jamesbaldwyn
XP Display Page
Tue Jan 02, 2007 6:33 am
Hi guys It would be really appreciated if you could help me.
On the XP Display Panel I have for some reason lost my tabs, by tabs I mean screen saver, appearance, settings etc etc. I still have the themes bit although there's a blank space where the tabs should be
This means that I cannot adjust any display settings which I need!
See what I mean?
Thanks Guys
EMBQA
RE: XP Display Page
Tue Jan 02, 2007 9:56 am
I'm not sure... With XP you can just re-set the computer to an earlier date...just do that.
[Edited 2007-01-02 01:57:18]
RE: XP Display Page
Tue Jan 02, 2007 5:54 pm
If that does not work Use the Installer CD & do a repair.
regds
MEL
Jetsgo
RE: XP Display Page
Tue Jan 02, 2007 7:47 pm
That icon there on your desktop, WinCleaner Memory....
What exactly is it? Does it have to deal with your registry by any chance? A lot of times freeware registry cleaners can do really bizarre things to a computer. This is all of course just a small idea based off of an icon.
Your best bet though is to run System Restore to the most recent date in which you know your computer was working fine.
Chris
Marine Corps Aviation, The Last To Let You Down!
jamesbaldwyn
RE: XP Display Page
Tue Jan 02, 2007 10:33 pm
I have had it for one day, its supposed to improve RAM consumption but I haven't noticed a difference
2112
RE: XP Display Page
Wed Jan 03, 2007 2:03 am
Before you do any system restores, I'd remove that WinCleaner Memory program first, then run a full virus and spyware scan and clean and remove anything you find (viruses have been known to infect System Restore files). If your tabs return, you've found the culprit. If they do not, then you need to check your registry.
There are several registry entries that affect the tabs in the Display Control Panel applet. Before making any changes to the registry, make sure to back it up first! The entries listed below may not appear in your registry, so you'll need to create them if you still can't see the tabs after running a full virus and spyware scan and removing anything nefarious. If the entries do exist, make sure the DWORD values are set to zero (Hexadecimal)
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem]
"NoDispAppearancePage"=dword:00000000
"NoDispBackgroundPage"=dword:00000000
"NoDispSettingsPage"=dword:00000000
"NoDispScrSavPage"=dword:00000000
Chris
LHRjc
RE: XP Display Page
Wed Jan 03, 2007 2:11 am
the following link is valid for xp as well as nt
http://www.microsoft.com/technet/arc...as/maintain/profiles.mspx?mfr=true
The Control Panel—Restrict Display Option
This setting, shown in Figure 13.10, removes or enables tabs in the Control Panel Display applet by setting the following values under the [HKEY_CURRENT_USER _Software Microsoft Windows CurrentVersion Policies System] key.
NoDispCPL 0 or 1
REG_DWORD
When this value is set to 1 or the Deny access to display icon box is checked (see Figure 13.10), the Display applet of the Control Panel does not display. If set to 0 or the box is cleared, the applet is displayed.
NoDispBackgroundPage 0 or 1
REG_DWORD
When this value is set to 1 or the Hide Background tab box is checked (see Figure 13.10), the Background tab on the Display applet does not display. If set to 0 or the box is cleared, the tab is displayed.
NoDispScrSavPage 0 or 1
REG_DWORD
When this value is set to 1 or the Hide Screen Saver tab box is checked (see Figure 13.10), the Screen Saver tab on the Display applet does not display. If set to 0 or the box is cleared, the tab is displayed.
NoDispAppearancePage 0 or 1
REG_DWORD
When this value is set to 1 or the Hide Appearance tab box is checked (see Figure 13.10), the Screen Saver tab on the Display applet does not display. If set to 0 or the box is cleared, the tab is displayed.
NoDispSettingsPage 0 or 1
REG_DWORD
When this value is set or the Hide Settings tab box is checked (see Figure 13.10), the Screen Saver tab on the Display applet does not display. If set to 0 or the box is cleared, the tab is displayed.
Edit: Sorry 2112 beat me to it  Wink
[Edited 2007-01-02 18:11:55]
"Our 319's are very reliable. They get fixed very quickly."
jamesbaldwyn
RE: XP Display Page
Wed Jan 03, 2007 7:08 pm
lol thanks both of you, I Shall give it a try now
looks a bit confusing lol
Users browsing this forum: c933103, Dutchy, FriscoHeavy, GrahamHill, moo, salttee and 3 guests
