tz757300
Computer Help
Sun Jan 14, 2007 1:38 pm
Here's the deal. A while ago, I reinstalled Windows because there was some serious internal software issues happening and I thought just over-writing the whole OS would do the trick. I thought it did, but today I realized that it didnt overwrite my Windows, but there is a second Windows program on my hard drive. Why? I have no clue. So now I have two HUGE OS's on the hard drive and now I only have 20% of my Hard drive space instead of at least 50%. Does anyone have any good ideas on how to get rid of the bad windows?
LETS GO MOUNTAINEERS!
andz
RE: Computer Help
Sun Jan 14, 2007 1:41 pm
Reformat and repartition your drive, it is the best way to do it, but BACKUP YOUR DATA FIRST OR IT WILL BE LOST!
tz757300
RE: Computer Help
Sun Jan 14, 2007 1:57 pm
Once I reformat and repartition the drive, how exactly do I put Windows back onto the hard drive?
andz
RE: Computer Help
Sun Jan 14, 2007 2:00 pm
If you insert the windows CD and follow the instructions carefully the reformat and repartition is part of the procedure.
tz757300
RE: Computer Help
Sun Jan 14, 2007 2:07 pm
But thats the thing, I did that same exact option and I ended up with 2 Windows on my hard drive. Can't I just get my hard drive completely wiped and start from there?
AC773
RE: Computer Help
Sun Jan 14, 2007 2:12 pm
Quoting TZ757300 (Thread starter):
I'd be willing to bet that when you re-installed Windows, you did a quick-format. The quick option is really only meant for brand new drives, and old HDDs need a full format.
All you need to do is re-install Windows and make sure you delete all partitions and do a full format using NTFS (I presume you're installing XP).
That should do it.  Smile
Better to be nouveau than never to have been riche at all.
tz757300
RE: Computer Help
Sun Jan 14, 2007 2:17 pm
Quoting AC773 (Reply 5):
Thanks AC, but what is the effect of having no partitions on the hard drive?
Also, I'm considering upgrading my hard drive so something bigger by the time college comes around. How would I go about installing Windows and transferring all my files to that?
andz
RE: Computer Help
Sun Jan 14, 2007 2:20 pm
Quoting TZ757300 (Reply 6):
AFAIK you have to partition today's big drives because Windows has issues with the size, but I may be wrong.
AC773
RE: Computer Help
Sun Jan 14, 2007 3:06 pm
It just lumps everything into one big happy volume. Unless you need separate virtual drives to sort your data, there's no reason to have any partitions.
If it's a desktop, you can simply install the hard drive and use it for miscellaneous data while using your old drive for Windows. If it's a laptop, all you need is an external USB enclosure along with your new drive (about $30 from a place like Newegg.com). Put the new drive in the enclosure and use a program like Acronis TrueImage to clone the data onto your new drive. Put the new drive in the notebook and the old one in the enclosure, and your machine should boot up just like it always did. After you clean out the stuff in your old drive you'll end up with a new, bigger hard drive in your machine and a bonus external drive.
Quoting Andz (Reply 7):
You're half right. Before XP, consumer versions of Windows used an MS-DOS core and the FAT32 filesystem. FAT32 limits drive volumes to 32 GB, so large drives running Windows ME and earlier versions had to have partitions in order to utilize all their space. XP brought with it the NT core and NTFS filesystem, and the volume limit was gone for good.
WSOY
RE: Computer Help
Mon Jan 15, 2007 5:28 am
Quoting AC773 (Reply 8):
Reply 6):
You won't be able to access any of your drive, that's it. You first partition the disk space into the addressable blocks you need, often just one, then format it (them) to the filesystem you need (NTFS is the preferred choice for later Windowses).
After formatting, the partitions normally become accessible by their letters (C: D: and so forth).
The Windows setup program, when run from the installation CD, will both partition and format the drive if you so instruct.
"Nukkuessa tulee nälkä" (Nipsu)
AC773
RE: Computer Help
Mon Jan 15, 2007 7:09 am
Quoting WSOY (Reply 9):
Strictly speaking, yes. But if you delete all of your drive's partitions when installing XP, the installer will automatically create one big one to span the drive.
Let's not make things any more complicated than they have to be.  Smile
tz757300
RE: Computer Help
Mon Jan 15, 2007 7:50 am
So I can have no partitions on the HDD and still access my files? I dont have any need to separate the drive into anything else. I just got my External HDD for overflow
AC773
RE: Computer Help
Mon Jan 15, 2007 9:10 am
Quoting TZ757300 (Reply 11):
 checkmark
Windows will take care of it for you.
tz757300
RE: Computer Help
Mon Jan 15, 2007 12:37 pm
Well I'm glad to say that I am now free of my old windows and now have a brand spankin new copy on a clean, formatted drive. This thing runs like new again. Plus, with my 160GB External HDD, I have loads of new room to do basically whatever I want. Granted it took me about 5 hours from start to finish, but the result was worth it.
Thanks everyone who helped!!!
damirc
RE: Computer Help
Mon Jan 15, 2007 4:15 pm
Um. No.
Quick means just create the filesystem and do not perform a bad block check on the drive ....
D.
WSOY
RE: Computer Help
Tue Jan 16, 2007 12:12 am
Quoting AC773 (Reply 10):
Yes l agree. Therefore I said it's wrong to say an unpartitioned space "lumps everything together" as you put it. In reality unpartitioned space is not acessible to any other programs than the ones that create the actual drive filesystem for other software to use. No "lumping".
Mysteriously, I myself have created some very large FAT32 partitions, e.g. by drive cloning. Some partitioning tools let you do it, some not.
See here:
http://www.petri.co.il/install_windo...s_xp_on_large_fat32_partitions.htm
AC773
RE: Computer Help
Tue Jan 16, 2007 2:08 am
Quoting Damirc (Reply 14):
Fair enough, though in my experience, an NTFS quick-format occasionally leaves the old OS bootable at startup.
Quoting WSOY (Reply 15):
Is it wrong to say that? Yes, technically.
Does it make a discernable difference in the real world? No.
I don't know how many times I've installed XP, but every time the procedure is the same. Delete all partitons, format the unpartitioned space, and let XP install itself on that. It leaves me with a single volume spanning the full capacity of the drive, and I don't have to put any more thought into it.
Again, I'd rather not split hairs.
WSOY
RE: Computer Help
Tue Jan 16, 2007 4:03 am
Quoting AC773 (Reply 16):
I think this is just what has lead to your confusing the terms. The fact that the XP installation software does both the partitioning and formatting for you, may have prompted your thinking they are the one and the same. Sorry, I just had to point this one out, no hard feelings, I hope.
damirc
RE: Computer Help
Tue Jan 16, 2007 7:02 am
It does work. The limit is imposed by politics rather than technology. I currently have a 151GB FAT32 partition. NTFS is all sweet, but if you're dual booting any flavor of Linux you know how nice it is to write to NTFS partitions from Linux  Wink
That would be the root block, the OS is not really bootable, but the boot loader starts to load only to fail, because it cannot find anything on the drive to boot.
Sorry, to be anal ... but You cannot format unpartitioned space. You can delete all the partitions, create a new partition (or several of them) and then you're on to formatting. No offence.
D.
srbmod
RE: Computer Help
Tue Jan 16, 2007 8:10 am
This thread is being locked at the request of the thread starter, as all of the questions the user had have been answered.
Users browsing this forum: Dutchy, notdownnlocked, Scorpio and 2 guests
