Coal
Sony Vaio: Which One?
Sun Feb 18, 2007 5:39 pm
Ok, I need some advice on this one. I'm undecided between the SZ430 and the SZ450.
It seems as though all the hardware is the same and that the only differences are that the 430 has WAN whereas the 450 doesn't, and the 450 weighs less and has an LED back light on the screen.
So should I shell the extra $100 for the lighter version and for the LED light?
Coal
[Edited 2007-02-18 09:40:06]
Nxt Flts: SQ SIN-CGK-SIN | SQ SIN-DPS | GA DPS-SUB | MI SUB-SIN | MI SIN-KNO | GA KNO-CGK-PNK | GA PNK-CGK | SQ CGK-SIN
UAXDXer
RE: Sony Vaio: Which One?
Sun Feb 18, 2007 6:29 pm
Quoting Coal (Thread starter):
These days I didn't know you could get a laptop without WAN. That being said, I would go with the 430. Or get a MacBook pro, you will be a lot happier.  smirk
It takes a bug to hit a windsheild but it takes guts to stick
cabso1
Sun Feb 18, 2007 8:47 pm
Get a Mac,
Signed,
Klaus
 Wink
Coal
Sun Feb 18, 2007 10:04 pm
Quoting UAXDXer (Reply 1):
WAN is not the same as Wireless LAN (Wi-Fi)
I'm actually getting rid of a MacBook
How so?
Coal
ThePRGuy
Sun Feb 18, 2007 10:20 pm
Quoting Coal (Reply 3):
But is it a Pro?
If so, are you ok?
Alex
Heathrow has been described as the only building site to have its own airport.
Coal
Sun Feb 18, 2007 11:58 pm
Quoting ThePRGuy (Reply 4):
But is it a Pro?
If so, are you ok?
I'm goody gumdrops!  wink
I don't like Macs. Period.
Now if anyone would be kind enough to answer the question and not suggest a Mac that'd be great Big grin
Coal
ManuCH
Crew
Mon Feb 19, 2007 12:54 am
Well, it simply depends on if you need the WAN part or not. If you don't need WAN and you're sure that you won't need it in the next couple of years, go for the 450. If WAN is an important feature for you, get the 430... it would be the key point for me.
For example, I currently own a Vaio VGN-FE11S (without WAN - I didn't even know a laptop with integrated WAN existed when I bought it). I would have bought a MacBook, but my mobile carrier's GPRS/EDGE/UMTS data card isn't compatible with Macs, and having this WAN function is a basic need for me.
There, now it's up to you ... decide on whether you need that integrated WAN or not.
-Manuel
Never trust a statistic you didn't fake yourself
Klaus
Mon Feb 19, 2007 3:49 am
Apart from the built-in EDGE adapter it's a comprehensive downgrade from a MacBook in many respects - weaker port specs (slower LAN and WLAN, crippled FireWire, no digital audio, no digital video et cetera) and a much higher price - unless you compare with a MacBook Pro, but that one is still farther ahead than a normal MacBook.
Even a MacBook just running Windows is cheaper and ahead of the Vaio in many respects.
Coal
Mon Feb 19, 2007 8:45 am
Quoting ManuCH (Reply 6):
-Manuel
I know I won't need the WAN for the next 3-4 years. So in that case I guess I'll go for the 450.
Quoting Klaus (Reply 7):
 Yeah sure Are you blind or just plain stupid?
Quoting Coal (Reply 5):
Coal
Tom12
Mon Feb 19, 2007 8:48 am
A computer name with too many vowels in the title to pronounce, Vaio - Sounds like the noise a cat would make if you fed it through a mango! - Jeremy Clackson
Tom
"Per noctem volamus" - Royal Air Force Bomber Squadron IX
Klaus
Mon Feb 19, 2007 9:22 am
Quoting Coal (Reply 8):
a) I'm certainly not as rude as you are.
b) It's your decision - but others may still benefit from a closer look at the options they've got.
Coal
Mon Feb 19, 2007 8:53 pm
Quoting Klaus (Reply 10):
 checkmark
Quite rude. I take that back.
Well, then maybe they can start their own threads.
I guess in the end I'm gonna go with the 450.
Coal
mandala499
Mon Feb 19, 2007 10:01 pm
Can't help you much, but I got an SRX-87, it's aged, but still going strong, and has been through a heck of a lot, unless I have to, I'm reluctant to replace it...
Vaio....
Users browsing this forum: Ken777, WarRI1 and 1 guest
