deltaownsall
How Much Can You Bench?
Wed Sep 13, 2006 2:41 am
The title is pretty self-explanatory...i'm bored and curious to see if there's any other lifters on here and what you can do. My max right now is about 225x1, the best I've ever been is probably 225x4...not huge but decent for my meager 6', 170lb frame. Anyways, lets try to keep this reasonably truthful/on-topic.
TuffGong
RE: How Much Can You Bench?
Wed Sep 13, 2006 2:58 am
When i was doing bench on a regular basis about two years ago I was pushing 255lbs 10 reps with a spot. Now i only do free weight, no bench and I am doing 90 lbs dumbbells ten reps no spot. I have a 5'10 195 lbs body, been playin Ice hockey and lacrosse for about 17 years.
Meet you at the Ol' Yacht club for a pint.
usnseallt82
Wed Sep 13, 2006 3:47 am
Quoting DeltaOwnsAll (Thread starter):
I can hold my own.  Big grin
Crye me a river
AGC525
Wed Sep 13, 2006 3:51 am
I was pretty big into powerlifting, My max was 515 x 1 about two years ago. Now I've slacked off greatly, I'm around 350. At the time I was 240lbs. I've started to get back into it, I forgot what a long road it is!
American Aviation: From Kitty Hawk to the Moon in 66 years!
jfkaua
Wed Sep 13, 2006 3:54 am
I weigh 130ish, max 210x1
mt99
Whats more impressive.. being able to lift 2 x 225lbs or 12 x 135lbs..
Which is better for that matter?
Step into my office, baby
EA CO AS
Wed Sep 13, 2006 3:57 am
Best is 315 x 3. Added 40lbs to it just to see if I could do it and that bar pinned me like a little girl.
A332
Wed Sep 13, 2006 3:59 am
I bench a lot... keeps the blisters away.
Bad spellers of the world... UNTIE!
ANCFlyer
Wed Sep 13, 2006 4:25 am
 bigthumbsup
LOT767-300ER
Wed Sep 13, 2006 4:27 am
Of course ANC, your hat benches alot, it has to bench you everday!  Silly
deltaownsall
Wed Sep 13, 2006 4:43 am
Quoting Mt99 (Reply 5):
I would say that 2x225 is considerably better...I would be hard pressed to do 225 more than once or twice right now, but i could most likely do 135 at least 20 times.
dl021
Wed Sep 13, 2006 4:57 am
How much does your mom weigh?  duck   Wink
I could probably bench the bench..........
Is my Pan Am ticket to the moon still good?
LHMark
Wed Sep 13, 2006 4:59 am
Dunno, how much does Dmitri Young weigh?
Regards, Jim Leyland
"Sympathy is something that shouldn't be bestowed on the Yankees. Apparently it angers them." - Bob Feller
JGPH1A
Wed Sep 13, 2006 5:00 am
Quoting Usnseallt82 (Reply 2):
I can hold my own.
That wasn't the question, that is simply assumed - spare us the sordid details of your lonely desert life !  Smile
Bench ? Benches are for sitting on. Therefore I "bench" one, I suppose.
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
prosa
Wed Sep 13, 2006 5:05 am
I've done 225 x 10, which works out to a single rep of 300 pounds. The most I've done in an actual single rep is 275, though when doing it I could tell I wasn't near my limit. I've also done ten reps with a pair of 100-pound dumbbells.
Here is a chart showing typical bench press amounts by bodyweight. The bodyweight amounts correspond with the weight categories used in powerlifing competiton:
http://www.exrx.net/Testing/WeightLifting/BenchStandards.html
[Edited 2006-09-12 22:10:47]
[Edited 2006-09-12 22:16:03]
"Let me think about it" = the coward's way of saying "no"
aa61hvy
Wed Sep 13, 2006 5:17 am
Might as well ask
"How big is your penis?"
Think people will tell the truth? Nah.
Go big or go home
prosa
Wed Sep 13, 2006 5:38 am
A couple of bench press factoids:
One of the tests given to prospective NFL players at the annual Combine is the number of reps they can manage at 225 pounds. Quarterbacks, wide receivers, kickers and punters are exempt from the test. Most men manage between 10 and 35 reps, with linemen at the top and cornerbacks at the bottom.
Outside of powerlifting, the athletes with the best bench presses as a function of bodyweight probably are Olympic gymnasts. I have read that essentially all of them can bench in excess of double bodyweight and some approach triple bodyweight.
BMIFlyer
Wed Sep 13, 2006 6:14 am
I can hold my own.
Same here Big grin
I'm slowly working my way up the scale, but as with everything good, it takes time  Wink
Lee
IFEMaster
Wed Sep 13, 2006 6:37 am
I don't bench press. I catch the weights as they are running away from me.
Signed,
Chuck Norris
Delivering Anecdotes of Dubious Relevance Since 1978
vikkyvik
Wed Sep 13, 2006 6:46 am
The most I've ever benched is 170, at about 3 or 4 reps. I've never tried to max out and actually see how much I could bench for one rep.
I've also never lifted for more than bout 2 or 3 months at a stretch. Get bored of it too quickly.
I'm 5'10", and was around 150 lbs when I benched 170.
~Vik
deltaownsall
Wed Sep 13, 2006 6:48 am
Quoting PROSA (Reply 16):
Interesting...I've heard of a similar practice in the NBA, only the weight is 175. Apparently Shaun Livingston (of the clippers?) couldn't even do one rep...pretty incredible for an NBA player.
prosa
Wed Sep 13, 2006 9:29 am
Quoting DeltaOwnsAll (Reply 20):
Indeed there is such a practice, though the weight is 185. Here is a list of the most recent results:
http://www.draftexpress.com/viewarticle.php?a=1352
I was quite surprised to see just how low some of these numbers were.
RichPhitzwell
Wed Sep 13, 2006 9:34 am
[quote=Aa61hvy,reply=15]Might as well ask
This is the most disgusting reply I have ever read....and yes I can bench it very well.
Again, what does 2.5 inches weigh....no reason just asking  eek
Nonav.com kinda like Whiners except the lights are on and the pimps been paid
usnseallt82
Wed Sep 13, 2006 9:36 am
Quoting JGPH1A (Reply 13):
Then I'll repeat my response before....I can hold my own.  Big grin
Quoting Aa61hvy (Reply 15):
Depends upon the temp and who I'm looking at.  bigthumbsup
Crye me a river
flymia
Wed Sep 13, 2006 10:27 am
255lbs 1 rep.
Quoting DL021 (Reply 11):
LOL  Smile
deltaownsall
Wed Sep 13, 2006 10:31 am
Quoting PROSA (Reply 21):
Interesting...looks like Shelden Williams is a beast@25 reps...
Jaws707
Wed Sep 13, 2006 10:34 am
I can bench 335 one time. Sometimes for fun I'll do 215 about 10-15 times, and 135 30+ times.
I am about 6'1 and weigh 210. It took me 4 years of hard work to get to this point. The first time I ever tried to bench, I failed at 135.
Like they say, "practice makes perfect"
dl021
Wed Sep 13, 2006 10:40 am
Quoting PROSA (Reply 14):
OK.....is that something you read?
That's probably what you can benchpress, then. If you really want to know what you can do then get a spotter and stop guessing.
Big enough to make me happy.......isn't that what counts?
Quoting Usnseallt82 (Reply 23):
and you probably have to..........
usnseallt82
Wed Sep 13, 2006 10:42 am
Quoting DL021 (Reply 27):
Nowadays, only from the occasional chief looking to stir something up.
Crye me a river
prosa
Wed Sep 13, 2006 12:02 pm
That's using the one-rep-max calcuator at Exrx.net:
http://www.exrx.net/Calculators/OneRepMax.html
It's not 100% precise, but I've found it to be reasonably accurate. Chances are, ten reps at 225 would work out to a single rep in the 290 - 310 range.
dl021
Thu Sep 14, 2006 12:35 am
Quoting Usnseallt82 (Reply 28):
I'm not sure you understand in what way I'm mocking you....but I expect that from a Navy guy............. duck   Big grin  Wink
vikkyvik
Thu Sep 14, 2006 12:41 am
Not if it ain't big enough to make her happy.
 Wink
usnseallt82
Thu Sep 14, 2006 1:38 am
Quoting DL021 (Reply 30):
Oh, I understand quite well....but I figured I answered that with my temp and who I'm looking at comment.  Big grin
Crye me a river
FDXmech
Fri Sep 15, 2006 1:46 pm
Quoting Vikkyvik (Reply 31):
Like the saying goes, "Who do you expect to satisfy with that lil' thing"?
Answer - "Myself"
[Edited 2006-09-15 06:48:02]
baylorairbear
Fri Sep 15, 2006 3:22 pm
The most I've ever benched was 430 pounds, and that was only once. That was my freshman year of college, and I was 6'4'' at 339 pounds, and trained everyday for shotput and discus. I don't do any weight training now. I only run, and weigh in at 235 pounds. If I had to guess, I'd say I can still mash 300 pounds pretty easily, but I would do a full body warm up and stretch before attempting that.
BAB
I'm just skipping stones...
deltaownsall
Sun Sep 17, 2006 12:56 pm
Well...I've been taking a new product called "Anator" by Muscletech for about a week now. Like any other weightlifting supplement it has huge hype, but I was surprised to see that its already given me some impressive results. After just a week of taking it, my bench went up from 205x4 to 225x3, a set of negatives @225, then 205x6. Needless to say ill keep taking it...although at $90 for 16 servings the price is pretty outrageous.
jetmech
Sun Sep 17, 2006 5:58 pm
In my younger days, I would do 3 or 4 sets of 10-12 reps with about 220lbs. My best ever was a set of about 5 reps with about 310lbs. Only did that once though. Nowadays, I can only do about 3 sets of 7-8 reps with 220lbs  crying .
Users browsing this forum: Freakysh, sovietjet, Tkfan and 3 guests
