Leezyjet
Why No Turbine Powered Cars?
Fri Dec 29, 2006 10:39 pm
As piston power is fairly inefficient, why have manufacturers never really botherd to invest in making a turbine powered car ?.
Not talking huge jet powered things like Thrust SSC or that thing that Richard Hammond crashed.
From what I know of a/c engines, turbines only have one moving part and are much more efficient in turning the fuel into power as very little power is lost in the movement of the engine.
Surely the technology is there to produce a small turbine that would be able to power a vehicle.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
TheSonntag
RE: Why No Turbine Powered Cars?
Fri Dec 29, 2006 10:50 pm
It might surprise you, but this was actually tested in the 70s, and believe it or not, piston engines are much more suited for cars.
Airplanes tend to cruise at the same RPM for a long time, while cars must speed up and down all the time. Turbine engines are bad at speeding up and down compared to piston engines. You can easily speed up a piston engine very fast, while it takes some time for Turbine engines.
Of course, you could use a turbine to power an electric engine for a car, but this is highly inefficient.
Also, a Diesel engine is, in fact, a very efficient engine. Just because the piston engine principle is old does not mean it is outdated.
KaiGywer
Crew
Noise and speed control come to mind. I would imagine it being hard to control the speed, and where would the HOT exhaust go?
It has been done though. Not a success  Smile Love the sound on the webpage, and can you imagine smelling Jet A-1 while driving...mmmm Big grin
http://www.turbinecar.com/turbine.htm
http://www.familycar.com/Classics/ChryslerTurboCar.htm
jamesbuk
Fri Dec 29, 2006 10:56 pm
Quoting KaiGywer (Reply 2):
aaahhhh man thatd be heaven!! My fave part of any airport is standing behind the active take off runway and smelling the fuel as it burns when they take off.
Isnt a fair bit of energy wasted as heat in a jet engine though?
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
vc10
Fri Dec 29, 2006 11:14 pm
Try the following web site and you will see that the Rover cars produced a jet powered car in 1950 , but it never went into general production
http://news.bbc.co.uk/onthisday/hi/d...march/8/newsid_2516000/2516271.stm
littlevc10
baroque
Fri Dec 29, 2006 11:26 pm
Quoting TheSonntag (Reply 1):
So much so that with the first German jets, the Arado bomber had (then) acceptable engine life, because of limited throttle changes whereas the Me262 with basically the same engines had no end of trouble because of the demands for throttle change and accompanying wear of the engines.
Quoting VC10 (Reply 4):
The rather lousy fuel consumption they quote was probably with the version that had a complex heat recovery system using, IIRC glass beads. Another problem was the lag on acceleration, apparently it was very difficult to drive out of a corner. Nothing much happened as it spooled up and then all hell was let loose.
It is a pity the main account seems only to be the contemporaneous "gee whiz this is new" sort of article.
Rover's association with gas turbines was problematical to say the least. They were designated by the UK Government to deal with Power Jets and Sir Frank Whittle, but made such a pig's breakfast of it during WWII, that the main work was taken over to RR. Whittle's autobiog is quite revealing on the subject.
KaiGywer
Crew
Fri Dec 29, 2006 11:29 pm
Quoting Baroque (Reply 5):
Reading the Chrysler site, it seemed like it worked really good, but was killed by treehuggers because of too much Nitrous Oxide emissions
777DadandJr
Fri Dec 29, 2006 11:33 pm
Quoting Jamesbuk (Reply 3):
This was a bit obstacle to overcome. I remember reading an article some time ago about the Chrysler Turbine of 1963. It was said that at idle the temperature of the exhaust emitted from the tailpipe was in excess of 500 degrees!
Wouldn't want to step off the curb in sandals behind one of those puppies!
Russ  wave
My glass is neither 1/2 empty nor 1/2 full, rather, the glass itself is twice as big as it should be.
Leezyjet
Sat Dec 30, 2006 8:00 pm
That sounds great. I'd love to hear that humming along every morning. IIRC you could run a diesel car on Jet A-1 without any modifications. A guy I used to know used to fuel his Renault 5 GT Turbo with Av-Gas then take it for a blast down the runway at RAF Linton-on-Ouse !!.
Surely though the turbine technology has come a long way since those cars back in the 60's/70's that could make it a viable alternative when combined with electric motors.
 Smile
f.pier
Sat Dec 30, 2006 9:05 pm
But what would happen when a car turned left and the jet flow hitted against pedestrians?
sv2008
Sat Dec 30, 2006 9:09 pm
Quoting 777DadandJr (Reply 7):
Gas from a piston engine can be as much as 800'C - although a smaller amount, and it cools a bit before leaving the car.
I think lack of low speed torque was a problem too, something you need for cars.
TedTAce
Sat Dec 30, 2006 10:11 pm
I'm surprised this didn't get a mention:
http://www.indy500.com/news/story.php?story_id=1923
http://www.autodrome-cannes.com/indy67_grid_parnelli_jones.jpg
Personally, I'd love to have:
http://962.com/events/FOW_day/fullimages/DSC_0009.jpg
With a PT6 in it!!!
It's not a car, but I'd also love to have:
This space intentionally left blank
sv2008
Sat Dec 30, 2006 10:55 pm
^Those cars are turbine/electric hybrid presumably?
TheSonntag
Sat Dec 30, 2006 11:06 pm
Not a "car" in this respect, but worth mentioning is the M1 tank, which also uses a gas turbine. As far as I know, there are no real advantages compared to a big Diesel for a tank.
sv2008
Sat Dec 30, 2006 11:28 pm
Only power to weight ratio presumably, but they would have many other disadvantages.
baroque
Sat Dec 30, 2006 11:51 pm
Quoting KaiGywer (Reply 6):
Well if you read the Rover stuff it is all gee whiz - wonderful. But the realities were a bit different. One of histories great ideas that on further examination was not that great. Mind you, Rover and turbines had not gone well previously, so that might have been one extra problem.
Duff44
Sun Dec 31, 2006 3:40 am
Quoting Sv2008 (Reply 12):
The top one and the boat are straight turbine drive... no electric.
The Nissan has a V6 twin-turbo
How about a turbine motorcycle?
http://www.marineturbine.com/motorsports.asp
320HP Roll-Royce Allison 250 series gas turbine, top speed appx. 227mph/365kph
One big problem with turbine power is heat. You don't want to be touching an exhaust that's at 1700º or whatever it is.
I'll rassle ya for a bowl of bacon!
Alessandro
Sun Dec 31, 2006 5:16 am
Didn´t checker sell a turbinecar?
AsstChiefMark
Sun Dec 31, 2006 6:24 am
The turbine delay was about 5 to 10 seconds. They took a while to start moving after you hit the gas.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
cptkrell
Sun Dec 31, 2006 10:59 am
Part of Sonntag's (Rep 2) pretty well sums it up. Turbines are efficient at steady throttles and they also take time to throttle arrive.
The general demands of automotive performance (with some exceptions, say, WOT at Indy as per the Granatelli car, save execution demands for a wreck or ingress/egress pits), requires constant throttle changes expecting constant and immediate vehicle responses in daily driving. Turbines are poorly responsive in this area, and even if perhaps a 20+ speed transmission or equivalent power-transfer program were engineered to enhance a turbine's plus/minus fuel flow were perfected, I would think that the cost/weight etc would still result in a minus in the total efficiency spectrum.
Many years ago, myself and a couple others designed and packaged a small constant RPM turbine (a Williams unit, IIRC) as an APU for luxury cars. The design intent was to completely eliminate all auxillary take-offs from the car's engine (alternator, water pump, power steering, brakes, electrical loads, etc, etc), so the engine would be free to power the car at whopping increase in torque and horsepower and much better mileage, but too many hiccups in the overall scheme lead us to turbocharging/supercharging and increased CIDs to make up for added power loads.
I would opine that even with today's technology, gas turbines in automobiles would rank on the same page as screen windows in submarines. Regards...jack
all best; jack
falstaff
Sun Dec 31, 2006 11:37 am
I was able to ride in a Chrysler Turbine car in the mid 90s just after the Museum of Transport in St. Louis got theirs running again. We didn't go far, just a few laps around the parking lot. The exhaust was incredibly hot and there was a lot of it compared to a regular car of the 60s. Just standing behind it for a short period was enough to break a sweat.
Quoting AsstChiefMark (Reply 18):
There was a bit of delay I recall, but since I wasn't driving I really didn't notice. I know the driver said it took some getting used to.
Quoting Alessandro (Reply 17):
I don't think so.
That might be true. US federal emissions came in for 1971 and California had them in 1966 (I think). In the mid 60s emission controls were not a big deal, but if Chrysler was thinking for the future that would be a good reason to kill it off.
My mug slaketh over on Falstaff N503
ltbewr
Sun Dec 31, 2006 11:48 am
Despite the relatively few parts involved with small turbines, they are very expensive, much more so than a piston engine. The extreme heat, very tight tolerances, the costly labor costs for the machining needed and the very expensive materials needed, along with pollution, fuel consumption, and other factors noted in previous posts, means that turbine powered cars or light trucks are impractical.
AirCop
Sun Dec 31, 2006 2:06 pm
Quoting TedTAce (Reply 11):
http://www.indy500.com/news/story.ph...=1923
Remember that race, the teams were complaining that the turbine car had an unfair advantage. Parnelli Jones was just cruising like he was out for an weekend drive, when the $6 part gave out, with 3 laps to go.
Rj111
Sun Dec 31, 2006 9:42 pm
Gas turbines are only really efficient at their top rotation speeds. Ideally you'd want a turbine powering an alternator powering an electric motor to get any practical use out of it.
Even still fuel consumption is still poor. Though lower maintenance required is another advantage.
mandala499
Mon Jan 01, 2007 8:19 am
How about a constant speed turbine and a continuous variable transmission? *evil grin*
I wonder how good this would be for trucks...
As for the exhaust, well, make for some use of the heat... or diffuse it further.
Mandala499
N231YE
Mon Jan 01, 2007 8:52 am
I don't know about the heat being that much of a problem. I remember reading an entire book on this car a while back, and it had heat exchangers in the exhaust. They exchanged the heat to the intake air aft of the compressor, cooling the exhaust gas to around 600ºF.
[Edited 2007-01-01 01:12:48]
glydrflyr
Mon Jan 01, 2007 12:15 pm
A very important issue not mentioned in any of these posts is the matter of braking in a turbine powered car. A recip engine in cars or trucks provides instant engine braking when the accelerator is released, thus helping to slow the vehicle. Downshifting, in either a standard or automatic transmission vehicle, dramatically slows it, and most cars with four or more speed automatic trannies allow the driver to turn off the overdrive feature at will, helping to slow or maintain speed on long downhills, thus reducing brake usage and, in cars with barely adequate brakes, preventing the possibility of brake fade.
Chrysler discovered this, much to their chagrin, with the turbine powered Plymouths of 1954. The brakes of that time were simply not up to the kind of use that would be required of them in normal driving with a turbine engined car. Those brakes were drum type, not the rotors most car today have, and were prone to fade and were also almost useless when they got wet. The technique of the day for drying the brakes was to drag them for a while until you felt them becoming effective. Not something I would have wanted to depend on if I drove a turbine car at that time.
Chrysler, and the trade magazines of the day, were all predicting that by 1960 most vehicles would be "Jet Powered".
if ya gotta crash, hit something soft and cheap!
KaiGywer
Crew
Mon Jan 01, 2007 10:47 pm
Quoting RJ111 (Reply 23):
Also known as an APU?  Smile
baroque
Mon Jan 01, 2007 11:09 pm
Quoting N231YE (Reply 25):
The heat exchanger on the Rover was quite bulky (that is what the glass/ceramic beads were for) and IIRC the fuel consumption was still lousy.
sv2008
Mon Jan 01, 2007 11:13 pm
Quoting KaiGywer (Reply 27):
No, because it's not aux it is for the main engine.
The problem with this arrangement is heavy batteries are needed to store the energy. This doesn't work well in cars because you'd need lots of them, as the speed of the car changes frequently - the turbine speed would have to be constantly adjusted too, to an extent, to save fuel.
It's not like a Prius hybrid, you'd need far more than that to provide enough power.
There was a turbine hybrid car that used a flywheel instead, I have an article on it somewhere. This is even less practical than batteries though.
KaiGywer
Crew
Mon Jan 01, 2007 11:24 pm
Quoting Sv2008 (Reply 29):
Well, in an airplane. A jet engine used to power a generator though, is basically an APU  Smile
However, what's the point?  Smile
cptkrell
Mon Jan 01, 2007 11:37 pm
Glydrflr did bring up what I think is an additional important point; inherent engine braking (a point I might mention, totally lost with some naive posters who preached in another thread the favorability of putting a vehicle in neutral to "coast" to stop lights and down grades - not a good idea).
As he also pointed out, most USA car brakes at that time were of the drum type, clearly illustrating the ineptitude of American manufacturers when it comes to priorities. Anti-lock disc brakes had been around for a LONG time prior to the 1960s and their advantages, even without today's sophisticated computer technology, was a given, but put on the back-burner while flights of fancy technology (ie: the turbines in everyday passenger cars we are talking about now) were deemed more important even though practicality was, and is still now, highly suspect. Regrads...jack
all best; jack
N231YE
Tue Jan 02, 2007 2:36 am
Quoting Baroque (Reply 28):
Very true. I wonder how many miles per gallon or litres per 100 km the car obtained?
Quoting Glydrflyr (Reply 26):
Its good that you mentioned that...I never knew that brakes and engine braking also play a role in the car's impracticability.
Rj111
Tue Jan 02, 2007 2:53 am
Gas turbines were once a viable option for train, and still are in some cases. But the rise in fuel prices has all but nullified this.
http://upload.wikimedia.org/wikipedia/commons/e/e5/Union_Pacific_18.jpg
This article should highlight some of the reasons a gas turbine would not be so good for a train and subsequently a car.
http://en.wikipedia.org/wiki/Gas_turbine-electric_locomotive
Users browsing this forum: mad99 and 19 guests
