LY777
Why Is The Water So "cold" In Eilat, Israel?
Fri Dec 08, 2006 1:29 am
Eilat is Israel's southernmost city (located at 29.55° N 34.95° E), in the Southern District of Israel. Adjacent to the Egyptian city of Taba and Jordanian port city of Aqaba, Eilat is located at the northern tip of the Gulf of Aqaba, which is the eastern sleeve of the Red Sea.Eilat's weather is very hot and dry due to its proximity to the Negev, Sinai, Arabian and Sahara deserts.The average max temperatures vary from 71°F/21°C in January to 104°F/40°C in August.There is less than 20 mm of precipitation per year
What I don't understand is why the water the temperature of the sea is so cold in Summer...
Does someine have an explanation?
N1120A
RE: Why Is The Water So "cold" In Eilat, Israel?
Fri Dec 08, 2006 1:32 am
Well, the same can be said of the Pacific off the coast of Southern California. Probably a tidal thing.
ME AVN FAN
Fri Dec 08, 2006 1:57 am
Quoting LY777 (Thread starter):
I have been, admittedly quite some years ago, in Aqaba in late August and found that the water was warmer then in the Mediterranean at the same time, and MUCH warmer than the Lake of Zurich.  scratchchin  smile
LY777
Fri Dec 08, 2006 2:46 am
Quoting ME AVN FAN (Reply 2):
really?I find it so cold compared to the Eastern Med (in Tel Aviv)
Quoting N1120A (Reply 1):
yes, but the red sea is a "closed sea"
ME AVN FAN
Fri Dec 08, 2006 3:16 am
Quoting LY777 (Reply 3):
really?I
sure, even if I am NOT a swimming thermometer. It in Dubai of course is warmer, very much warmer. It is such there that you may feel tempted to take some rubber-ducks with you !
sv2008
Fri Dec 08, 2006 4:02 am
Interested in going diving there one day, although it can't be much colder than the med.
LY777
Fri Dec 08, 2006 4:24 am
Quoting Sv2008 (Reply 5):
Do you mean the Western Med?
sv2008
Fri Dec 08, 2006 5:15 am
Yes, it was pretty cold when I went in october.
LY777
Fri Dec 08, 2006 6:52 am
Oh yes, you are absolutely right.In South Spain near Malaga, it is really cold even in Summer
sv2008
Fri Dec 08, 2006 7:20 am
I was in Murcia, but not far away.
It was cold on the surface, never mind at 20m even though I had 110/200 Bar left (over half my supply) I was ready to surface after 30mins because I was very cold (We had to surface because another diver was down to 40 already).
And we had thick full length wet suits on. 1m there makes the difference between swimming in warm and freezing cold water, with severe thermoclines.
The only other place I dived (Thailand) the temperature change was gradual and minimal.
CaptainJon
Fri Dec 08, 2006 8:40 am
Good question! Tides as someone said it probably true, but remember it is also 40+ air temperature so it is rather relative. The Mediterranean seems warmer (though I don't know if temperature wise it is actually warmer) because it is cooler (and more humid) in the north.
BCNGRO
Fri Dec 08, 2006 9:33 am
This is a map of today's sea water temperature in Europe. I don't think water in the Mediterranean sea is much different to that from other areas at the same latitude. And this stays the same in summer too.
Geographic temperature anomalies are usually caused by currents (such as the Gulf current which brings warm water to northwest Europe or the Labrador current which makes cold water flow from the Labrador Peninsula down to the US northeast). The Mediterranean sea, however, is not known to be under the influence of any important current and so its water is at a normal temperature for its latitude (it just tends too cool down a little faster in winter and warm up a bit faster in summer as its smaller than oceans).
http://www.wetterzentrale.de/pics/Reursst.gif
At the bus station, buses stop. At the train station, trains stop. At my desk, I have a work station.
NAV20
Fri Dec 08, 2006 10:10 am
No - it's open to the Gulf of Aden and the Indian Ocean. Why else are there all those locks in the Suez Canal?  Smile
My guess would be that the water temperature could vary a lot depending on the state of the tide.and currents.
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
RichPhitzwell
Fri Dec 08, 2006 1:39 pm
Nonav.com kinda like Whiners except the lights are on and the pimps been paid
ME AVN FAN
Fri Dec 08, 2006 2:24 pm
Quoting RichPhitzwell (Reply 13):
Hope this helps:
plus THIS here :
Aqaba's climate makes it a refreshing location for year-round diving. The water temperature averages 22.5°C (72.5°F) in winter and 26°C (78.8°F) in summer.
source: http://www.atlastours.net/jordan/scuba_diving.html
miamix707
Fri Dec 08, 2006 3:16 pm
it shouldn't be. What happens is that if you are outside in 100F temps and take a dip in 80deg F water it will feel COLD. However once you're in the water and start swimming it shoudlnt feel cold anymore.
I was in Palm Beach this past weekend and the surf was 77F according to the information the lifeguard had written on a public board. Everyone seemed to be afraid to get in but I decided I wanted to snorkel a bit.. and yes it was a little cold initially but once in, the temperature felt perfect (I hate cold water).
The central Florida coast is about at the same latitude as Eilat but the water gets a lot warmer during the summer (reaching the low 90's)
Quoting ME AVN FAN (Reply 14):
That's not a lot different than Hawaii for example, where the water is not as warm as the Caribbean areas that lie at the same latitude. In Hawaii it has to do with the ocean currents. Same thing with the Galapagos, right in the Equator but the water is chilly because of a cold current coming from the south.
For some reason the Red Sea has cooler temperatures than other tropical seas at the same latitudes, maybe it's the depth? Can't be because of the ocean currents since it's enclosed.
ME AVN FAN
Fri Dec 08, 2006 3:40 pm
Quoting MIAMIx707 (Reply 15):
you see, in Zurich, people start swimming in the lake (real swimming of hundreds of meters, not just wetting the feet) when water temperatures exceed 18 degrees centigrade. And when it is as high as 24 degrees, some find it rather too warm . I like it if it is above 25 degrees .
strasserb
Fri Dec 08, 2006 9:25 pm
This report explains all what you never wanted to know about the water temperature at Eilat:
http://isramar.ocean.org.il/Report1.pdf
 boggled   crazy
Still, even in the most arid desert is an airport somewhere ...
LY777
Sun Dec 10, 2006 4:09 am
does someone know the quantity of precipitation of Eilat: I have heard 20 mm but some say more, some say less...
TurkishWings
Sun Dec 10, 2006 4:51 pm
I was in Aqaba last year in late October and the water temperature was perfectly normal. I didn't have any difficulty in swimming whatsoever....
Quoting ME AVN FAN (Reply 16):
I am sure you remember the incredible August 3 summer ago  Smile (I think it was 3 summers ago). It was hotter than any place I know of.... Temperatures exceeding 40 C. We went to Vierwaldstattersee to refresh ourselves but it was more of a torture.... And there were warnings as to not to swim in the lakes due to high level of bacteria produced by heat.... What a summer it was....
Coffee - Tea or Me?
LY777
Sun Dec 10, 2006 8:48 pm
What about the Dead Sea?
In summer, the water temperature must be 98°F/37°C!!!
ME AVN FAN
Sun Dec 10, 2006 11:04 pm
Quoting TurkishWings (Reply 19):
It was a tremendous summer, in 03 ! And never mind, Swiss scientists always warn about bacteria in the water or in the air (it is either too hot or too cold, too dry or too humid), about too much sun or insufficient, about too much orange juice or the contrary.
miamix707
Tue Dec 12, 2006 1:33 pm
too much orange juice bad? what does it do?
Actually ME AVN, i heard that if you're going to be in the sun and take enough vitamin C (which orange juice has) it won't damage your skin. I woudln't risk it though.
Isn't there a weak EL Nino this year? The Eastern Pacific have gotten a much more active than normal hurricane season (warmer water).
I have to say I quickly read all that about why the water in Eilat is cool. They mention thermoclines and other things but being that place is basically closed and narrow, it still doesn't make sense to me.
ME AVN FAN
Tue Dec 12, 2006 5:48 pm
Quoting MIAMIx707 (Reply 22):
too much can indeed cause an orange-allergia resulting in serious skin-conditions
anyway, the summer 03 was excellent in Central Europe, where average people do not care much about el-Nino, while the scientists are all out for such stories.
LY777
Wed Dec 13, 2006 3:54 am
2003 was really horrible in Paris, too.
By the way, on July 31th and August 1st 2002, the temperature reached 48.8°C in Eilat!!!
SFOMEX
Wed Dec 13, 2006 4:34 am
Don't trouble yourself about it! Come to Cancun where the water is always right. I'm going to CUN next weekend and I'm sure I will find a warm and nice sea.  sun   Cool
The only thing worst than the GOP is the Democratic Party, think about it!
miamix707
Wed Dec 13, 2006 10:46 am
Quoting SFOMEX (Reply 25):
Actually I heard in February the water isn't always so warm, my brother went there one spring break and found the water cold, of course he was expecting the water in winter to be like it is in Miami during summer...
Quoting LY777 (Reply 24):
that's crazy! I'm sure that day people were glad the water is as cool as it is Big grin
Quoting ME AVN FAN (Reply 23):
I should have developed that a long time ago then  Wink
Here in Florida the hottest summer was in '98 during the last big el Nino. I remmeber ants outside were trying to get inside the house to escape the heat. When coming outside one day I remembering feeling a slight wind hitting me, but this wind was hot!
Quoting LY777 (Reply 20):
I've seen pics of people that have gone there and how easily they float! Pretty cool. Nothing lives there except for maybe some bacteria right?
ME AVN FAN
Wed Dec 13, 2006 6:20 pm
Quoting MIAMIx707 (Reply 26):
In summer, the water temperature must be 98�F/37�C!!!
I have been swimming in the Dead Sea once. Interesting and nice to be "avove the water" except that it was difficult to get the feet into the water, and after swimming you had a white crust all over your body, rather strange, but quite an experience. And that at 330 meters below sea-level !
LY777
Thu Dec 14, 2006 5:30 am
I swam in the Dead Sea last April.It was really great, the water was not too hot, something like 93°F
Users browsing this forum: einsteinboricua and 4 guests
