aloges
WinXP... Recent Security Update Causes Trouble
Sat Apr 14, 2007 5:59 am
Yet another reason to get a Mac:
If you recently installed the security update described in "knowledge base" ("gospel of sorrow" would be a better name) article 925902, do not be surprised if several pieces of your software stop working. In my case, it's the built-in calculator that I've noticed so far - in other words, a security update supplied by Microsoft has stopped an extremely basic and simple bit of software built into Windows XP from working. I'll keep this civil, but the swear words floating around in my mind are definitely X-rated... just like the words of the people in the forums I found via Google, to find the culprit.
So if you've recently updated your oh-so secure WinXP with one of the latest security updates (one of the 20 they must have churned out in the last two weeks), check if your calculator still works... if it doesn't, you can either leave it at that and wait for the next update  sarcastic  or uninstall the update and hope for success, which is what I'll do.
Why can't this junk just work for one day without causing trouble?  Sad
andessmf
RE: WinXP... Recent Security Update Causes Trouble
Sat Apr 14, 2007 6:01 am
Quoting Aloges (Thread starter):
Because it has 'Windows' in its title?
Surprised its your first time encountering this type of problem.
aloges
Sat Apr 14, 2007 6:11 am
Well, it worked. I uninstalled the update and calc.exe works fine again. BRILLIANT, Microsoft!  banghead
Quoting AndesSMF (Reply 1):
Probably... if only I had a couple thousand to blow on Macs. iMac for home, MacBook for on the road. I'm simply tired of Windows, and don't want to learn Linux.
It could easily be the umpteenth time, it's very easy to lose count of your problems if you use Windows.  Wink
Goldenshield
Sat Apr 14, 2007 6:17 am
Quoting Aloges (Reply 2):
The penguin will assimilate you. Resistance is futile.
TedTAce
Sat Apr 14, 2007 6:51 am
Quoting Goldenshield (Reply 3):
 rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl  That's funny, AND true!!
This space intentionally left blank
aloges
Sat Apr 14, 2007 7:05 am
The little bugger already has, the only DSL routers I'll work with run on Linux - but fortunately, I have little to do with the kernel!  Wink
Users browsing this forum: dman87, Flighty, fr8mech, OMP777X and 1 guest
