple of words or proper punctuation. Like:
2. Consider two portfolios with the same duration. Under which conditions would the change in their values, when interest rates change, be the same? Explain your answer.
It's all jumbled as it is.
airxliban
Thu Jun 29, 2006 8:57 am
Quoting Comorin (Reply 14):
Hehe...that is what I said actually, that they would have to have different convexities.
Actually needed that work done for my masters project but avoided doing it! I had a bunch of data on corporate bonds but they all had different optionalities. It ended up being a bunch of interest rate path simulations or something, not sure, didn't do it myself.
Still got two more Sad Trading and financial history. Had fixed income today, macro yesterday, derivatives on Monday. Almost done - final stretch. Enjoy Sudoku.
Quoting AeroWesty (Reply 15):
The professor is Greek  Wink
AeroWesty
Thu Jun 29, 2006 9:08 am
Quoting AirxLiban (Reply 16):
I'd be interested in the right answer. I don't even think duration was used properly in this context.
airxliban
Thu Jun 29, 2006 9:30 am
I think I copied it directly out of the exam paper. I believe the answer is that they have to have different convexities. Are you referring to duration in the dictionary sense or in the economic sense?
AeroWesty
Thu Jun 29, 2006 9:45 am
Quoting AirxLiban (Reply 18):
In the economic sense. Duration could refer to maturity. It should be worded clearly, unless there's a specific definition of duration they're teaching. Simply stating duration doesn't say whether the portfolios were started at the same time or not, just that they have the same length of time as a property.
comorin
Thu Jun 29, 2006 10:16 am
Quoting AeroWesty (Reply 17):
Why do you think so?  Confused Portfolio Duration is the weighted sum of each component asset's Modified Duration which is a measure of interest rate sensitivity of the portfolio as a whole. Apart from the minor grammar error, duration was used correctly in this context. You may be thinking of simple duration (term of equivalent zero-coupon bond), in which case you would be right, but it's not what bond traders refer to when they talk about duration.
Lord Macaulay, the originator of the Macaulay Duration measure, taught at Cambridge. Hopefully, AirxLiban's professor at Oxford should also know a thing or two about the subject...  Wink
AeroWesty
Thu Jun 29, 2006 10:28 am
Quoting Comorin (Reply 20):
That's why I qualified it with:
Quoting AeroWesty (Reply 19):
Remember, I'm just reading the question without knowing what's been taught in the class, and the balance of the question had a grammatical error.
comorin
Thu Jun 29, 2006 11:03 am
Quoting AeroWesty (Reply 21):
Sorry if I sounded like a know-it-all! I've learned so much from a.net, and I just wanted to 'give back' on a topic I deal with everyday.
 Smile
AeroWesty
Thu Jun 29, 2006 11:25 am
Quoting Comorin (Reply 22):
That's okay, I thought it was kind of funny when you mentioned bond traders, since I did arbitrage and made a market in zero coupon convertible bonds (among others) as the lead trader for a Wall Street firm in the past. That gave me a clue about where the test question was coming from.
Never a problem with asking questions and getting thoughtful answers here.
Users browsing this forum: aerlingus747 and 1 guest
