Matt D
PhotoShop Experts: Got A Project For You
Wed Oct 11, 2006 10:51 am
This is just to satisfy a "what if" curiosity I have. And I know some of you are pretty talented at modifying pictures. So here''s what I want.
I want to take this train.....
http://x-2000r.angelcities.com/images/trainstuff/LincolnApp1.JPG
And show it running on THIS track:
http://x-2000r.angelcities.com/images/trainstuff/LookingEastPM.JPG
The scale of the train will have to be significantly reduced to make it look believable I'm sure.
Now, I want the same thing done with these pictures:
Show THIS train:
http://x-2000r.angelcities.com/images/trainstuff/PalmMetroEng2.JPG
Rolling on THIS track:
http://x-2000r.angelcities.com/images/trainstuff/PICT0127.JPG
Thanks a bunch.
Skookum
RE: PhotoShop Experts: Got A Project For You
Wed Oct 11, 2006 11:04 am
The main problem you face here is the different angles of the tracks. It's one thing to trace the train, cut it out, and transplant it, but getting it to appear at the same angle at which the tracks approach the camera in the second shots is not possible unless you do some CGI.
Good flying
Matt D
Wed Oct 11, 2006 11:05 am
I figured that might be a problem with the first set. But as far as I can tell, the track angle on the second set is close to identical. Or at least close enough to make the modified image believable.
KFLLCFII
Wed Oct 11, 2006 12:24 pm
Quoting Matt D (Reply 2):
Did what I could...But when you rotate the train to match, it shows a pretty good lean...
http://img157.imageshack.us/img157/8596/pict0127editedqd3.jpg
-Bryan
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
NoUFO
Wed Oct 11, 2006 12:29 pm
http://img.photobucket.com/albums/v102/Turtleshell/LookingEastPM.jpg
Could stand another half an hour of work, but I'll pass.
I support the right to arm bears
KFLLCFII
Wed Oct 11, 2006 12:39 pm
Quoting NoUFO (Reply 4):
Hmm, if I can figure out how to "yaw" the train in the second pic instead of rotating it, I just might be able to alleviate that lean...
NoUFO
Wed Oct 11, 2006 12:58 pm
Photoshop allows to transform the perspective of a selected layer. Problem is that only some front parts of the train need additional transformation. Plus, the shadow is not perfect, the window frames need to be re-alligned, and I forgot to enhance the colours of the background image.
AC773
Wed Oct 11, 2006 1:41 pm
Here's my attempt:
And just for good measure...
 biggrin   duck
Better to be nouveau than never to have been riche at all.
NoUFO
Wed Oct 11, 2006 2:42 pm
Ok, I improved mine (reply #4) a bit. Empty the browser cache and reload if it doesn't show up. Actually, the shadow is worse now, but overall it's a tad better.
AC773
Thu Oct 12, 2006 1:28 am
Quoting NoUFO (Reply 8):
Don't be daft, that was a big improvement. Now that the headlights are straight on, it looks quite realistic. As close to perfect as anyone could get.  bigthumbsup
agill
Thu Oct 12, 2006 6:15 am
http://img.photobucket.com/albums/v461/Agill/PICT0127.jpg
NoUFO
Thu Oct 12, 2006 1:39 pm
And No.2:
http://img.photobucket.com/albums/v102/Turtleshell/PICT0127.jpg
solarix
Thu Oct 12, 2006 2:09 pm
lmao @ Agil's train!! haha!!  Smile
Bong Hits 4 Jesus
ANCFlyer
Thu Oct 12, 2006 2:32 pm
Quoting AC773 (Reply 7):
Ha Ha Ha . . . what are you, Lew's understudy?
Confuscius
Thu Oct 12, 2006 3:02 pm
Let me embellish it just a bit.
Ain't I a stinker?
Skookum
Thu Oct 12, 2006 3:03 pm
Quoting Agill (Reply 10):
Agill
NoUFO, how the hell did you get the F59PHI angled? I can see a little distortion, but that's bloody brilliant!
EDIT: Didn't see the above post....  rotfl
[Edited 2006-10-12 08:04:15]
Good flying
NoUFO
Thu Oct 12, 2006 3:21 pm
Quoting Confuscius (Reply 14):
Why did you take the first version of my pic?
Quoting Skookum (Reply 15):
I simply used the 3D transformation filter Photoshop comes with.
Confuscius
Thu Oct 12, 2006 4:04 pm
Oops! that was yours, my mistake. May I belatedly cite your picture or should I remove it?
Ain't I a stinker?
NoUFO
Thu Oct 12, 2006 4:14 pm
I wondered why you didn't take the second, improved version.
AC773
Fri Oct 13, 2006 12:12 am
Quoting ANCFlyer (Reply 13):
He hasn't had any new work in a while, so I thought I'd pick up the slack.  biggrin
MYT332
Fri Oct 13, 2006 12:23 am
Matt D, did I inspire you with my Pendolino edit the other day?
As for Agill, that's the funniest thing I've seen all day. I like you sense of humour!
One Life, Live it.
agill
Fri Oct 13, 2006 12:30 am
Quoting Myt332 (Reply 20):
Thanks  Smile
TedTAce
Fri Oct 13, 2006 1:13 am
Brilliant!!!  rotfl  rotfl  rotfl  rotfl  rotfl
This space intentionally left blank
Users browsing this forum: bombayduck, trav110 and 1 guest
