NoUFO
One Or Two Mac-Related Questions
Fri Aug 25, 2006 9:13 pm
Hi Klaus and other Mac-Evangelists,
Can I move executable files (more precisely projectors created in Flash or Director) from an OS9-based system to a more modern OS X system and rest assured everything works fine, or will the older system change the resource fork of the file?
I ask, because I sent a projector, whose icon was previously changed on an OS 9 Mac, to a client, and the projector did not start on her Mac.
Thanks in advance.
- Norbert
I support the right to arm bears
RichardPrice
RE: One Or Two Mac-Related Questions
Fri Aug 25, 2006 10:06 pm
Quoting NoUFO (Thread starter):
Up to 10.4, 'Classic' was included in OSX allowing you to run *most* OS9 and previous apps.
Theres ultimately no 100% answer to the question asked, its a definite 'maybe'.
NoUFO
Fri Aug 25, 2006 10:40 pm
Thank you Richard, But the new projector I create will definitely run on a more contemporary Mac. Question is: When I move the projector and data files on an older Mac's hard drive, change the projector's icon and burn all files on a hybrid Mac/ISO CD-ROM: will the projector still be executable under OSX, considering I changed the icon and possibly the resource fork?
Klaus
Sat Aug 26, 2006 3:40 am
I don't know your tools and specifically I don't know what a projector in that sense actually is.
But you should normally not have a problem. Both MacOS "Classic" V1.0-V9.2.2 and MacOS X 10.0-... use HFS or HFS+ as their file system; And both fully support the classic data and resource forks.
You should be careful, however, when compressing or mailing files with resource forks; ZIP files will usually discard the resource fork, SIT files will preserve it.
"Classic" applications (and some documents) make heavy use of the resource fork, while OS X applications come in "bundles", basically just camouflaged folder structures without using the resource fork at all. But moving programs or data between the two platforms should not be a problem.
Changing an item's icon works in different ways between Classic and OS X; In Classic, the icon is stored in the resource fork of the file itself, in OS X the icon is stored in the directory as far as I remember.
NoUFO
Sat Aug 26, 2006 4:30 am
Thanks, that was indeed helpful.
Quoting Klaus (Reply 3):
In this case it's an Adobe (formerly Macromedia) Flash projector. A projector is simply the Flash Player Plug-In as an executable file. It loads and displays Flash Player movies without the browser. Macromedia/Adobe Flash and Director both follow a movie metaphor, hence the name "projector".
That could be the reason. Before I mailed the projector, I zipped it using MacZip, not StuffIt.
OK, thanks, I guess I will go from there and try to find out more about colours, size and format.
Klaus
Sat Aug 26, 2006 5:29 pm
Quoting NoUFO (Reply 4):
Ah, okay. In that case the Classic MacOS version will be an application with essential components contained in the resource fork; The OS X version may still contain resource forks but OS X would not require it to.
Indeed; Most likely it just stripped off the resoruce fork. Stuffit is always the better choice for resource-containing files.
Users browsing this forum: Dano1977, moo, salttee and 2 guests
GZIP: Off
