aloges
Coffee Mills
Wed Feb 07, 2007 11:21 pm
Hi all!
Recently, I started milling the black pepper I use instead of buying it milled. I noticed several worlds of difference in the taste, and that got me thinking about the coffee I like to drink.
I usually make small portions, no more than two cups at a time, using a French press. I still buy my coffee milled, and to be honest it could sometimes be better. So how much of a difference would I notice if I had a mill and bought the beans instead of the powder?
thanks for your time,
aloges
ANCFlyer
RE: Coffee Mills
Wed Feb 07, 2007 11:30 pm
Quoting Aloges (Thread starter):
Light Years.
I never use pre-ground coffee. It's ground right before I use it, I prefer a very fine grind. There's no mistaking the difference.
Do it . . . you'll never be sorry.
luv2fly
RE: Coffee Mills
Wed Feb 07, 2007 11:49 pm
I agree with ANCFlyer! The difference is night and day.
Lutenist
RE: Coffee Mills
Wed Feb 07, 2007 11:52 pm
If you really want to do it right, get an electric bur mill (not a hand-turned mill, as you might find it too slow). Each bean passes through the bur mill once, which makes for an even ground. Also, the bur mills tend not to heat the bean, as do impellor grinders.
Impellor grinders are not ideal, as beans that have been ground continue to be smashed by the impellor, which causes uneveness--i.e., some course ground and some fine ground.
ME AVN FAN
RE: Coffee Mills
Wed Feb 07, 2007 11:57 pm
my coffee milled
I did so as well but a few years ago switched to buy it un-milled at mill it in those machines at the exit of decent supermarkets. It is much better that way.
Alright, in the 50ies, everybody had one of those wooden coffee mills at home to do it daily.
[Edited 2007-02-07 15:58:24]
aloges
RE: Coffee Mills
Thu Feb 08, 2007 12:08 am
Seems like you're all in agreement, I'll probably start saving for a mill then.  bigthumbsup
Quoting ME AVN FAN (Reply 4):
That's exactly what I'm thinking about, a Peugeot mill in particular. My pepper mill is a Peugeot model and I'm very pleased with it, I'm also a bit of a sucker for high(er)-end kitchen tools.
TedTAce
RE: Coffee Mills
Thu Feb 08, 2007 12:12 am
Quoting ANCFlyer (Reply 1):
Until your mill batteries run out in the middle of nowhere AK with no spares Big grin
This space intentionally left blank
aloges
RE: Coffee Mills
Thu Feb 08, 2007 12:21 am
Quoting TedTAce (Reply 6):
N00b! He runs his on polar bear excrement! Caribou as well if the bear stuff is hard to come by.  Wink
pelican
RE: Coffee Mills
Thu Feb 08, 2007 12:39 am
I would recommend you to go to a Tschibo shop and try fresh milled coffee. They mill it there for you.
pelican
ME AVN FAN
RE: Coffee Mills
Thu Feb 08, 2007 12:53 am
Quoting Pelican (Reply 8):
right, in some places they mill it for you, in others you can do the milling there with a machine of them. Except that Tchiba in my view is too weak.
kmh1956
RE: Coffee Mills
Thu Feb 08, 2007 1:09 am
Absolutely!! I flatly refuse to buy pre-ground now....it tastes like crap compared to feshly-ground.
When buying your beans, though, make sure that they gleam with natural oils, or else you may as well be buying cans of (ewww) Maxwell House.
'Somebody tell me why I'm on my own if there's a soulmate for everyone' :Natasha Bedingfield
TedTAce
RE: Coffee Mills
Thu Feb 08, 2007 1:25 am
Quoting Aloges (Reply 7):
N00b!
I got 300 days on you and your calling me a N00b?  scratchchin
aloges
RE: Coffee Mills
Thu Feb 08, 2007 1:44 am
Quoting TedTAce (Reply 11):
The hell you have, and you know it.  Wink
srbmod
RE: Coffee Mills
Thu Feb 08, 2007 6:52 am
The problem with the ground coffee you buy in the stores is that the packages are prone to lose their seal (especially those in vacuum sealed packages). Once air gets into ground coffee, the quality begins to go down. Now the fractional pack coffee is better because each pack is a set amount and the packs have nitrogen pumped in which also helps to keep the coffee fresher longer. But like the vacuum sealed packs you see in the stores, they too can have their seals fail as well (especially if they pump too much nitrogen into the packs and the end up popping their seals due to pressure.).
One important thing to remember with coffee is that air and moisture are coffee's two worst enemies. This is true with ground coffee and with beans. So make sure the container the beans are stored in has a vacuum seal that won't let air or moisture in.
As for a grinder, a burr mill is the way to go. Here's a site that has numerous reviews on grinders and other coffee-related products:
CoffeeGeek.com
Their review section of grinders contains over 900 different grinders:
http://www.coffeegeek.com/reviews/grinders
kmh1956
RE: Coffee Mills
Thu Feb 08, 2007 8:26 am
Oh yeah, one other thing...don't EVER store your coffe beans in the fridge or freezer. That's a sure-fire way of drying up all those lovely natural oils that keep the flavor so good. Store them at room temperature in an airtight container and only grind what you need.
Users browsing this forum: afterburner, Raventech, salttee and 3 guests
