miamiair
5.56 Or 7.62 X 51?
Fri Dec 01, 2006 10:48 pm
After reading the post about the M240 and the M249, what do the firearm aficionados here prefer?
I have both, and each have their pros and cons:
5.56
PRO:
Cheap
Readily available
Accurate
CON:
Not as effective as 7.62
7.62
PRO
Accurate
Readily available
Good Performance/Range
CON
Heavier than 5.56
More expensive than 5.56
Throw in your two cents.
MDorBust
RE: 5.56 Or 7.62 X 51?
Fri Dec 01, 2006 10:51 pm
In order of preferance:
7.62x51mm
7.62x39mm
5.56mm
Personally I find it funny that the 7.62x51mm battle rifles were phased out because they were uncontrollable under automatic fire. Then the 5.56mm rifles that replaced them were modified to not shoot automatic because of ammo waste.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
miamiair
Fri Dec 01, 2006 11:46 pm
Since you brought the 7.62 X 39 into the mix, it is cheap and available. I can't say about the accuracy as I have a folding stock AK and just use it to plink cans; never tried it for accuracy.
KaiGywer
Sat Dec 02, 2006 12:27 am
7.62x51mm.
First caliber I ever shot, using one of these babies:
http://i3.photobucket.com/albums/y84/kaigywer/g3.jpg
miamiair
Sat Dec 02, 2006 12:48 am
Have one, but this is my favorite:
http://i30.photobucket.com/albums/c325/miamiair/M1A.jpg
jwenting
Sat Dec 02, 2006 3:10 am
5.56 only sounds cheaper and lighter.
You need more of them for the same effect (unless you get extremely lucky) so in the end it costs more and weighs more as well.
I wish I were flying
dl021
Sat Dec 02, 2006 7:09 pm
Dude...the main issue, as you know is shot placement, seconded by bullet throw weight.
The 7.62 is a much better round than the 5.56 as long as you can comfortably lug the bullet launcher around with sufficient ammo to do the necessary damage if everything else is equal. Problem is that it's generally not.
If you are an expert marksman and don't mind the couple of extra pounds that a 7.62 carbine weighs then by all means use that....it holds 10 fewer rounds than the usual 5.56 magazine, and is more difficult to shoot accurately from the smaller rifles, but it's more effective as long as you are strong enough to hold it steady (two pounds may not make much difference unless you are winded from having run and jumped).
If you have difficulty with that then remember that the 5.56 is easier to carry, shoot and recover from for a second shot when fired from a similar sized weapon. I can make double taps more easily with the carbine I have than I can with the M1A (which is my favorite rifle, albeit large and heavy) but I can't hit squat with the carbine from beyond 200 meters. So it's a tradeoff.
BTW...I'm probably getting a 7.62 carbine in the next month or so.
Just for shits and grins.....
Is my Pan Am ticket to the moon still good?
Queso
Sat Dec 02, 2006 11:31 pm
Quoting Miamiair (Thread starter):
5.56 Or 7.62 X 51?
Neither. 12.7 × 99 (aka .50BMG).
http://www.praxagora.com/lunde/photos/thunder50bmg-3.jpg
yooyoo
Sun Dec 03, 2006 12:19 am
I'm not an aficionado or gun person whatsoever so please forgive my ignorance.
What do you use the above for? Those are some mean looking firearms.
Hunting, target practice, collecting all the above?
I am so smart, i am so smart... S-M-R-T... i mean S-M-A-R-T
dl021
Sun Dec 03, 2006 1:32 am
Quoting YooYoo (Reply 8):
YooYoo....the main purpose for firearms is shooting. Whether it's at paper targets, game animals or self defence they are designed for that.
There is also the collectibility issue for the firearms, just as with any other item out there produced in limited or known quantities.
Different people have different reasons for ownership of firearms and it's relatively difficult to put them all in one category...some people have multiple reasons for owning their firearms and that makes it even more difficult.
As far as looks go, it's a statistical fact that most firearms related deaths in North America come from .22 to .38 caliber firearms and the ones generally used in the commission of crimes aren't the "mean" looking ones that collectors like, but the ordinary looking cheap ones that sell for less than $200 retail.
MD-90
Sun Dec 03, 2006 3:24 am
Quoting DL021 (Reply 6):
You know, the M-14 system itself is actually not that much longer or heavier than an AR-15 (depends on the barrel, of course), it's the ammo that weighs so much more and takes up a lot more space.
The gun above your post looks pretty expensive, so it would most likely on used by people who can afford it (and the ammo), and they're usually fairly responsible. Most likely for shooting a targets, and just as a cool gun to have in the collection. There are a lot of guns I'd rather have than a .50BMG handgun, but that's just me. A .50 rifle would be fun, because you can use those on the long ranges....like 1000 yards and up! (those are also only used for target shooting).
yooyoo
Sun Dec 03, 2006 5:04 am
Quoting DL021 (Reply 9):
Nope, i don't want to get into a debate about crime, murder with regards to firearms. I'm genuinely curious as to what they are used for.
My use of the word "mean" was not meant in a negative way but used as a "wow" description.
I've not fired many guns, but i do enjoy the target shooting and skill associated with it.
Queso
Sun Dec 03, 2006 7:00 am
I actually prefer 7.62x63 (.30-06) because it knocks down full-size metallic silhouette rams at 200 yards with no problem. You have to hit them in just the right spot to knock them over with a .223, and even then it's iffy as to whether they'll go over or not.
The ballistics of the 7.62x63 and the 7.62x51 are similar, they can use the same projectiles but the x63 is slightly more powerful.
Here are a couple of pics of my 7.62x63 handgun:
http://i61.photobucket.com/albums/h56/kmaf/Light%20Tent/IM001302-2.jpg
dl021
Sun Dec 03, 2006 7:37 am
Quoting MD-90 (Reply 10):
I'd have to disagree....it's alot heavier. Speaking as one who has humped both the M-16 and and M-21 system...it's a big difference to the man who has to carry it for a long distance. With equal amount of ammo and the extra wood/metal you've got a noticeable difference. Carry them both on separate 20 click road marches and then tell me it's not that much heavier.
Quoting YooYoo (Reply 11):
Sorry if my answer seemed to take your question negatively. I was just trying to cover all the bases. It does look fairly mean.
Quoting Queso (Reply 12):
you mean, like, in the middle?  Wink
MDorBust
Sun Dec 03, 2006 8:00 am
Quoting DL021 (Reply 13):
Now now, that's not really fair. The scope on the M-21 by itself probably weighs half of an M-16.  duck
I find the M-14 to be a heavier rifle, and much more cumbersome, than the M-16. Only with a great deal of aftermarket work does the M-14 (at the very least a replacement for the stock) approach being a fieldable piece of infantry equipment. I've always thought that the FAL was a much better combat rifle.
Queso
Sun Dec 03, 2006 8:03 am
No, at the top. It gives it more leverage. A bottom or middle shot will just push it back a little, not knock it down.
Users browsing this forum: einsteinboricua, lentokone, TheF15Ace, vc10 and 51 guests
