Dougloid
Upgrading A Hard Drive
Fri Dec 15, 2006 2:11 am
Folks, I picked up a 160 gb hard drive for Thurgood, my Dell desktop, this week. It's my intention to migrate all the files including the OS and replace the 40gb hard drive that sits there presently and use the 160 gb Seagate as my primary drive.
I've gotten some information on this.First was a series of articles by Fred Langa in Information Week which advise the use of Windows Disk Imaging. I also downloaded a 15 day free trial edition of Acronis True Image 10.0.
Anyone have any ideas on the least painful way to get the drives swapped out?
Pope
RE: Upgrading A Hard Drive
Fri Dec 15, 2006 2:16 am
A couple of months ago I upgrade my 60 GB harddrive on my laptop to 100 GB. I purchased a kit a Best Buy that had the laptop and some software that allowed me to mirror the drive. It worked perfectly and in less than 30 minutes the new drive was installed and ready to go.
I'll see if I can find the name of the software later tonight when I head home.
Hypocrisy. It's the new black for liberals.
andessmf
Fri Dec 15, 2006 2:17 am
The last time I did that Norton Ghost was used.
Worked great.
Go3Team
Fri Dec 15, 2006 2:28 am
Depending on the laptop, and how much crap you have on it that you want to save, you could just install the hard drive into the laptop, and use the rescue disk that should have come with the laptop to reinstall the OS onto the new disk.
Yay Pudding!
IFEMaster
Fri Dec 15, 2006 2:49 am
These are quite good if you want to slave the current hard disk...
http://www.bixnet.com/usbporenfor2.html
Delivering Anecdotes of Dubious Relevance Since 1978
Dougloid
Fri Dec 15, 2006 4:06 am
Quoting Pope (Reply 1):
That would be pretty helpful, thanx.
aloges
Fri Dec 15, 2006 4:37 am
I've only ever done that on the cheap, which means plugging the new drive into the PC as a slave and then copying everything from the master manually. I select everything on the old HDD, tell Windose to copy it to the new one and once the "can't copy file blahblahblah" windows pop up, I check where it stopped and make it continue after that.
I do have Acronis TrueImage though, I've used it to backup my C partition on the D partition. I don't have truly vital info on my machine, so that's fine for me, and I've never needed any backups I made anyway. So alas, I can't tell you how easily Acronis images are restored.
[Edited 2006-12-14 20:56:43]
Dougloid
Sun Dec 17, 2006 1:47 pm
Quoting Aloges (Reply 6):
I downloaded a copy of Acronis Trueimage 10.0 on a 2 week tree trial after doing a little research. The instructions were dead simple and I've just completed a seamless trouble free hard drive replacement/upgrade with nary a snag.
It worked so well I'll probably go and buy a copy of it. Which is pretty likely what the folks at Acronis wanted.
No matter, I don't think I could have bought the hard drive for much less than I did.
It gets the Devil Cat stamp of approval....
Big version: Width: 640 Height: 480 File size: 59kb
Zelda the devil cat
rolfen
Mon Dec 18, 2006 1:38 am
Just my 5 stamps (1 cent each), if you're a geek like me, you can use:
Ranish Partition manager
It's a freely downloadable bootable floppy which will copy your partitions for you.
When you launch it you get a dos-like screen full of cool numbers on a blue background that will make you look real smart it's not such a big deal, really, but some people dont want to deal with it.
So what you'll do is copy the 40 gigs partition to the new disk and mark it as bootable partition, and install a regular boot sector, all this from ranish p.m. (rpm).
Now you'll be left with a problem: you have a 40 gig partition and 120 free gigs. What to do? You cant just resize the partition with rpm, it will corrupt it.
Either you just create another partition on the 120 free gigs, and you'll have two logical drives on your pc ( c: and d: ) or you use a special tool for resizing partitions... maybe your acronis can do that but you'll have to pay... I usually use partition magic, but it's not free either, and you need the newest version or else it might corrupt your data.
[Edited 2006-12-17 17:40:34]
rolf
Dougloid
Mon Dec 18, 2006 5:01 am
Well, it worked like a champ and I don't seem to have lost any settings or data. Acronis True Image is a good product, and not only that, it has very good documentation.
Users browsing this forum: aviationaware, tommy1808 and 1 guest
