Beaucaire
Swedish Nuclear Reactor Incident..
Fri Aug 04, 2006 7:07 pm
That was a close call - two out of four pumps to provide cooling into the core of a Swedish reactor failed due to a construction-default.
Considered to be extremely safe ,all of Sweden's nuclear plants have to be checked and modified.
If the two remaining pumps would have failed as well ,the core would have melted and a desaster in the scale of Chernobyl hit Europe .
http://www.aftenposten.no/english/local/article1409304.ece
Please respect animals - don't eat them...
Halcyon
RE: Swedish Nuclear Reactor Incident..
Fri Aug 04, 2006 7:12 pm
Here in America we are entering the "second age" of nuclear power, with plants opening again all over the US...it does make me nervous. The ones in the NE and FL really get to me.
nighthawk
Fri Aug 04, 2006 7:17 pm
Quoting Beaucaire (Thread starter):
The control rods would have dropped, killing off the reaction and averting any problems. No big deal.
AirPacific747
Fri Aug 04, 2006 7:23 pm
Luckily, Barsebäck on the other side of Øresund was shut down after pressure from the Danish government.
It did make me nervous how easy it has been before september 11 to hijack a plane from CPH and hit the nuclear powerplant not more than 20 kilometers away from Copenhagen.
[Edited 2006-08-04 12:25:35]
Beaucaire
Fri Aug 04, 2006 7:34 pm
Quoting AirPacific747 (Reply 3):
But aren't reactors build to sustain an impact of a commercial jetliner??
The dangers are comming rather from within the reactors,as the most recent example shows.Officials will rarely tell you the full truth in order to calm public opinion.
I still think nuclear energy is sustainable provided the latest safety technology is implemented in all plants.Storage of burnt fuel cells and nuclear waste remains the issue !
AirPacific747
Fri Aug 04, 2006 7:37 pm
Quoting Beaucaire (Reply 4):
I'm not sure, that's why I was nervous about it. I guess you're probably right
Matt27
Fri Aug 04, 2006 7:54 pm
Quoting Nighthawk (Reply 2):
Exacty, the 'incident' is not really a big deal here.
Ummm...no. They closed Barsebäck because of years of domestic debates and the requests from the Danes didn't really have anything to do with that decition. Barsebäck is the smallest plant in Sweden and it was the first to be closed because of that.
Man ska inte dricka rödvin i en vit hall.
nighthawk
Fri Aug 04, 2006 7:56 pm
Yes, they are. However a month before September 11 I watched a documentary about the twin towers, and it stated in the doc that WTC was designed to withstand a hit from a 747.
However with a nuclear reactor, the majority of it is underground, even then its incased in about 10 foot of reinforced concrete, so chances are an impact would do next to no damage to the reactor itself. However any cooling pipes would be wiped out, and whether the rods will drop automatically or not is another matter.
I lived less than 2 miles from a nuclear plant all my life, and it doesnt bother me one bit. Its closed now, but I really hope they build another on the same site. However thats a different thread.
AirPacific747
Fri Aug 04, 2006 8:03 pm
Quoting Matt27 (Reply 6):
Okay, but that was not my original point. The point was that i'm glad that it is closed now  Smile
rolfen
Fri Aug 04, 2006 8:11 pm
Extremely safe...
hah
rolf
Thom@s
Fri Aug 04, 2006 8:15 pm
Swedes... I knew they'd be the end of us all...
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
NoUFO
Fri Aug 04, 2006 8:28 pm
From what I have heard "killing" the reaction wasn't the problem, cooling was. They shutdown Forsmark after a short circuit, and only 2 pumps designed to cool the - already inoperative - reactor worked. Are you really so naive to think that the control rods drop and that thing is dead and cold after that?
As for Oskarshamn, only one out of three reactors could withstand the Forsemark incident.
But it's "no big deal", right?
I support the right to arm bears
md80fanatic
Fri Aug 04, 2006 8:35 pm
Quoting Halcyon (Reply 1):
 checkmark  checkmark  checkmark
Exactly. The pumps are not the main reaction moderator, as most believe. Their purpose is to carry heated, pressurized water to the steam generators to make electricity. Chernobyl was a water-moderated reactor IIRC, and this pump issue would have been a big deal had it happened there.
What we have here are media scare tactics, nothing more.
I wonder if the petroleum industry is somehow behind this report?  scratchchin
NoUFO
Fri Aug 04, 2006 8:43 pm
Quoting MD80fanatic (Reply 12):
Who?
Again: the control rods moderate but you still need pumps to cool the reactor even after shutdown. If that's not going to happen, it's possible that the reactor starts to melt, although that may not be inevitable.
No, that was a graphite moderated reactor.
[Edited 2006-08-04 13:49:11]
nighthawk
Fri Aug 04, 2006 8:54 pm
Quoting NoUFO (Reply 13):
No reaction = no heat generated.
Kill the reaction and the reactor will soon start to cool off.
md80fanatic
Fri Aug 04, 2006 9:01 pm
Who?
Two pumps should be sufficient to provide enough water flow once the rods are dropped. The "rods" are able to completely absorb all excess neutrons when fully extended.
Thank you, my mistake.  Smile
Doona
Fri Aug 04, 2006 9:04 pm
This happened last week? Wow, never even heard of it...
Quoting AirPacific747 (Reply 8):
Hey, just because you've covered every flat inch of your country (which is really pretty much everywhere) with wind power stations, it doesn't mean that the rest of us have... I like our nuclear power, and we need it.
 checkmark  We had a public referendum about the nuclear power issue back in the '80s, and it turned people didn't want the nuclear power anymore... Seems like opinion is swinging now, however.
Sure, the Danes were standing at the front door, kicking and screaming about it, but since when does Sweden make decision based on what Denmark wants?
Mats
AirPacific747
Fri Aug 04, 2006 9:05 pm
Quoting Doona (Reply 16):
Well Sweden is so much bigger than Denmark, therefore you have so much more space to build windmills on. What are you waiting for? Help boosting our economy even more by buying our windmills!
I don't know since when but Barsebäck is closed now which everyone here on this side of the "pond" is happy about  Smile
..most people anyway :P
[Edited 2006-08-04 14:08:09]
Doona
Fri Aug 04, 2006 9:13 pm
Quoting AirPacific747 (Reply 17):
Have you actually seen Sweden? North of Skåne, there is only forest. Trees, everywhere! All the way up to the Arctic. Trees or mountains. And as soon as you get up north of Bohuslän, there are Norwegian mountains that block pretty much all the wind. And down here were it's flat and tree-less, we grow all the food, the space is needed. So a dramatic increase when it comes to wind power is unlikely... plus, the damn things drive down the property values!
Mats
md80fanatic
Fri Aug 04, 2006 9:14 pm
I like your nuclear power too.  Smile I wish we could convince our leaders to do the same...to go predominantly nuclear. But alas, the majority likes to put oilmen into power....  banghead
SK A340
Fri Aug 04, 2006 9:16 pm
They didn't fail, two started as normal, which covered 100% of the power needed. The other two had to been started manually, which means that after 23 minutes the cooling system had 200% of the power needed. But I can assure you that the green hippies and red commies sure screams alot now of how unsafe the nuclear power is and they want to shut it down ahead of schedule.
No, only four of ten reactors
I'll be glad when you shut down your coal and/or oil plants.
/Micke
AirPacific747
Fri Aug 04, 2006 9:17 pm
Quoting Doona (Reply 18):
What do you think Denmark looked like before it was turned into farms? Anyway this is probably too complicated to discuss.
On a sidenote, there are bad things about windmills as well. They scare away the birds and other animals, and they can be noisy too. In the end I am still happy that we don't have nuclear power here
Quoting SK A340 (Reply 20):
Me too!
Loosen up a little guys and let's have a good discussion
[Edited 2006-08-04 14:21:14]
NoUFO
Fri Aug 04, 2006 9:18 pm
Quoting Nighthawk (Reply 14):
Yeah, I'm aware of that.  Yeah sure
But probably not soon enough to keep the reactor from melting.
Quoting MD80fanatic (Reply 15):
In this case two pumps were sufficient. Had that happen in Oskarshamn, only one reactor (out of three) would have been able to withstand the remaining heat.
Beaucaire
Fri Aug 04, 2006 9:26 pm
Geothermal Electricity is for me the ultimate energy of the future - although wind ,piezo-electric and tidal -technologies are not at all at the end of their development potential.
The nuclear lobby is unfortunately too strong to allow substantial research and investments into those energies. Many countries have geology profiles that would allow Geo-thermal applications but nobody tries it ...
Rj111
Fri Aug 04, 2006 9:51 pm
Had the reactor melted wouldn't the lead and concrete sheilding protected us from any harmful emmissions?
NoUFO
Fri Aug 04, 2006 10:27 pm
Quoting RJ111 (Reply 24):
That's how it was planned - just like it was planned that four pumps will pump water into the reactor.
Btw: At first NONE of the four pumps worked!
Derico
Fri Aug 04, 2006 11:17 pm
Go nuclear power! I for one would rather have nuclear power, and to tell Arab and Venezuelan oil, Bolivian natural gas, to f-off. Furthermore, it saves river habitats (less hydros), birds (less wind stations), etc.
Two new nuclear plants are supposed to come online in Argentina in the next couple of years.
My internet was not shut down, the internet has shut me down
CPDC10-30
Fri Aug 04, 2006 11:34 pm
Sorry, but that just isn't true. A shut down reactor still needs to have heat removed from it. However, the Swedish reactor in question has containment that make make even a worst case meltdown unlikely to release radioactivity outside the building. Anyone comparing this to Chernobyl has no idea what they are talking about.
Nuclear power doesn't make economic sense in all cases. But for energy poor countries such as the UK, Japan, China etc it needs to be an important part of the power generation mix. It isn't perfect, but it does have a pretty damn good record of producing clean and safe energy. It isn't fair to let the faulty design and deliberate circumventing of safety procedures at Chernobyl to tarnish nuclear power as a whole.
Alessandro
Sat Aug 05, 2006 1:06 am
Well, this is the result of underfunding of the nuclear industry since the 1970ies in Sweden. As for Barseback nothing is written in stone, it could be restarted if theres a different government in september.
777236ER
Sat Aug 05, 2006 1:08 am
Let's get things straight, at no time was a core meltdown close to occuring. The reactor would be able to run with one pump inoperative. With two pumps inoperative, there are only two pump redundancies, so the reactor was shut down.
Let's say another pump failed (an independent three-pump failure having a probability less than an ETOPS-equiped aircraft having a double engine failure). The reactor would have immediately scrammed, and everything would have been fine. The reaction would stop and the reactor would be cool.
Had all four pumps failed, simultaneously, at high power, the reactor would scram. While the heat would increase with no pumping, the core would still be flooded with water.
And here's where the inherant safety of the BWR comes into the mix. With a PWR, you'd have steam in the system - something that's very dangerous, likely to over-pressure the reactor and blow the roof off (like Chernobyl). A BWR is designed to operate in that state constantly, so even with a significant increase in steam caused by flooding the reactor with water, containment would be assured.
This can be compared to two out of four hydraulic systems on a 747 failing, the aircraft returning to the airport, and the media screaming that the passengers were minutes from death.
David L
Sat Aug 05, 2006 1:13 am
Quoting CPDC10-30 (Reply 27):
 checkmark
I'm surprised no-one's brought up the Three-mile Island Minor Glitch.  Smile
agill
Sat Aug 05, 2006 1:50 am
http://www.gp.se/gp/jsp/Crosslink.jsp?d=361&a=289114 Well who would have guesed. But since most people want to keep it we can only hope they make the demands  Smile SAP must hate this
yooyoo
Sat Aug 05, 2006 2:01 am
Quoting Nighthawk (Reply 7):
And they withstood the impacts from the airliners.
I am so smart, i am so smart... S-M-R-T... i mean S-M-A-R-T
Boeing Nut
Sat Aug 05, 2006 3:53 am
Quoting YooYoo (Reply 32):
Incorrect. Boeing 707's at approach speeds.
[Edited 2006-08-04 20:54:29]
David L
Sat Aug 05, 2006 4:07 am
Quoting Boeing Nut (Reply 33):
Thank you - that's what I thought the architect said. Approach speeds and approach fuel loads.
CptGermany
Sun Aug 06, 2006 7:43 am
 checkmark  and it wasn't full of fuel.
It is safe to a certain degree. There is always a calculated risk of a system failing catastrophically, regardless of a how much redundancy is built into it. Furthermore, nuclear power is not clean! There is a substantial amount nuclear waste, which needs to be handled very carefully and has a slow rate of decay!
Users browsing this forum: desertjets, PhilBy and 3 guests
